Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Edit a server command
joule5
July 2023
in
Repetier-Server
Can you provide the path to extcommands.xml in the "database subdirectory inside your storage directory" for raspberry pi image?
Repetier
July 2023
/var/lib/Repetier-Server/database contains the file on a pi.
joule5
July 2023
Ok found it. Thanks. I was expecting to find whats happening when I press autolevel. I was looking for server command
@buttoncommand
autolevel.
joule5
August 2023
Where do I find
@buttoncommand
autolevel?
Repetier
August 2023
Button commands are in printer settings->G-Codes->Button Commands and can be edited inside the gui.
Sign In
or
Register
to comment.
