Connection problem after upgrading to 0.70
I have two equal printers with motherboard Andciv CM3E 3D. I had problems with connection also with server version 0.65 but after installing new Windows 7 computer I almost get rid of those problems. Sometimes still the connection broke after 2-3h printing time.
I installed new server version 0.70 and now the symptoms got much worse. After starting a new job, printer stops in few seconds without any information in log file. Server keeps "green" but cannot control the printer (for example "move" commands do not have any effect). If I disconnect usb cable and reconnect connection becomes back.
I have tried with different baud rates but it doesn't help. 115200 and 76800 seem to function best in version 0.65. Also tried larger buffer and communication timeout (90) Have to mention that on printers side the baud rate seem to be 100.000. Motherboard always resets baud to this after booting the printer. Repetier Server doesn't have this baudrate option in baud rate list. However I tried to change the baud rate to 100000 manually in configuration file but couldn't get any contact to the printer.
This connection problem must be some kind of compatibility issue between Repetier Server and my motherboard. I don't have any connection issues with other software (for example Simplify 3D).
Otherwise I love concept of Repetier Server if I just could achieve trusted connection. I hope we could solve this problem somehow.
Got same pb here with raspberry b2 and v 0.70
Erratic behavior.
Logs show comm links errors mis match Checksum.
I want to revert to 0.65 but can t find the software anymore on repetier server download home page...
