Repetier Module - Response Handling
Hi, I was able to create a module that added a page and button to printer menu. I am able to call registered action and send a gcode command to printer. I am able to capture response on client but very stupid way. I registered response handler where i am testing for printer and response I am interested in. When there is a match I set a global variable. Using another registered action method I check this global variable and if it is set i return result. I am sure there is a better way how to achieve this. (just publish to RSCom on server and subscribe in angular controller somehow?). Thank you for any help/piece of code. Tom
Also inside a controller better use $scope.$on instead. If you bind to $rootScope you must unbind in destroy event or you will end up with multiple listeners!
