Camera control settings
I think it is very easy to implement this using "v4l2-ctl".
Example, from shell without sudo this is the output of "v4l2-ctl --all" of my cam:
pi@Raspberry1:~ $ v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : UVC Camera (046d:0825)
Bus info : usb-3f980000.usb-1.4
Driver version: 4.19.66
Capabilities : 0x84A00001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1280/960
Pixel Format : 'MJPG'
Field : None
Bytes per Line : 0
Size Image : 1632000
Colorspace : sRGB
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1280, Height 960
Default : Left 0, Top 0, Width 1280, Height 960
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1280, Height 960
Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 960
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 15.000 (15/1)
Read buffers : 0
brightness (int) : min=0 max=255 step=1 default=128 value=128
contrast (int) : min=0 max=255 step=1 default=32 value=32
saturation (int) : min=0 max=255 step=1 default=32 value=32
white_balance_temperature_auto (bool) : default=1 value=1
gain (int) : min=0 max=255 step=1 default=64 value=192
power_line_frequency (menu) : min=0 max=2 default=2 value=2
white_balance_temperature (int) : min=0 max=10000 step=10 default=4000 value=8000 flags=inactive
sharpness (int) : min=0 max=255 step=1 default=24 value=24
backlight_compensation (int) : min=0 max=1 step=1 default=0 value=0
exposure_auto (menu) : min=0 max=3 default=3 value=3
exposure_absolute (int) : min=1 max=10000 step=1 default=166 value=417 flags=inactive
exposure_auto_priority (bool) : default=0 value=1
With the command "v4l2-ctl --list-ctrls-menus" only the list of possible editable controls appears.
If I want to change the contrast, for example, I just need to ask this: v4l2-ctl --set-ctrl brightness=10
It would therefore be interesting if from the interface, perhaps with sliders, I could change everything that is possible, without going through mjpg-streamer.
Really nice, thanks!
v4l2-ctl --set-ctrl=power_line_frequency=2
v4l2-ctl --set-ctrl=exposure_auto=1
v4l2-ctl --set-ctrl=exposure_absolute=80
