Terminal closes immediately
I just tried installing Repetier-server 1.4.9 and when I do the Klipper install or go to Global Settings > Terminal it immediatly closes and doesn't seem to finish running the Klipper setup.
Image of the terminal: https://imgur.com/a/FgdLX3O
Logs: https://pastebin.com/S1BFfiac
  • Fixed it, ended up being I was missing wget and sudo packages, as well as needing to run apt --fix-broken install
