Camera not working with new Raspberry Pi4 Repetier-Server
Hello, everybody. So far, I used a Raspberry Pi 3 as a repetier-server and a webcam. Everything worked well. Now I have a new Raspberry Pi 4, installed the printer, etc. But the same webcam doesn't work on it anymore. I tried various USB connections, have "accessed" countless times, but I don't get a picture. What can I do?
  • Should not happen as it is same software or did you upgrade image version?
    Did you check if it was assigned a new port number?
    If you login you can check if it is running using
    ps aux | grep mjpg
    If you manually run
    sudo /usr/local/Repetier-Setup/bin/startAllCams
    you should see if there is an error in starting. If it does not run afterwards check syslog:
    tail -2000 /var/log/syslog
    mjpg streamer writes messages to this if it stops a webcam.
  • - I have on both raspberry the same software version.
    - Yes the port number I have checked.
    - the manual run command don't help
    - follow a part from my log:
    Apr 15 11:17:18 Repetier-Server1 dhclient[793]: DHCPREQUEST for 192.168.10.101 on eth0 to 255.255.255.255 port 67
    Apr 15 11:17:19 Repetier-Server1 dhclient[793]: DHCPACK of 192.168.10.101 from 192.168.10.1
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0328] dhcp4 (eth0):   address 192.168.10.101
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0328] dhcp4 (eth0):   plen 24 (255.255.255.0)
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0329] dhcp4 (eth0):   gateway 192.168.10.1
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0329] dhcp4 (eth0):   server identifier 192.168.10.1
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0330] dhcp4 (eth0):   lease time 86400
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0331] dhcp4 (eth0):   nameserver '192.168.10.1'
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0331] dhcp4 (eth0):   domain name 'localdomain'
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0331] dhcp (eth0):   domain search 'localdomain.'
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0332] dhcp4 (eth0): state changed unknown -> bound
    Apr 15 11:17:19 Repetier-Server1 avahi-daemon[380]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.10.101.
    Apr 15 11:17:19 Repetier-Server1 avahi-daemon[380]: New relevant interface eth0.IPv4 for mDNS.
    Apr 15 11:17:19 Repetier-Server1 avahi-daemon[380]: Registering new address record for 192.168.10.101 on eth0.IPv4.
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0372] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0404] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0421] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0]
    Apr 15 11:17:19 Repetier-Server1 dhclient[793]: bound to 192.168.10.101 -- renewal in 42426 seconds.
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0663] policy: set 'Kabelgebundene Verbindung 1' (eth0) as default for IPv4 routing and DNS
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.0687] device (eth0): Activation: successful, device activated.
    Apr 15 11:17:19 Repetier-Server1 nm-dispatcher: req:2 'up' [eth0]: new request (3 scripts)
    Apr 15 11:17:19 Repetier-Server1 nm-dispatcher: req:2 'up' [eth0]: start running ordered scripts...
    Apr 15 11:17:19 Repetier-Server1 wpa_supplicant[541]: wlan0: Trying to associate with SSID 'Villa Wahnsinn'
    Apr 15 11:17:19 Repetier-Server1 NetworkManager[386]: <info>  [1586942239.1321] device (wlan0): supplicant interface state: inactive -> associating
    Apr 15 11:17:20 Repetier-Server1 ntpd[490]: Listen normally on 4 eth0 192.168.10.101:123
    Apr 15 11:17:20 Repetier-Server1 ntpd[490]: bind(24) AF_INET6 fe80::1820:8462:bc22:f5df%2#123 flags 0x11 failed: Cannot assign requested address
    Apr 15 11:17:20 Repetier-Server1 ntpd[490]: unable to create socket on eth0 (5) for fe80::1820:8462:bc22:f5df%2#123
    Apr 15 11:17:20 Repetier-Server1 ntpd[490]: failed to init interface for address fe80::1820:8462:bc22:f5df%2
    Apr 15 11:17:20 Repetier-Server1 ntpd[490]: new interface(s) found: waking up resolver
    Apr 15 11:17:21 Repetier-Server1 wpa_supplicant[541]: wlan0: Associated with f0:9f:c2:69:98:c6
    Apr 15 11:17:21 Repetier-Server1 wpa_supplicant[541]: wlan0: CTRL-EVENT-CONNECTED - Connection to f0:9f:c2:69:98:c6 completed [id=0 id_str=]
    Apr 15 11:17:21 Repetier-Server1 kernel: [   16.398349] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    Apr 15 11:17:21 Repetier-Server1 wpa_supplicant[541]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
    Apr 15 11:17:21 Repetier-Server1 NetworkManager[386]: <info>  [1586942241.8020] device (wlan0): supplicant interface state: associating -> completed
    Apr 15 11:17:21 Repetier-Server1 NetworkManager[386]: <info>  [1586942241.8020] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'Villa Wahnsinn'.
    Apr 15 11:17:21 Repetier-Server1 NetworkManager[386]: <info>  [1586942241.8025] device (wlan0): state change: config -> ip-config (reason 'none') [50 70 0]
    Apr 15 11:17:21 Repetier-Server1 NetworkManager[386]: <info>  [1586942241.8047] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
    Apr 15 11:17:21 Repetier-Server1 NetworkManager[386]: <info>  [1586942241.8139] dhcp4 (wlan0): dhclient started with pid 1332
    Apr 15 11:17:21 Repetier-Server1 avahi-daemon[380]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::dc58:44c4:9748:19e9.
    Apr 15 11:17:21 Repetier-Server1 avahi-daemon[380]: New relevant interface wlan0.IPv6 for mDNS.
    Apr 15 11:17:21 Repetier-Server1 avahi-daemon[380]: Registering new address record for fe80::dc58:44c4:9748:19e9 on wlan0.*.
    Apr 15 11:17:21 Repetier-Server1 dhclient[1332]: DHCPREQUEST for 192.168.10.102 on wlan0 to 255.255.255.255 port 67
    Apr 15 11:17:22 Repetier-Server1 dhclient[1332]: DHCPACK of 192.168.10.102 from 192.168.10.1
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1135] dhcp4 (wlan0):   address 192.168.10.102
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1141] dhcp4 (wlan0):   plen 24 (255.255.255.0)
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1145] dhcp4 (wlan0):   gateway 192.168.10.1
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1149] dhcp4 (wlan0):   server identifier 192.168.10.1
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1153] dhcp4 (wlan0):   lease time 86400
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1157] dhcp4 (wlan0):   nameserver '192.168.10.1'
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1162] dhcp4 (wlan0):   domain name 'localdomain'
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1166] dhcp (wlan0):   domain search 'localdomain.'
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1170] dhcp4 (wlan0): state changed unknown -> bound
    Apr 15 11:17:22 Repetier-Server1 avahi-daemon[380]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.10.102.
    Apr 15 11:17:22 Repetier-Server1 avahi-daemon[380]: New relevant interface wlan0.IPv4 for mDNS.
    Apr 15 11:17:22 Repetier-Server1 avahi-daemon[380]: Registering new address record for 192.168.10.102 on wlan0.IPv4.
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1289] device (wlan0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1322] device (wlan0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1362] device (wlan0): state change: secondaries -> activated (reason 'none') [90 100 0]
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1375] manager: NetworkManager state is now CONNECTED_GLOBAL
    Apr 15 11:17:22 Repetier-Server1 nm-dispatcher: req:3 'connectivity-change': new request (3 scripts)
    Apr 15 11:17:22 Repetier-Server1 nm-dispatcher: req:3 'connectivity-change': start running ordered scripts...
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1390] manager: NetworkManager state is now CONNECTED_SITE
    Apr 15 11:17:22 Repetier-Server1 dhclient[1332]: bound to 192.168.10.102 -- renewal in 32822 seconds.
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1823] device (wlan0): Activation: successful, device activated.
    Apr 15 11:17:22 Repetier-Server1 nm-dispatcher: req:4 'up' [wlan0]: new request (3 scripts)
    Apr 15 11:17:22 Repetier-Server1 nm-dispatcher: req:4 'up' [wlan0]: start running ordered scripts...
    Apr 15 11:17:22 Repetier-Server1 NetworkManager[386]: <info>  [1586942242.1913] manager: NetworkManager state is now CONNECTED_GLOBAL
    Apr 15 11:17:23 Repetier-Server1 systemd[1]: systemd-rfkill.service: Succeeded.
    Apr 15 11:17:24 Repetier-Server1 NetworkManager[386]: <info>  [1586942244.4016] manager: startup complete
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started Network Manager Wait Online.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Reached target Network is Online.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Starting /etc/rc.local Compatibility...
    Apr 15 11:17:24 Repetier-Server1 systemd[1457]: rc-local.service: Failed to set up standard output: No such device
    Apr 15 11:17:24 Repetier-Server1 systemd[1457]: rc-local.service: Failed at step STDOUT spawning /etc/rc.local: No such device
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Starting LSB: exim Mail Transport Agent...
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: rc-local.service: Control process exited, code=exited, status=209/STDOUT
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: rc-local.service: Failed with result 'exit-code'.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Failed to start /etc/rc.local Compatibility.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started LSB: exim Mail Transport Agent.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Starting Terminate Plymouth Boot Screen...
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Starting Hold until boot process finishes up...
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Received SIGRTMIN+21 from PID 151 (plymouthd).
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: plymouth-start.service: Succeeded.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: plymouth-quit.service: Succeeded.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started Terminate Plymouth Boot Screen.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: plymouth-quit-wait.service: Succeeded.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started Hold until boot process finishes up.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Received SIGRTMIN+21 from PID 151 (n/a).
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started Getty on tty1.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Reached target Login Prompts.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Reached target Multi-User System.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Started Update UTMP about System Runlevel Changes.
    Apr 15 11:17:24 Repetier-Server1 systemd[1]: Startup finished in 1.528s (kernel) + 17.625s (userspace) = 19.153s.
    Apr 15 11:17:24 Repetier-Server1 ntpd[490]: Listen normally on 6 wlan0 192.168.10.102:123
    Apr 15 11:17:24 Repetier-Server1 ntpd[490]: Listen normally on 7 eth0 [fe80::1820:8462:bc22:f5df%2]:123
    Apr 15 11:17:24 Repetier-Server1 ntpd[490]: Listen normally on 8 wlan0 [fe80::dc58:44c4:9748:19e9%3]:123
    Apr 15 11:17:24 Repetier-Server1 ntpd[490]: new interface(s) found: waking up resolver
    Apr 15 11:17:33 Repetier-Server1 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
    Apr 15 11:17:41 Repetier-Server1 systemd[1]: systemd-fsckd.service: Succeeded.
    Apr 15 11:17:48 Repetier-Server1 systemd[1]: systemd-hostnamed.service: Succeeded.
    Apr 15 11:18:18 Repetier-Server1 ntpd[490]: Soliciting pool server 185.17.70.106
    Apr 15 11:18:19 Repetier-Server1 ntpd[490]: Soliciting pool server 62.202.141.23
    Apr 15 11:18:19 Repetier-Server1 ntpd[490]: Soliciting pool server 62.12.173.11
    Apr 15 11:18:20 Repetier-Server1 ntpd[490]: Soliciting pool server 192.33.96.102
    Apr 15 11:18:20 Repetier-Server1 ntpd[490]: Soliciting pool server 84.16.67.12
    Apr 15 11:18:20 Repetier-Server1 ntpd[490]: Soliciting pool server 176.10.99.203
    Apr 15 11:18:21 Repetier-Server1 ntpd[490]: Soliciting pool server 195.186.4.100
    Apr 15 11:18:21 Repetier-Server1 ntpd[490]: Soliciting pool server 62.2.85.186
    Apr 15 11:18:21 Repetier-Server1 ntpd[490]: Soliciting pool server 87.245.127.186
    Apr 15 11:18:22 Repetier-Server1 ntpd[490]: Soliciting pool server 217.147.223.78
    Apr 15 11:18:22 Repetier-Server1 ntpd[490]: Soliciting pool server 162.159.200.1
    Apr 15 11:18:23 Repetier-Server1 ntpd[490]: Soliciting pool server 217.147.223.78
    Apr 15 11:20:38 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:20:38 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.65' (uid=0 pid=1870 comm="timedatectl ")
    Apr 15 11:20:38 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:20:39 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:20:39 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.008738] usb 1-1.1: USB disconnect, device number 3
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.010386] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.014354] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.018394] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.022356] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.026504] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:21:19 Repetier-Server1 thd[379]: Error reading device '/dev/input/event1'
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.119518] xhci_hcd 0000:01:00.0: ERROR Transfer event for disabled endpoint slot 2 ep 2
    Apr 15 11:21:19 Repetier-Server1 kernel: [  211.119535] xhci_hcd 0000:01:00.0: @0000000037509980 00000000 00000000 0f000000 02038000
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.326879] usb 1-1.1: new high-speed USB device number 5 using xhci_hcd
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.457878] usb 1-1.1: New USB device found, idVendor=1532, idProduct=0e03, bcdDevice=79.13
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.457895] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.457908] usb 1-1.1: Product: Razer Kiyo
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.457920] usb 1-1.1: Manufacturer: Alpha Imaging Tech. Corp.
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.459568] uvcvideo: Found UVC 1.00 device Razer Kiyo (1532:0e03)
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.462217] uvcvideo: Failed to set UVC probe control : -32 (exp. 26).
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.462833] uvcvideo 1-1.1:1.0: Entity type for entity Extension 2 was not initialized!
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.462849] uvcvideo 1-1.1:1.0: Entity type for entity Extension 6 was not initialized!
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.462863] uvcvideo 1-1.1:1.0: Entity type for entity Processing 3 was not initialized!
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.462877] uvcvideo 1-1.1:1.0: Entity type for entity Camera 1 was not initialized!
    Apr 15 11:21:20 Repetier-Server1 kernel: [  212.463223] input: Razer Kiyo as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input2
    Apr 15 11:21:20 Repetier-Server1 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:21:20 Repetier-Server1 mtp-probe: bus: 1, device: 5 was not an MTP device
    Apr 15 11:21:21 Repetier-Server1 systemd[1]: Stopping mjpg_streamer for picam...
    Apr 15 11:21:21 Repetier-Server1 systemd[1]: mjpg_streamer.service: Succeeded.
    Apr 15 11:21:21 Repetier-Server1 systemd[1]: Stopped mjpg_streamer for picam.
    Apr 15 11:21:21 Repetier-Server1 systemd[1]: Started mjpg_streamer for picam.
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Start from directory /usr/local/Repetier-Setup/bin
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Testing active webcams in /dev/v4l/by-path/*
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Best resolution: 0 x 0 at 0
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Best resolution: 1920 x 1080 at 30
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0 on port 8081
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 30 -q 85 -r 1920x1080 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8081 -w /usr/local/share/mjpg-streamer/www" -b
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2001]: starting application
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2001]: enabling daemon mode
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: enabling daemon modeforked to background (2003)
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index1
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: Using V4L2 device.: /dev/video1
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: Desired Resolution: 1920 x 1080
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: Frames Per Second.: 30
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: Format............: JPEG
    Apr 15 11:21:21 Repetier-Server1 systemd-udevd[1957]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: TV-Norm...........: DEFAULT
    Apr 15 11:21:21 Repetier-Server1 mtp-probe: checking bus 1, device 5: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:21:21 Repetier-Server1 mtp-probe: bus: 1, device: 5 was not an MTP device
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: HTTP TCP port........: 8081
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: HTTP Listen Address..: (null)
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: username:password....: disabled
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: commands.............: enabled
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
    Apr 15 11:21:21 Repetier-Server1 MJPG-streamer [2003]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
    Apr 15 11:21:21 Repetier-Server1 startAllCams[1972]: Webcam does not support MJPG - using slower YUYV instead!
    Apr 15 11:21:38 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:21:39 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.72' (uid=0 pid=2047 comm="timedatectl ")
    Apr 15 11:21:39 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:21:39 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:21:39 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:22:09 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:22:12 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.76' (uid=0 pid=2104 comm="timedatectl ")
    Apr 15 11:22:12 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:22:12 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:22:12 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:22:42 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:22:47 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.80' (uid=0 pid=2163 comm="timedatectl ")
    Apr 15 11:22:47 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:22:48 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:22:48 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:23:18 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:23:25 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.84' (uid=0 pid=2237 comm="timedatectl ")
    Apr 15 11:23:25 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:23:25 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:23:25 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:23:55 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:24:04 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.88' (uid=0 pid=2305 comm="timedatectl ")
    Apr 15 11:24:04 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:24:04 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:24:04 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:24:34 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:24:45 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.92' (uid=0 pid=2379 comm="timedatectl ")
    Apr 15 11:24:45 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:24:45 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:24:45 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:25:15 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:25:28 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.96' (uid=0 pid=2459 comm="timedatectl ")
    Apr 15 11:25:28 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:25:28 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:25:28 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:25:58 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:26:13 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.100' (uid=0 pid=2542 comm="timedatectl ")
    Apr 15 11:26:13 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:26:14 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:26:14 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:26:44 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:27:01 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.104' (uid=0 pid=2614 comm="timedatectl ")
    Apr 15 11:27:01 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:27:01 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:27:01 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:27:31 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:27:50 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.108' (uid=0 pid=2713 comm="timedatectl ")
    Apr 15 11:27:50 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:27:50 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:27:50 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:28:20 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:28:41 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.114' (uid=0 pid=2821 comm="timedatectl ")
    Apr 15 11:28:41 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:28:41 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:28:41 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:29:11 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:29:34 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.118' (uid=0 pid=2909 comm="timedatectl ")
    Apr 15 11:29:34 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:29:34 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:29:34 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:30:04 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:30:29 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.122' (uid=0 pid=2995 comm="timedatectl ")
    Apr 15 11:30:30 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:30:30 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:30:30 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:31:00 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:31:04 Repetier-Server1 ntpd[490]: 87.245.127.186 local addr 192.168.10.101 -> <null>
    Apr 15 11:31:27 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.126' (uid=0 pid=3100 comm="timedatectl ")
    Apr 15 11:31:27 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:31:27 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:31:27 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:31:57 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:32:26 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.130' (uid=0 pid=3215 comm="timedatectl ")
    Apr 15 11:32:26 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:32:26 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:32:26 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:32:53 Repetier-Server1 systemd[1]: Starting Cleanup of Temporary Directories...
    Apr 15 11:32:53 Repetier-Server1 systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
    Apr 15 11:32:53 Repetier-Server1 systemd[1]: Started Cleanup of Temporary Directories.
    Apr 15 11:32:56 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:33:28 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.134' (uid=0 pid=3303 comm="timedatectl ")
    Apr 15 11:33:28 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:33:28 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:33:28 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:33:58 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.620891] usb 1-1.1: USB disconnect, device number 5
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.621679] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.625661] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.629672] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.633661] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.637809] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.752129] xhci_hcd 0000:01:00.0: ERROR Transfer event for disabled endpoint slot 2 ep 2
    Apr 15 11:34:18 Repetier-Server1 kernel: [  989.752145] xhci_hcd 0000:01:00.0: @0000000037507200 00000000 00000000 0f000000 02038001
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.059981] usb 1-1.1: new high-speed USB device number 6 using xhci_hcd
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.201009] usb 1-1.1: New USB device found, idVendor=1532, idProduct=0e03, bcdDevice=79.13
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.201026] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.201039] usb 1-1.1: Product: Razer Kiyo
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.201051] usb 1-1.1: Manufacturer: Alpha Imaging Tech. Corp.
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.203428] uvcvideo: Found UVC 1.00 device Razer Kiyo (1532:0e03)
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.206169] uvcvideo: Failed to set UVC probe control : -32 (exp. 26).
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.207127] uvcvideo 1-1.1:1.0: Entity type for entity Extension 2 was not initialized!
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.207143] uvcvideo 1-1.1:1.0: Entity type for entity Extension 6 was not initialized!
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.207158] uvcvideo 1-1.1:1.0: Entity type for entity Processing 3 was not initialized!
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.207172] uvcvideo 1-1.1:1.0: Entity type for entity Camera 1 was not initialized!
    Apr 15 11:34:18 Repetier-Server1 kernel: [  990.207839] input: Razer Kiyo as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input3
    Apr 15 11:34:18 Repetier-Server1 mtp-probe: checking bus 1, device 6: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:34:18 Repetier-Server1 mtp-probe: bus: 1, device: 6 was not an MTP device
    Apr 15 11:34:18 Repetier-Server1 systemd[1]: Stopping mjpg_streamer for picam...
    Apr 15 11:34:18 Repetier-Server1 systemd[1]: mjpg_streamer.service: Succeeded.
    Apr 15 11:34:18 Repetier-Server1 systemd[1]: Stopped mjpg_streamer for picam.
    Apr 15 11:34:18 Repetier-Server1 systemd[1]: Started mjpg_streamer for picam.
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3394]: Start from directory /usr/local/Repetier-Setup/bin
    Apr 15 11:34:18 Repetier-Server1 systemd[1]: mjpg_streamer.service: Main process exited, code=killed, status=15/TERM
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Start from directory /usr/local/Repetier-Setup/bin
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Testing active webcams in /dev/v4l/by-path/*
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Best resolution: 0 x 0 at 0
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Best resolution: 1920 x 1080 at 30
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0 on port 8081
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video0 --fps 30 -q 85 -r 1920x1080 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8081 -w /usr/local/share/mjpg-streamer/www" -b
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3427]: starting application
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3427]: enabling daemon mode
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: enabling daemon modeforked to background (3429)
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
    Apr 15 11:34:18 Repetier-Server1 startAllCams[3398]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index1
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: Using V4L2 device.: /dev/video0
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: Desired Resolution: 1920 x 1080
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: Frames Per Second.: 30
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: Format............: JPEG
    Apr 15 11:34:18 Repetier-Server1 MJPG-streamer [3429]: TV-Norm...........: DEFAULT
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: HTTP TCP port........: 8081
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: HTTP Listen Address..: (null)
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: username:password....: disabled
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: commands.............: enabled
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
    Apr 15 11:34:19 Repetier-Server1 MJPG-streamer [3429]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
    Apr 15 11:34:19 Repetier-Server1 startAllCams[3398]: Webcam does not support MJPG - using slower YUYV instead!
    Apr 15 11:34:19 Repetier-Server1 startAllCams[3398]: Best resolution: 0 x 0 at 0
    Apr 15 11:34:19 Repetier-Server1 systemd-udevd[3375]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Apr 15 11:34:19 Repetier-Server1 mtp-probe: checking bus 1, device 6: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:34:19 Repetier-Server1 mtp-probe: bus: 1, device: 6 was not an MTP device
    Apr 15 11:34:31 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.138' (uid=0 pid=3471 comm="timedatectl ")
    Apr 15 11:34:31 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:34:31 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:34:31 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:35:01 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:35:36 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.142' (uid=0 pid=3572 comm="timedatectl ")
    Apr 15 11:35:36 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:35:36 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:35:36 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:36:06 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:36:41 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.146' (uid=0 pid=3691 comm="timedatectl ")
    Apr 15 11:36:41 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:36:42 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:36:42 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:36:45 Repetier-Server1 ntpd[490]: 176.10.99.203 local addr 192.168.10.101 -> <null>
    Apr 15 11:37:12 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:37:47 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.150' (uid=0 pid=3780 comm="timedatectl ")
    Apr 15 11:37:47 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:37:47 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:37:47 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:38:17 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:38:52 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.155' (uid=0 pid=3912 comm="timedatectl ")
    Apr 15 11:38:52 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:38:52 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:38:52 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:39:22 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:39:57 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.159' (uid=0 pid=4010 comm="timedatectl ")
    Apr 15 11:39:57 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:39:57 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:39:57 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:40:27 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:41:02 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.163' (uid=0 pid=4111 comm="timedatectl ")
    Apr 15 11:41:02 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:41:02 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:41:02 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:41:33 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:42:08 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.167' (uid=0 pid=4209 comm="timedatectl ")
    Apr 15 11:42:08 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:42:08 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:42:08 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:42:38 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:43:13 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.172' (uid=0 pid=4339 comm="timedatectl ")
    Apr 15 11:43:13 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:43:13 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:43:13 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:43:43 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:44:22 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.177' (uid=0 pid=4492 comm="timedatectl ")
    Apr 15 11:44:22 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:44:22 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:44:22 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:44:52 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:45:27 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.181' (uid=0 pid=4598 comm="timedatectl ")
    Apr 15 11:45:27 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:45:27 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:45:27 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:45:57 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:46:33 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.185' (uid=0 pid=4700 comm="timedatectl ")
    Apr 15 11:46:33 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:46:33 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:46:33 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:47:03 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.015726] usb 1-1.1: USB disconnect, device number 6
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.018294] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.022306] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.026276] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.030270] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:47:07 Repetier-Server1 kernel: [ 1759.034297] uvcvideo: Failed to resubmit video URB (-19).
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.079669] usb 1-1.1: new high-speed USB device number 7 using xhci_hcd
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.210690] usb 1-1.1: New USB device found, idVendor=1532, idProduct=0e03, bcdDevice=79.13
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.210707] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.210720] usb 1-1.1: Product: Razer Kiyo
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.210732] usb 1-1.1: Manufacturer: Alpha Imaging Tech. Corp.
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.212393] uvcvideo: Found UVC 1.00 device Razer Kiyo (1532:0e03)
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.215349] uvcvideo: Failed to set UVC probe control : -32 (exp. 26).
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.218647] uvcvideo 1-1.1:1.0: Entity type for entity Extension 2 was not initialized!
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.218663] uvcvideo 1-1.1:1.0: Entity type for entity Extension 6 was not initialized!
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.218677] uvcvideo 1-1.1:1.0: Entity type for entity Processing 3 was not initialized!
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.218692] uvcvideo 1-1.1:1.0: Entity type for entity Camera 1 was not initialized!
    Apr 15 11:47:08 Repetier-Server1 kernel: [ 1760.219042] input: Razer Kiyo as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input4
    Apr 15 11:47:08 Repetier-Server1 mtp-probe: checking bus 1, device 7: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:47:08 Repetier-Server1 mtp-probe: bus: 1, device: 7 was not an MTP device
    Apr 15 11:47:08 Repetier-Server1 systemd[1]: Stopping mjpg_streamer for picam...
    Apr 15 11:47:08 Repetier-Server1 systemd[1]: mjpg_streamer.service: Succeeded.
    Apr 15 11:47:08 Repetier-Server1 systemd[1]: Stopped mjpg_streamer for picam.
    Apr 15 11:47:08 Repetier-Server1 systemd[1]: Started mjpg_streamer for picam.
    Apr 15 11:47:08 Repetier-Server1 systemd[1]: mjpg_streamer.service: Main process exited, code=killed, status=15/TERM
    Apr 15 11:47:08 Repetier-Server1 startAllCams[4778]: Start from directory /usr/local/Repetier-Setup/bin
    Apr 15 11:47:08 Repetier-Server1 startAllCams[4778]: Testing active webcams in /dev/v4l/by-path/*
    Apr 15 11:47:08 Repetier-Server1 startAllCams[4778]: Starting webcam /dev/v4l/by-path/platform-bcm2835-codec-video-index0
    Apr 15 11:47:08 Repetier-Server1 startAllCams[4778]: Best resolution: 0 x 0 at 0
    Apr 15 11:47:08 Repetier-Server1 startAllCams[4778]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: Best resolution: 1920 x 1080 at 30
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index0 on port 8081
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 30 -q 85 -r 1920x1080 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8081 -w /usr/local/share/mjpg-streamer/www" -b
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4808]: starting application
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4808]: enabling daemon mode
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: enabling daemon modeforked to background (4810)
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-video-index1
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: Using V4L2 device.: /dev/video1
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: Desired Resolution: 1920 x 1080
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: Frames Per Second.: 30
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: Format............: JPEG
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: TV-Norm...........: DEFAULT
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: www-folder-path......: /usr/local/share/mjpg-streamer/www/
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: HTTP TCP port........: 8081
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: HTTP Listen Address..: (null)
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: username:password....: disabled
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: commands.............: enabled
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: starting input plugin /usr/local/lib/mjpg-streamer/input_uvc.so
    Apr 15 11:47:09 Repetier-Server1 MJPG-streamer [4810]: starting output plugin: /usr/local/lib/mjpg-streamer/output_http.so (ID: 00)
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: Webcam does not support MJPG - using slower YUYV instead!
    Apr 15 11:47:09 Repetier-Server1 startAllCams[4778]: Best resolution: 0 x 0 at 0
    Apr 15 11:47:09 Repetier-Server1 systemd-udevd[4760]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
    Apr 15 11:47:09 Repetier-Server1 mtp-probe: checking bus 1, device 7: "/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1"
    Apr 15 11:47:09 Repetier-Server1 mtp-probe: bus: 1, device: 7 was not an MTP device
    Apr 15 11:47:38 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.190' (uid=0 pid=4909 comm="timedatectl ")
    Apr 15 11:47:38 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:47:38 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:47:38 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:48:08 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:48:43 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.194' (uid=0 pid=5029 comm="timedatectl ")
    Apr 15 11:48:43 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:48:43 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:48:43 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:49:13 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
    Apr 15 11:49:49 Repetier-Server1 dbus-daemon[373]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.198' (uid=0 pid=5135 comm="timedatectl ")
    Apr 15 11:49:49 Repetier-Server1 systemd[1]: Starting Time & Date Service...
    Apr 15 11:49:49 Repetier-Server1 dbus-daemon[373]: [system] Successfully activated service 'org.freedesktop.timedate1'
    Apr 15 11:49:49 Repetier-Server1 systemd[1]: Started Time & Date Service.
    Apr 15 11:50:09 Repetier-Server1 systemd[1]: Created slice User Slice of UID 1000.
    Apr 15 11:50:09 Repetier-Server1 systemd[1]: Starting User Runtime Directory /run/user/1000...
    Apr 15 11:50:09 Repetier-Server1 systemd[1]: Started User Runtime Directory /run/user/1000.
    Apr 15 11:50:09 Repetier-Server1 systemd[1]: Starting User Manager for UID 1000...
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on GnuPG network certificate management daemon.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Reached target Timers.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on GnuPG cryptographic agent and passphrase cache.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Reached target Paths.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Starting D-Bus User Message Bus Socket.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Listening on D-Bus User Message Bus Socket.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Reached target Sockets.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Reached target Basic System.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Reached target Default.
    Apr 15 11:50:10 Repetier-Server1 systemd[5192]: Startup finished in 177ms.
    Apr 15 11:50:10 Repetier-Server1 systemd[1]: Started User Manager for UID 1000.
    Apr 15 11:50:10 Repetier-Server1 systemd[1]: Started Session c1 of user pi.
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5256]: starting application
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5256]: enabling daemon mode
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: MJPG Streamer Version: git rev: 821c330ea6bbb5fbed98d48e00aac156e923161b
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: Using V4L2 device.: /dev/video1
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: Desired Resolution: 1920 x 1080
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: Frames Per Second.: 30
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: Format............: JPEG
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: TV-Norm...........: DEFAULT
    Apr 15 11:50:11 Repetier-Server1 MJPG-streamer [5258]: init_VideoIn failed
    Apr 15 11:50:19 Repetier-Server1 systemd[1]: systemd-timedated.service: Succeeded.
  • I saw you tried 1920x1080 as resolution with 30 frames per second. But I also see
    so there is no hardware compression as it seems and no matching framerate/resolution in capabilities. What does
    /usr/bin/v4l2-ctl --list-formats-ext -d /dev/video1
    or video0 return?
    If you really have no hardware compression you should not use such a high resolution and frame rate - that will add very high cpu rate and maybe still not work. Plus you need a very good network connection for the high data rate.
    Try selecting a resolution/frequency you see in the supported list - best in mjpg section if it exists.
  • I can choose resolutions what I want, i never become a picture.
    pi@Repetier-Server1:~ $ /usr/bin/v4l2-ctl --list-formats-ext -d /dev/video0
    ioctl: VIDIOC_ENUM_FMT
    Type: Video Capture
    [0]: 'MJPG' (Motion-JPEG, compressed)
    Interval: Discrete 0.033s (30.000 fps)
    Size: Discrete 1920x1080
    Interval: Discrete 0.017s (60.000 fps)
    [1]: 'YUYV' (YUYV 4:2:2)
    [2]: 'H264' (H.264, compressed)
    Interval: Discrete 0.042s (24.000 fps)
    Interval: Discrete 0.050s (20.000 fps)
  • Looks like it has mjpg support for 640x480 and 1920x1080 at 30 fps. I also reread the log and not sure if all closed. Some calls look like they succeeded. Especially on port 8081 it seemed to work. Please run
    ps aux | grep mjpg
    and show the output. When I do it I get something like this:
    root@Felix:~# /usr/local/Repetier-Setup/bin/startAllCams
    enabling daemon modeforked to background (1016)
    Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0
    Best resolution: 640 x 480 at 15
    Starting platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0 on port 8086
    /usr/local/bin/mjpg_streamer -i "/usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 15 -q 85 -r 640x480 " -o "/usr/local/lib/mjpg-streamer/output_http.so -p 8086 -w /usr/local/share/mjpg-streamer/www" -b
    enabling daemon modeforked to background (1047)
    Starting webcam /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index1
    root@Felix:~# ps aux | grep mjpg
    root      1016  2.8  0.0  80920  1804 ?        Sl   09:54   0:00 /usr/local/bin/mjpg_streamer -i /usr/local/lib/mjpg-streamer/input_raspicam.so -fps 15 -x 640 -y 480 -quality 85  -o /usr/local/lib/mjpg-streamer/output_http.so -p 9000 -w /usr/local/share/mjpg-streamer/www -b
    root      1047  0.1  0.0  25112  2784 ?        Sl   09:54   0:00 /usr/local/bin/mjpg_streamer -i /usr/local/lib/mjpg-streamer/input_uvc.so -d /dev/video1 --fps 15 -q 85 -r 640x480  -o /usr/local/lib/mjpg-streamer/output_http.so -p 8086 -w /usr/local/share/mjpg-streamer/www -b
    root      1068  0.0  0.0   7348   524 pts/0    S+   09:55   0:00 grep mjpg
    You see some failed like I saw but 2 also succeeded. Not sure why linux now has so much more video devices showing up. They just do not work all but no problem as we see them fail. the ps command then shows the survivors.
  • Excuse me, but that's beyond my ability. I'm just a user, installed the image with instructions, put camera in. I'm overwhelmed in the console. Can you help me by remote? The Raspberry 3 works well, I don't understand why the 4 doesn't.
  • I have a second problem, the print with my Repetier-Server stops by yourself. Same GCode printed from USB-Stick or Octo Print working well. I have checked the cable and all printer settings. The problem only happens sometimes.
    I switched from Octo Print to repertier server because Repetier-Server it looks better. But either I've got something wrong with Raspberry Pi or there's a bug. Can you help me, please? best to use a remote session
  • Login over ssh and send
    ps aux | grep mjpg
    and paste output here is all I wanted.
    Remote session is not possible, especially since you work when I sleep:-)
    Regarding the print stops - does the printer reconnect causing the print to stop or just hang? Both can come from bad power supply. See https://harlemsquirrel.github.io/shell/2019/01/05/monitoring-raspberry-pi-power-and-thermal-issues.html for informations about detecting problems. Most important is
    vcgencmd get_throttled
    which should return 0x0 or you might have a power problem which can lead to usb problems and usb disconnects after a while. Send this after you got problems - often it starts with 0 and gets non zero during print when it stopped.
    If you check /var/lib/Repetier-Server/logs/server.log you might see if there was a reconnect at the time of problem.
  • Now I've rebuilt the whole Raspberry Pi. But the camera still doesn't work. I have the following camera: https://www.razer.com/de-de/gaming-broadcaster/razer-kiyo
    And I've also arranged another camera, which works immediately without any problems. But the Razer Kiyo isn't. The Razer Kiyo also worked well with the Repertier Server on Raspberry Pi 3. Not until Raspberry Pi 4. Which camera can you recommend me for the Repertier Server? she should either have LED lighting or night vision mode.
  • According to this:
    https://askubuntu.com/questions/993115/does-the-razer-kiyo-work-under-linux
    it should work. What does
    v4l2-ctl --device=/dev/video0 --list-formats-ext
    with /dev/video0 the device number the webcam gets. There they show for MJPG
        Index       : 1
        Type        : Video Capture
        Pixel Format: 'MJPG' (compressed)
    So you need one of the resolutions defined there and also a framerate provided there. Guess otherwise the script is not happy finding no match. Would use 864x480 as a good compromise between resolution and stream bitrate as mjpg is badly compressed.
    I have no webcam with led so can not recommend one.
  • Thank you very much for your support! with the razor cam will on my Repertier not working. So I buy a Logitech, this working well.
  • Hi I have the same issue. I had it working with a PI camera (used the pi preconfigured install), but it stopped working. I reinstalled the PI.. bought a new pi camera module... but nothing in the drop list.
    this is what i get when entering the above commands:
     ps aux | grep mjpg
    pi        3534  0.0  0.0   7348   584 pts/0    S+   15:04   0:00 grep --color=auto mjpg
  • What does
    vcgencmd get_camera
    return? If a pi cam is connected and supported you should get:
    supported=1 detected=1
    If detected is 0 linux does not see it. Make sure the cable is oriented correctly and has contact.
  • supported=0 detected=0
    something is wrong here ;)
  • Yep. I wonder it is not even supported. The buster image we use supports it. I just expected that it was not detected.
    Running it one of my pis without pi cam I get:
    vcgencmd get_camera
    supported=1 detected=0
    So question is what os/image are you using here?
  • latest from your website... i tried the manual way now too.. no result eiter...
  • Please read answer here:
    https://raspberrypi.stackexchange.com/questions/89120/unable-to-detect-cam-module-in-raspberry-pi-3-b
    Seems that it might be that support is disabled and you just need to enable it.
  • HAHA this was it! THANK YOU... no idea how this happened but who cares :)
