Video stream is very choppy
I'm using Repetier-Server Pro on a Raspberry Pi. the webcam stream was running fine for a while. I have 2 printer and 2 webcams. Now it is very choppy and I'm not sure where to look. Can anyone help?
  • It is normally a question of bandwith vs. webcam image size and frames per second. If you have a pi connected over wifi with 1920x1080px and 30fps this can not be transferred with not perfect wifi. Reduce e.g. framerate to 5fps then and see if it improves.
  • Well, you can accelerate hardware resources which can help you with video encoding and decoding very easily, in conclusion, it will help you in fine streaming.
