Trying to install input shaper
edited February 2024 in Questions & Answers
Hi i updated klipper in repetier-server. Then i tried to install the input shaper and got an error.
what to do now? i never installed input shaper before but now i have an adxl345 accelerometer
Version: v0.12.0-111-g4f00f219
  Linking out/klipper.elf
/usr/bin/ld: out/src/sensor_adxl345.o: in function `command_query_adxl345':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_adxl345.c:124: undefined reference to `sensor_bulk_reset'
/usr/bin/ld: out/src/sensor_adxl345.o: in function `command_query_adxl345_status':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_adxl345.c:143: undefined reference to `sensor_bulk_status'
/usr/bin/ld: out/src/sensor_adxl345.o: in function `adxl_query':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_adxl345.c:97: undefined reference to `sensor_bulk_report'
/usr/bin/ld: /opt/klipper/ENDER3V_KLIPPER/src/sensor_adxl345.c:97: undefined reference to `sensor_bulk_report'
/usr/bin/ld: out/src/sensor_angle.o: in function `command_query_spi_angle':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_angle.c:232: undefined reference to `sensor_bulk_reset'
/usr/bin/ld: out/src/sensor_angle.o: in function `angle_check_report':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_angle.c:82: undefined reference to `sensor_bulk_report'
/usr/bin/ld: /opt/klipper/ENDER3V_KLIPPER/src/sensor_angle.c:82: undefined reference to `sensor_bulk_report'
/usr/bin/ld: out/src/sensor_mpu9250.o: in function `command_query_mpu9250':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_mpu9250.c:132: undefined reference to `sensor_bulk_reset'
/usr/bin/ld: out/src/sensor_mpu9250.o: in function `command_query_mpu9250_status':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_mpu9250.c:161: undefined reference to `sensor_bulk_status'
/usr/bin/ld: out/src/sensor_mpu9250.o: in function `mp9250_query':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_mpu9250.c:102: undefined reference to `sensor_bulk_report'
/usr/bin/ld: out/src/sensor_lis2dw.o: in function `command_query_lis2dw':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_lis2dw.c:123: undefined reference to `sensor_bulk_reset'
/usr/bin/ld: out/src/sensor_lis2dw.o: in function `command_query_lis2dw_status':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_lis2dw.c:136: undefined reference to `sensor_bulk_status'
/usr/bin/ld: out/src/sensor_lis2dw.o: in function `lis2dw_query':
/opt/klipper/ENDER3V_KLIPPER/src/sensor_lis2dw.c:93: undefined reference to `sensor_bulk_report'
collect2: error: ld returned 1 exit status
make: *** [Makefile:72: out/klipper.elf] Error 1
Installing klipper-mcu service over systemd
Created symlink /etc/systemd/system/multi-user.target.wants/klipper-mcu.service -> /lib/systemd/system/klipper-mcu.service.
  • Installing bleeding edge I could reproduce it. Seems it now needs one more option to compile and link.
    I have fixed it in the klipper installer so please rerun install input shaper. Should now work again.
  • Very sexy! It works. Thank you very much. Have a great weekend!
