Problems with extcommands.xml on 0.65.0 on Raspberry Pi
I'm having trouble getting extcommands.xml on 0.65.0 on Raspberry Pi to work.
At this point I'm just trying to get any command to show up in the menu at all.
I've take the example directly from the manual and I think I have everything setup correctly. At first I was unsure server was actually reading the file but to confirm, I broke the XML and then on RepetierServer restart, I see errors in the server.log so I know the file is being picked up.
No matter what I do, I can't see any new options in any menu....  Maybe I don't know where to look.
I'm assuming that I'd see new menu options in the hamburger menu beside the direct print button. Am I looking in the wrong place?
Can someone confirm this is working for them on 0.65.0 on Pi?
Thanks,
Mark.
  • It is working. The commands appear in the menu next the language flag with the gear.
    Your hamburger comment reminds me that I wanted to do this on a per printer basis as well. Need to check that.
  • Now that I know where to look everything seems fine.
    I'll add a 'yes please' for a feature to a do this on a per printer basis.
    Thanks again,
    Mark.
