Any trick to send gcode simultaneously to all printers connected to server ?
Hi all !
all is in the title , i am wondering if there's any simple way to run a gcode over all the printers connected to the server.
gcodes like preheat, or led on or off all sort of simple stuff like that.
That could be very handy when you run more than 10 same printers on a server.
Thanks !
Thanks !
@sendToPrinter slug command
Sends command to the printer with given slug name. That way you can execute command sin the context of another printer. Note that command and all command parameter get parsed first in your printer context, so outer quotes get removed and computed expressions get executed. Escape them if that is not wanted accordingly.
@func all cmd
@sendToPrinter a {{local.cmd}}
@sendToPrinter b {{local.cmd}}
@sendToPrinter c {{local.cmd}}
@endfunc
Put this in event dependent activate script, deactivate and activate so it gets run. On restart of server it start automatically if printer is activated.
Now you can run
@call all G28
to home all 3 printers.
You can also make a own dialog with most often used parallel commands to be lazy.
I simply cant find where to put susc a function. where do i write and save this function?
No where to save functions server sided?
