Error in orangepi lite with camera
Hi! Today i upgrade an orangepi lite from debian from oldstable to stable. After it i can not see camera (In oldstable debian i installed mjpg software manual).
Welcome to ARMBIAN 5.73 stable Debian GNU/Linux 11 (bullseye) 5.10.60-sunxi
https://imgur.com/a/K2KpQyluser@orangepilite:~$ lsusb
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1d50:6029 OpenMoko, Inc. Marlin 2.0 (Serial)
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hubIn settings web-camera i can see it but it is no way to silect:
I think that for manual installing i use the script:
https://github.com/ogra1/mjpg-streamercat /var/snap/mjpg-streamer/current/config
INPUTOPTS="input_uvc.so -d /dev/video0"
PORT="-p 8081"
DAEMON="true"
#mjpg-streamer -i "input_uvc.so -d /dev/video4" -o "output_http.so"
So you should check if mjpg_streamer is running:
ps aux | grep mjpg
If none is running these entries are just shown because you had them reported. But you need to find out why mjpg_streamer is not working any more. Maybe they are linked agains libraries not existent on the newer os so you need to recompile streamer. Try starting them in ssh console manually to see errors.
https://www.repetier-server.com/setting-webcam-repetier-server-linux/
user 2841 0.0 0.1 6860 536 pts/0 S+ 18:07 0:00 grep mjpg
I repeat commands from the link. It works OK! Thx!
