Printer Information isn't displayed
I've tried Repetier (client, both tar and AppImage) for Linux and in both versions the Printer Information window (Alt+I) is not displayed properly. It hangs and block further normal app usage. The window is created, it has a title, but the content isn't drawn - it contains a piece of underlying window . E.g. its paint routine down't overdraw the window canvas. I also can't close this window as it doesn't have a close button.
No errors is printed to console or log during that.
I'm trying to display the window just after printer connection. My log just before I press Alt+I is following:
19:18:31.403 : OpenGL renderer:Mesa DRI Intel(R) HD Graphics 4000 (IVB GT2)
19:18:31.407 : Using fast VBOs for rendering is possible
19:18:35.862 : Printer reset detected - initializing
19:18:35.875 : start
19:18:35.875 : echo:Marlin1.0.0
19:18:35.877 : echo: Last Updated: Feb 15 201913_11_2018 13:27:42 | Author: (MC7,PrimeMiniV2)
19:18:35.877 : Compiled: Feb 15 2019
19:18:35.878 : echo: Free Memory: 3762 PlannerBufferBytes: 1232
19:18:35.878 : echo:Hardcoded Default Settings Loaded
19:18:35.880 : echo:Steps per unit:
19:18:35.884 : echo: M92 X80.00 Y80.00 Z4000.00 E96.00
19:18:35.889 : echo:Maximum feedrates (mm/s):
19:18:35.889 : echo: M203 X500.00 Y500.00 Z5.00 E25.00
19:18:35.891 : echo:Maximum Acceleration (mm/s2):
19:18:35.895 : echo: M201 X9000 Y9000 Z100 E9000
19:18:35.900 : echo:Acceleration: S=acceleration, T=retract acceleration
19:18:35.904 : echo: M204 S2000.00 T2000.00
19:18:35.920 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
19:18:35.925 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
19:18:35.925 : echo:Home offset (mm):
19:18:35.929 : echo: M206 X0.00 Y0.00 Z0.00
19:18:35.929 : echo:PID settings:
19:18:35.932 : echo: M301 P26.04 I3.68 D46.07
19:18:36.036 : N1 M110*34
19:18:36.036 : N2 M115*36
19:18:36.036 : N4 M114*35
19:18:36.036 : N5 M111 S6*98
19:18:36.041 : N6 T0*60
19:18:36.042 : N7 M80*28
19:18:39.398 : echo:SD init fail
19:18:39.398 : ok
19:18:39.444 : N10 M220 S100*80
19:18:39.446 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/ErikZalm/Marlin/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:MC7PrimeMiniV2 EXTRUDER_COUNT:1 UUID:13_11_2018__2
19:18:39.446 : ok
19:18:39.446 : N11 M221 S100*80
19:18:39.481 : N12 M111 S6*84
19:18:39.483 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
19:18:39.483 : ok
19:18:39.483 : ok
19:18:39.483 : echo:Active Extruder: 0
19:18:39.484 : ok
19:18:39.484 : N13 T0*8
19:18:39.484 : ok
19:18:39.485 : ok
19:18:39.485 : ok
19:18:39.487 : ok
19:18:39.491 : echo:Active Extruder: 0
19:18:39.491 : ok
Could you at least add a close button to the window title of this window, so it can be safely closed?19:18:31.407 : Using fast VBOs for rendering is possible
19:18:39.398 : ok
19:18:39.446 : ok
19:18:39.483 : ok
19:18:39.483 : ok
19:18:39.484 : ok
19:18:39.484 : ok
19:18:39.485 : ok
19:18:39.485 : ok
19:18:39.487 : ok
19:18:39.491 : ok
Appimage or tar file?
