Ender3 S1 Pro and progress status issus
Hi there, i print with success on my Ender3 S1 PRO but the printing progress status is not available on the display: it's stuck on 0% with no ETA for all the printig time. Is there any configuration i must to set up on repetier server? I've noticed also that the home command perform in different way when lounched form repetier, so maybe am i using a wrong configuration? I've setted marlin firmware on the setup.
Thank's in advance
Thank's in advance
M117 Hello
do you see that at same position? Then info comes from server sending M117 with layer/eta/...
If not it comes likely from M73
https://marlinfw.org/docs/gcode/M073.html
so check if sending it changes display and check print log if we send it.
If M115 returns
With M115 i got
Maybe my display is not supported? It's a touch display.
