Problem installing RepetierHost 1.5.2
Hello,
I have a problem installing the soft Repetier Host 1.5.2...
I must install it on 2 PCs in my company and I managed to download the installer file, but our group policy blocks the download of the additional files (step 4 or 5 in the setup).
Is there any offline installer that I could use to install the soft ?
Thanks for answering my question.
  • You normally will not have skeinforge, so you can skip that.
    The server can be downloaded on www.repetier-server.com separately, so you can also omit that. Host works fine without.
    All other parts are directly included and need no download.
  • Thanks, it worked properly without the server installation.
  • I am running the latest version and a lot of the dependency files are broken or will not download
