Stopped connecting to Server
Suddenly host has stopped connecting to server "Could not connect to server.  Check IP......"
I can connect via browser and control printer so there is no network issue.  Uninstalled and reinstalled Host.
Windows 10.  Raspberry Pi server.  Standard home wifi.  Thanks.
  • The way you describe it, it should work. Unless e.g. firewall/virus scanner blocks that communication or you made a change like different api key, new server ip or port.
  • I can connect via browser from same computer that is running Host.  I did get a new API key AFTER problem started.  Rebooted host computer and server.  What else can I try?
  • Weird.  Suddenly started working!!  I hate these glitches with no idea what happened.
