Why is dbus-org.freedesktop.timedate1 started so frequently?
syslog:
... Mar 23 00:00:33 Repetier-Server dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.32358' (uid=0 pid=19311 comm="timedatectl ") Mar 23 00:00:33 Repetier-Server systemd[1]: Starting Time & Date Service... Mar 23 00:00:33 Repetier-Server dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.timedate1' Mar 23 00:00:33 Repetier-Server systemd[1]: Started Time & Date Service. Mar 23 00:01:03 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded. Mar 23 00:01:35 Repetier-Server dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.32363' (uid=0 pid=19451 comm="timedatectl ") Mar 23 00:01:35 Repetier-Server systemd[1]: Starting Time & Date Service... Mar 23 00:01:36 Repetier-Server dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.timedate1' Mar 23 00:01:36 Repetier-Server systemd[1]: Started Time & Date Service. Mar 23 00:02:06 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded. Mar 23 00:02:38 Repetier-Server dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.32368' (uid=0 pid=19595 comm="timedatectl ") Mar 23 00:02:38 Repetier-Server systemd[1]: Starting Time & Date Service... Mar 23 00:02:38 Repetier-Server dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.timedate1' Mar 23 00:02:38 Repetier-Server systemd[1]: Started Time & Date Service. Mar 23 00:03:08 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded. Mar 23 00:03:40 Repetier-Server dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.32373' (uid=0 pid=19737 comm="timedatectl ") Mar 23 00:03:40 Repetier-Server systemd[1]: Starting Time & Date Service... Mar 23 00:03:41 Repetier-Server dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.timedate1' Mar 23 00:03:41 Repetier-Server systemd[1]: Started Time & Date Service. Mar 23 00:04:11 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded. Mar 23 00:04:43 Repetier-Server dbus-daemon[390]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.32378' (uid=0 pid=19879 comm="timedatectl ") Mar 23 00:04:43 Repetier-Server systemd[1]: Starting Time & Date Service... Mar 23 00:04:43 Repetier-Server dbus-daemon[390]: [system] Successfully activated service 'org.freedesktop.timedate1' Mar 23 00:04:43 Repetier-Server systemd[1]: Started Time & Date Service. Mar 23 00:05:13 Repetier-Server systemd[1]: systemd-timedated.service: Succeeded. ...
In my research I found someone who had mentioned this:
It turns out that a configuration management system was calling
timedatectl
every ~10 minutes in order to check the current timezone.This calls
timedate1
over DBUS to get the answer, which only activates on incoming messages.with this content:
after restart it stops adding lines with these text in message.
Dave
Dave
