When printing from SD, my Prusa MK3s’s randomly stop
Hello everyone ,
maybe my topic is obvious , but I could not find an entry pointing to this issue.
In my makerspace, I have 4 Prusa MK3s connected to a Intel NUC running Repetier Server on Ubuntu. The printers are connected on the NUC 4 USB ports.
Sometimes we want to print from SD instead of from Repetier (this occurs especially when we have guest people or students making prints). I observed that very frequently, a print started from the SD card would just randomly stop. Unplug the USB cable from the printer, the problem is gone.
So it seems pretty much USB related.
Note: it never occurred to me as I was using Octoprint (and there were 3 printers connected on the server).
I understand Repetier server is meant to manage the printers without SD cards. But if it doesn’t allow to do prints from an SD card, it might not be the right option for my makerspace... that would be too bad, because I really like the software and was seriously considering getting the Premium version.
Thanks to everyone who has any ideas related to this issue!
Francesco
Francesco
As long as no one tries to print over the server sd prints should be ok since we don't send gcodes that influence prints.
Another point is does server reconnect usb? If so why? That would reset the prusa but as long as no one restarts server that should also be no issue.
2021-04-15 14:32:47: Port closed for Prusa MK3S 3 - Doris
2021-04-15 14:32:47: Connection closed: Prusa MK3S 3 - Doris
2021-04-15 14:32:48: Connection started: Prusa MK3S 3 - Doris
2021-04-15 14:32:48: Reset printer Prusa MK3S 3 - Doris
2021-04-15 14:40:22: Port closed for Prusa MK3S 3 - Doris
2021-04-15 14:40:22: Connection closed: Prusa MK3S 3 - Doris
2021-04-15 14:40:23: Connection started: Prusa MK3S 3 - Doris
2021-04-15 14:40:23: Reset printer Prusa MK3S 3 - Doris
2021-04-15 15:03:57: Port closed for Prusa MK3S 3 - Doris
2021-04-15 15:03:57: Connection closed: Prusa MK3S 3 - Doris
2021-04-15 15:03:58: Connection started: Prusa MK3S 3 - Doris
2021-04-15 15:03:58: Reset printer Prusa MK3S 3 - Doris
2021-04-15 16:35:50: Port closed for Prusa MK3S 1 - Maurice
2021-04-15 16:35:50: Connection closed: Prusa MK3S 1 - Maurice
2021-04-15 16:35:51: Connection started: Prusa MK3S 1 - Maurice
2021-04-15 16:35:51: Reset printer Prusa MK3S 1 - Maurice
2021-04-15 16:42:15: error: Reading serial conection failed: End of file. Closing connection.
2021-04-15 16:42:15: Port closed for Prusa MK3S 1 - Maurice
2021-04-15 16:42:15: Connection closed: Prusa MK3S 1 - Maurice
2021-04-15 16:43:08: error: Reading serial conection failed: End of file. Closing connection.
2021-04-15 16:43:08: Port closed for Prusa MK3S 3 - Doris
2021-04-15 16:43:08: Connection closed: Prusa MK3S 3 - Doris
means linux did close the port. Can be because you removed usb manually or because there were power problems and linux did disconnect. But since you said using repetier you have no problems I do not think it is power problem.
The interesting part might be
why was it closed here as it reconnected directly.
Apart from this server.log does not contain any informations. You need to enable logging for printer when not printing in printer menu. This will start writing to connected.log when not printing after next start or after next regular print. So there you would see if something happened that made server close a connection.
Recv:17:19:31.579: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
Recv:17:19:33.267: echo:busy: processing
Recv:17:19:35.331: echo:busy: processing
Recv:17:19:37.395: echo:busy: processing
Recv:17:19:39.927: echo:busy: processing
Recv:17:19:41.995: echo:busy: processing
Recv:17:19:44.064: echo:busy: processing
Recv:17:19:46.133: echo:busy: processing
Recv:17:19:48.205: echo:busy: processing
Recv:17:19:50.302: echo:busy: processing
Recv:17:19:52.375: echo:busy: processing
Recv:17:19:53.313: NORMAL MODE: Percent done: 0; print time remaining in mins: 16
Recv:17:19:53.321: SILENT MODE: Percent done: 0; print time remaining in mins: 16
Recv:17:19:53.363: ok T:215.0 /215.0 B:60.7 /60.0 T0:215.0 /215.0 @:33 B@:0 P:31.3 A:42.6
Send:17:19:53.363: N162 M105
Recv:17:19:53.371: ok T:215.0 /215.0 B:60.7 /60.0 T0:215.0 /215.0 @:33 B@:0 P:31.3 A:42.6
Send:17:19:53.371: N163 M105
Recv:17:19:53.375: ok T:215.0 /215.0 B:60.7 /60.0 T0:215.0 /215.0 @:33 B@:0 P:31.3 A:42.6
Recv:17:19:53.383: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:19:53.383: Resend: 62
Recv:17:19:53.383: Ignore due to resend: ok
Recv:17:19:53.383: Ignore due to resend: Unknown G code: G21
Send:17:19:53.466: Resend: N62 M105
Recv:17:19:55.595: echo:busy: processing
Recv:17:19:57.659: echo:busy: processing
Recv:17:19:59.334: echo:Advance K=0.05
Recv:17:19:59.335: E/D=Auto
Recv:17:19:59.339: echo:Advance K=30.00
Recv:17:19:59.339: E/D=Auto
Recv:17:19:59.343: Full RX Buffer
Recv:17:19:59.417: NORMAL MODE: Percent done: 1; print time remaining in mins: 16
Recv:17:19:59.421: SILENT MODE: Percent done: 0; print time remaining in mins: 16
Recv:17:19:59.433: NORMAL MODE: Percent done: 1; print time remaining in mins: 16
Recv:17:19:59.441: SILENT MODE: Percent done: 1; print time remaining in mins: 16
Mesg:17:20:01.671: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:01.671: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:01.671: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:01.671: Resend: N63 M105
Recv:17:20:04.295: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:04.295: Resend: 62
Recv:17:20:04.295: Ignore due to resend: ok
Send:17:20:04.378: Resend: N62 M105
Recv:17:20:05.466: Full RX Buffer
Mesg:17:20:08.395: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:08.395: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:08.395: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:08.395: Resend: N63 M105
Recv:17:20:09.149: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:09.149: Resend: 62
Recv:17:20:09.149: Ignore due to resend: ok
Send:17:20:09.233: Resend: N62 M105
Recv:17:20:10.357: Full RX Buffer
Recv:17:20:10.902: NORMAL MODE: Percent done: 1; print time remaining in mins: 16
Recv:17:20:10.910: SILENT MODE: Percent done: 2; print time remaining in mins: 16
Recv:17:20:10.980: NORMAL MODE: Percent done: 2; print time remaining in mins: 16
Recv:17:20:10.984: SILENT MODE: Percent done: 2; print time remaining in mins: 16
Mesg:17:20:13.250: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:13.250: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:13.250: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:13.250: Resend: N63 M105
Recv:17:20:13.266: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:13.266: Resend: 62
Recv:17:20:13.266: Ignore due to resend: ok
Send:17:20:13.350: Resend: N62 M105
Recv:17:20:13.675: Full RX Buffer
Recv:17:20:16.494: NORMAL MODE: Percent done: 3; print time remaining in mins: 16
Recv:17:20:16.497: SILENT MODE: Percent done: 2; print time remaining in mins: 16
Recv:17:20:16.506: NORMAL MODE: Percent done: 3; print time remaining in mins: 16
Recv:17:20:16.510: SILENT MODE: Percent done: 3; print time remaining in mins: 16
Mesg:17:20:17.360: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:17.360: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:17.360: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:17.360: Resend: N63 M105
Recv:17:20:18.582: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:18.583: Resend: 62
Recv:17:20:18.583: Ignore due to resend: ok
Send:17:20:18.666: Resend: N62 M105
Recv:17:20:19.393: Full RX Buffer
Mesg:17:20:22.677: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:22.677: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:22.678: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:22.678: Resend: N63 M105
Recv:17:20:22.875: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:22.879: Resend: 62
Recv:17:20:22.879: Ignore due to resend: ok
Send:17:20:22.963: Resend: N62 M105
Recv:17:20:23.846: Full RX Buffer
Mesg:17:20:26.975: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:26.975: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:26.975: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:26.975: Resend: N63 M105
Recv:17:20:26.992: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:26.992: Resend: 62
Recv:17:20:26.992: Ignore due to resend: ok
Recv:17:20:27.000: Ignore due to resend: NORMAL MODE: Percent done: 4; print time remaining in mins: 16
Recv:17:20:27.004: Ignore due to resend: SILENT MODE: Percent done: 3; print time remaining in mins: 16
Recv:17:20:27.012: Ignore due to resend: NORMAL MODE: Percent done: 4; print time remaining in mins: 16
Recv:17:20:27.020: Ignore due to resend: SILENT MODE: Percent done: 4; print time remaining in mins: 16
Send:17:20:27.083: Resend: N62 M105
Recv:17:20:28.110: Full RX Buffer
Mesg:17:20:31.103: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:31.104: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:31.104: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:31.104: Resend: N63 M105
Recv:17:20:31.710: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:31.711: Resend: 62
Recv:17:20:31.711: Ignore due to resend: ok
Send:17:20:31.793: Resend: N62 M105
Recv:17:20:34.291: Full RX Buffer
Recv:17:20:35.647: NORMAL MODE: Percent done: 5; print time remaining in mins: 16
Recv:17:20:35.651: SILENT MODE: Percent done: 4; print time remaining in mins: 16
Recv:17:20:35.659: NORMAL MODE: Percent done: 5; print time remaining in mins: 16
Recv:17:20:35.663: SILENT MODE: Percent done: 5; print time remaining in mins: 16
Mesg:17:20:35.807: Warning: Communication timeout - resetting communication buffer.
Mesg:17:20:35.807: Connection status: Buffered:12, Manual Commands: 1, Job Commands: 0
Mesg:17:20:35.807: Buffer used:12 Enforced free byte:0 lines stored:1
Send:17:20:35.807: Resend: N63 M105
Recv:17:20:37.031: Error:Line Number is not Last Line Number+1, Last Line: 61
Recv:17:20:37.035: Resend: 62
Mesg:17:20:37.036: Receiving only error messages. Reset communication for printer Prusa MK3S 1 - Maurice.
Recv:17:20:37.038: Response while unconnected:ok
Recv:17:20:37.041: ok
Mesg:17:20:38.042: Dtr: true Rts: true
Mesg:17:20:38.042: Connection started
Mesg:17:20:38.042: Dtr: false Rts: false
Mesg:17:20:38.063: Dtr: true Rts: true
Send:17:20:38.074: N1 M105
Send:17:20:39.078: N2 M105
Recv:17:20:39.109: start
Send:17:20:39.110: N1 M110
Send:17:20:39.110: N2 M105
Send:17:20:39.110: N3 M115 ; Get firmware capabilities and info
Send:17:20:39.110: N4 M220 S100 ; Speed multiplier 100%
Send:17:20:39.110: N5 M221 S100 ; Flow multiplyer 100%
Send:17:20:39.110: N6 G92 E0
Send:17:20:39.111: N7 G90
Send:17:20:39.111: N8 M82
Recv:17:20:39.112: echo: 3.8.1-2869
Recv:17:20:39.121: echo: Last Updated: Oct 24 2019 17:11:58 | Author: (none, default config)
Recv:17:20:39.121: Compiled: Oct 24 2019
Recv:17:20:39.129: echo: Free Memory: 2123 PlannerBufferBytes: 1392
Recv:17:20:39.129: echo:Stored settings retrieved
Recv:17:20:39.133: adc_init
Recv:17:20:39.473: CrashDetect ENABLED!
Recv:17:20:40.558: FSensor ENABLED
Recv:17:20:41.373: echo:busy: processing
Recv:17:20:43.593: echo:busy: processing
Recv:17:20:45.756: echo:busy: processing
Recv:17:20:46.883: Error:No Line Number with checksum, Last Line: 0
Recv:17:20:46.887: Resend: 1
Recv:17:20:46.887: Ignore due to resend: ok
Send:17:20:46.970: Resend: N1 M110
Recv:17:20:46.997: ok
Send:17:20:46.997: Resend: N2 M105
Recv:17:20:47.006: ok T:212.1 /0.0 B:60.0 /0.0 T0:212.1 /0.0 @:0 B@:0 P:35.3 A:41.9
Send:17:20:47.006: Resend: N3 M115 ; Get firmware capabilities and info
Recv:17:20:47.030: FIRMWARE_NAME:Prusa-Firmware 3.8.1 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv:17:20:47.031: ok
Send:17:20:47.031: Resend: N4 M220 S100 ; Speed multiplier 100%
Recv:17:20:47.034: ok
Send:17:20:47.034: Resend: N5 M221 S100 ; Flow multiplyer 100%
Recv:17:20:47.038: ok
Send:17:20:47.038: Resend: N6 G92 E0
Recv:17:20:47.042: ok
Send:17:20:47.042: Resend: N7 G90
Recv:17:20:47.046: ok
Send:17:20:47.046: Resend: N8 M82
Send:17:20:47.047: N9 G21 ; Use mm as unit
Send:17:20:47.047: N10 M114
Send:17:20:47.047: @getip
Send:17:20:47.049: N11 M105
Send:17:20:47.049: M117 192.168.1.8:3344
Send:17:20:47.049: N12 M105
Recv:17:20:47.050: ok
Recv:17:20:47.055: Unknown G code: $9 G21
Recv:17:29:33.330: ok T:209.2 /0.0 B:59.9 /0.0 T0:209.2 /0.0 @:0 B@:0 P:38.6 A:41.2
Send:17:29:34.322: N17 M105
Recv:17:29:34.334: ok T:208.4 /0.0 B:59.8 /0.0 T0:208.4 /0.0 @:0 B@:0 P:38.6 A:41.4
Send:17:29:35.315: @getip
Send:17:29:35.318: M117 192.168.1.8:3344
Send:17:29:35.318: N18 M105
Recv:17:29:35.325: ok
Recv:17:29:35.329: ok T:207.5 /0.0 B:59.8 /0.0 T0:207.5 /0.0 @:0 B@:0 P:38.7 A:41.5
Send:17:29:36.330: N19 M105
Recv:17:29:36.341: ok T:206.7 /0.0 B:59.7 /0.0 T0:206.7 /0.0 @:0 B@:0 P:38.7 A:41.2
Send:17:29:37.333: N20 M105
Recv:17:29:37.344: ok T:206.4 /0.0 B:59.7 /0.0 T0:206.4 /0.0 @:0 B@:0 P:38.8 A:41.2
Send:17:29:38.337: N21 M105
Recv:17:56:47.290: Error:Line Number is not Last Line Number+1, Last Line: 1056
Recv:17:56:47.290: Resend: 1057
Recv:17:56:48.260: Full RX Buffer
Mesg:17:56:51.390: Warning: Communication timeout - resetting communication buffer.
Mesg:17:56:51.390: Connection status: Buffered:14, Manual Commands: 1, Job Commands: 0
Mesg:17:56:51.390: Buffer used:14 Enforced free byte:0 lines stored:1
Recv:17:56:51.406: Error:Line Number is not Last Line Number+1, Last Line: 1056
Recv:17:56:51.407: Resend: 1057
Recv:17:56:52.524: Full RX Buffer
Mesg:17:56:55.513: Warning: Communication timeout - resetting communication buffer.
Mesg:17:56:55.513: Connection status: Buffered:14, Manual Commands: 1, Job Commands: 0
Mesg:17:56:55.513: Buffer used:14 Enforced free byte:0 lines stored:1
Recv:17:56:56.121: Error:Line Number is not Last Line Number+1, Last Line: 1056
Recv:17:56:56.125: Resend: 1057
Recv:17:56:58.706: Full RX Buffer
Mesg:17:57:00.221: Warning: Communication timeout - resetting communication buffer.
Mesg:17:57:00.221: Connection status: Buffered:14, Manual Commands: 1, Job Commands: 0
Mesg:17:57:00.221: Buffer used:14 Enforced free byte:0 lines stored:1
Recv:17:57:01.446: Error:Line Number is not Last Line Number+1, Last Line: 1056
Recv:17:57:01.446: Resend: 1057
Mesg:17:57:01.447: Receiving only error messages. Reset communication for printer Prusa MK3S 1 - Maurice.
Recv:17:57:01.452: Response while unconnected:ok
Mesg:17:57:02.456: Dtr: true Rts: true
Mesg:17:57:02.456: Connection started
Mesg:17:57:02.456: Dtr: false Rts: false
Mesg:17:57:02.477: Dtr: true Rts: true
Recv:17:57:03.524: start
Recv:17:57:03.527: echo: 3.8.1-2869
Recv:17:57:03.535: echo: Last Updated: Oct 24 2019 17:11:58 | Author: (none, default config)
Recv:17:57:03.535: Compiled: Oct 24 2019
Recv:17:57:03.539: echo: Free Memory: 2123 PlannerBufferBytes: 1392
Recv:17:57:03.543: echo:Stored settings retrieved
Recv:17:57:03.547: adc_init
Recv:17:57:03.887: CrashDetect ENABLED!
Recv:17:57:04.973: FSensor ENABLED
Recv:17:57:05.194: echo:SD card ok
Recv:17:57:11.301: Error:No Line Number with checksum, Last Line: 0
Recv:17:57:11.302: Resend: 1
Recv:17:57:11.445: FIRMWARE_NAME:Prusa-Firmware 3.8.1 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv:17:57:11.469: Unknown G code: $9 G21
Recv:17:57:11.473: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 E:0.00
that is strange. It looks like it accepting M105 with line 162 and when sending line 163 prusa says last line was 61. Resends are taken as error so in the end server disconnects it, reconnects and resets prusa with this.
What is your communication settings in server - especially how big is the buffer that it fits 100 commands? I'm pretty sure prusa buffer only has 127 byte. For debugging the problem ping pong mode would be the best so you know to which command a "ok" response belongs to. Will also check if I can reproduce it on my prusa.
M117 in general is no problem. But it gets send without line number since older marlin versions could not handle it with line numbers or choked on checksum.
