error taking snapshot:Net Exception
Hello,
my server.log is flooded with these messages.
When printing with Repetier-Server (Raspberry Pi 4), there is also lots of layer-shift which is not, if I print via SD-Card directly on my Ultimaker2+
I think because of these messages, the CPU of the Raspy may have errors communicating with my Ultimaker2+
Could this be possible ?
Layer shift is probably an other issue, also server has normally no influence on it. We just send the gcodes and printer would ensure that all moves are within limits the printer can handle meaning acceleration, speed etc are limited by printer or set from gcode you created and we just had send as requested. Layer shift has normally a physical reason:
- especially if always away from end stop it is cross talk on end stop sensor causing a move to stop early.
- random shift: Motor force exceeded either from hitting a plastic part, acceleration/speed to high loosing steps, overheat so motor disabled a short while.
- moves outside limits, e.g. timelapse configured with making snapshots outside move area. Check settings or disable webcam.
To see if communication had issues enable logging and watch afterwards for words like: timeout, resend
These appear if communication goes wrong, but since send gcode is checksum protected wrong commands get corrected and not executed.
Well, after days of experimenting I found the problem : Repetier-Server chocked after printing for a while and therefore skipped some commands, resulting in a layer shift. Enabling PingPong solved that problem.
Shouldn´t Repetier-Server have told me that he skipped some commands ?
But as said in first place it should not timeout so question is what was causing it so I can check if it is in the slow command list to improve on extending timeout in that case.
