If it can't be removed, is there anyway to downgrade to an earlier version? i do indeed regret to have updated version..
For anyone wanting the same, an adblocker can be used to remove the animation, use the custom settings and hide: ##lottie-player[class*="hidden-sm-500"]
But only works on devices able to run adblocker etc.
We can not modify the software for personal likes/dislikes. There is always someone dissatisfied, sorry.
However, you can replace the lottie file in www/img/lottie with a empty animation if you want to disable it without adblocker. In pro version you can do it in shadow directory (see docs for branding on homepage) so it even survives updates.
Understanderable, but its still awfull to look at, sorry, we have monitors in the printfarm room, and the running animation is very distractive when its moving all the time. Even when we remove the lottie from the filestructure, we do not get a full widt login page.
please considering makeing a on/off switch in the settings page for enabling / disabling the lottie, if it cant be done, we will unfortunately consider looking for other software.
You are the best! really appreciate it! in generally we are really happy with repetier!
