Include other Instances of Repetier Server in Dashboard
Is it possible to add other instances of Repetier server to the dashboard. I know that Repetier monitor exists, but it's real clunky compared to the browser experience, and does not work on IOS. Or is it possible to run Repetier monitor on a server and use it over the browser?
  • Monitor is the only solution, but it only works as app on desktop os, sorry. Monitor is also not a pure web app - it uses also a node backend connected via electron, so remotely it would not work.
