Écran tactile rotation
Bonjour,
J’ai un écran tactile sur mon Raspberry pi 3
Aujourd’hui j’ai besoin que l’écran soit retourner.
J’ai réussi depuis le fichier config dans le boot.
Mais quand je clique sur l’écran tactile j’ai l’impression que c’est toujours inverser pour descendre faut que je fasse un slide de bas en haut normalement mais là faut faire de haut en bas
La droite devient la gauche
En fin c’est incontrôlable
Comment corriger cela s’il vous plaît
See https://www.repetier-server.com/download-images/ part Rotate Display for solutions.
25.02.2024 17:00:35] : error fetchTextFromWeb:Net Exception: Network is unreachable URL:http://download.repetier-server.com/files/server/debian-armhf/updateinfo.txt
Easiest solution to rotate is the rotate function in our setup tool. When you use this pleas eundo your rotation solution first so touch and rotation match, then follow the instructions in the correct order - first select screen rotation and only then include the touch screen rotation and then apply and confirm. Order matters.
Je comprend pas je voit absolument pas le parametre https://gyazo.com/1ca2076638ef0460b0a82484caf2a1eb
https://gyazo.com/ce9a427798438fdf972954aa1c960582
/usr/share/X11/xorg.conf.d/40-libinput.conf
as described.
My solution I meant was this one:
In version 37+ we use a Raspbian OS based on the new Bookworm image. By default the image has the new graphic driver installed. To change the orientation of the display, open our Config Tool and go to 3 Touchscreen 4 Screen Orientation OK.
A screen alignment tool will appear on your touchscreen. Make sure that the screen saver was not previously activated. You can use this to change the orientation. Select Layout Screens DSI-1 Orientation and select your orentation. To rotate by 180°, click on Inverted. Then go to Layout Screens DSI-1 Touchscreen and select your touchscreen. Only now save it by clicking on Apply. The change will then become visible and you have 10 seconds to confirm it by clicking on OK. Then close the program with Close. The start information on the text console is not changed by the setting.
je ne voit pas config Tool ni touchscreen même avec la traduction je ne voit pas d'écran je ne sais donc pas ou cela se trouve.
peut être que c'est dans la version 1.4.15 que je n'arrive pas a mètre a jour
et jai fait apt-get update et upgrade la 2 jours
possible de sauvegarder les fichiers importer dessus et les configurations de mon imprimante ?
update/upgrade linux can break installation when some packages get updated to new versions with different behavior. Especially pi cam is here broken I guess.
j'ai réinstaller repetier server sur le raspberry
mais quand je fait restaurer
sa bloque à 11.7% pendant 30min sa bouge pas
https://gyazo.com/e23bd012fd7a26a0a63491742e72a864
As the image shows the restore was aborted. Did you do that or did it happen automatically? If you check troubleshooting in server does it show any problems? Does disk have enough free space to store the files plus to uncompress them?
https://gyazo.com/af6132ded95b17b97239b819f59bc8cb
