Annoying Printer Notifications
First of all - Great work guys, Repetier is coming along nicely.
Just want to bring up an issue I am getting, printer notifications(messages) that pop up in the web interface and there does not seem a way to acknowledge them or remove them after they pop up. They stay on the screen until one reboots the server !
Is this a Bug ? Or is there a not obvious way to remove he message window that pops up ? Any help will be appreciated.
Cheers from Downunder ! from the land of OZ!
Torerro22
Torerro22
Repetier-Server Pro 1.2.1 - Pan-49 ruinning on a Raspberry pi.
Iam just using the web interface, Which I guess is just the webser running on your repetier server.
The msg says the follwoing :
"Message from your Printer
UI Abort
Note: When printer is blocking and communicating buffers are full answers might not be executed ! "
This pops up and can't be closed off. you can move it arround and that is it.
Cheers
Torero22
As intermediate solution add a new quick command with the content:
@dialogHideAll
this will close the message and continue.
