Full RX Buffer
Hi All
I am struggeling with an error i haven't seen before. From the console it keeps writing Full RX Buffer
Am it has a lot of errors underway in the print aswell.
Full RX Buffer
Error: Line Number is not Last Line Number+1. Last Line: 24174
Resend: 24175
Error: Line Number is not Last Line Number+1. Last Line: 24175
Resend: 24176
It keeps writing this under way, and it lacks in middle of print, so printer just stops moving.
Hope you can help me. Cause this is a bit anoying.
Full RX Buffer
Resend: 24175
Resend: 24176
As a solution for such problems activating ping-pong mode normally solves it. Then only one command at a time is under way, which is the official way. But it is also the slower compared to our parallel send.
Yeah did see this with the MMU here you can see for the curently print i am making.
When this is done i will try to activate Ping-Pong mode.
