new compiled frontend not reflecting changes
I built with gulp all and copied the front2 folder at shadow into the modules folder into my raspberry pi, restarted and I can't see any changes there that I did on the project
what's wrong? can someone help me @Repetier
![:( :(](/resources/emoji/frowning.png)
As a test put a simple image as well into shadow folder and see if it loads. If that works the copy is not exactly at same place so it falls back to original files.
https://www.repetier-server.com/startup-configuration/
