Printer resumes when stop commanded from LCD
I am using Repetier Server Pro 0.93.1 and my printer uses an SKRv1.4 controller with Marlin 2.0.5.3 firmware.
When I use the printer LCD to command stop print, the printer stops printing, homes, then returns to the previous printing location and continues printing.  Selecting STOP from Repetier Server stops the print a expected.  Print log below:
< 18:29:16.388: N16 M73 P0 R402 Q0 S402
> 18:29:18.381: ok N16 P63 B31
> 18:29:18.381:  T:199.08 /200.00 B:60.14 /60.00 @:46 B@:66
> 18:29:18.382:  T:198.82 /200.00 B:60.14 /60.00 @:42 B@:61
< 18:29:18.382: N17 G90                       ; Use absolute coordinates
< 18:29:18.382: N18 M82                       ; Set E codes absolute (default)
< 18:29:18.383: N19 M107                      ; RepRap Fan off
> 18:29:18.383: Slow command added:G28                       ; Home all axis
< 18:29:18.383: N20 G28                       ; Home all axis
< 18:29:18.383: N21 G1 Z0.36                  ; Set Z offset PLA=0.36,ABS=0.32
> 18:29:18.384: ok N17 P63 B31
> 18:29:18.384: ok N18 P63 B31
> 18:29:18.384: ok N19 P63 B31
< 18:29:18.385: N22 G92 Z0 E0                 ; Reset Z and Extruder
< 18:29:18.385: ;@execute pi_temp
< 18:29:18.388: ;@execute enclosure
< 18:29:18.392: N23 M140 S60
< 18:29:18.394: N24 M105
> 18:29:18.395: Slow command added:M190 S60
< 18:29:18.395: N25 M190 S60
> 18:29:18.640:  T:198.82 /200.00 B:60.19 /60.00 @:47 B@:62
> 18:29:19.640:  T:198.68 /200.00 B:60.19 /60.00 @:42 B@:49
> 18:29:20.384: echo:busy: processing
> 18:29:20.641:  T:198.82 /200.00 B:60.19 /60.00 @:8 B@:55
> 18:29:21.640:  T:198.55 /200.00 B:60.19 /60.00 @:45 B@:60
> 18:29:22.383: echo:busy: processing
> 18:29:22.641:  T:198.55 /200.00 B:60.14 /60.00 @:50 B@:58
> 18:29:23.641:  T:198.68 /200.00 B:60.19 /60.00 @:42 B@:36
> 18:29:24.383: echo:busy: processing
> 18:29:24.641:  T:198.68 /200.00 B:60.14 /60.00 @:57 B@:61
> 18:29:25.641:  T:198.95 /200.00 B:60.19 /60.00 @:39 B@:44
> 18:29:26.383: echo:busy: processing
> 18:29:26.640:  T:199.08 /200.00 B:60.19 /60.00 @:33 B@:39
> 18:29:27.640:  T:199.21 /200.00 B:60.14 /60.00 @:19 B@:47
> 18:29:28.384: echo:busy: processing
> 18:29:28.641:  T:199.34 /200.00 B:60.14 /60.00 @:39 B@:42
> 18:29:29.641:  T:199.47 /200.00 B:60.14 /60.00 @:20 B@:46
> 18:29:30.384: echo:busy: processing
> 18:29:30.641:  T:199.34 /200.00 B:60.09 /60.00 @:60 B@:54
> 18:29:31.659:  T:199.61 /200.00 B:60.14 /60.00 @:34 B@:25
> 18:29:32.383: echo:busy: processing
> 18:29:32.659:  T:199.87 /200.00 B:60.09 /60.00 @:10 B@:46
> 18:29:33.659:  T:199.74 /200.00 B:60.09 /60.00 @:40 B@:39
> 18:29:34.383: echo:busy: processing
> 18:29:34.659:  T:199.87 /200.00 B:60.09 /60.00 @:12 B@:35
> 18:29:35.659:  T:199.87 /200.00 B:60.05 /60.00 @:36 B@:43
> 18:29:36.384: echo:busy: processing
> 18:29:36.659:  T:200.00 /200.00 B:60.05 /60.00 @:20 B@:43
> 18:29:37.659:  T:200.00 /200.00 B:60.05 /60.00 @:32 B@:31
> 18:29:38.384: echo:busy: processing
> 18:29:38.659:  T:200.18 /200.00 B:60.00 /60.00 @:0 B@:53
> 18:29:39.659:  T:200.18 /200.00 B:60.00 /60.00 @:12 B@:39
> 18:29:40.384: echo:busy: processing
> 18:29:40.660:  T:200.00 /200.00 B:60.00 /60.00 @:60 B@:39
> 18:29:41.659:  T:200.18 /200.00 B:60.00 /60.00 @:13 B@:24
> 18:29:42.384: echo:busy: processing
> 18:29:42.659:  T:200.18 /200.00 B:59.95 /60.00 @:17 B@:47
> 18:29:43.659:  T:200.00 /200.00 B:59.95 /60.00 @:53 B@:46
> 18:29:44.384: echo:busy: processing
> 18:29:44.659:  T:200.00 /200.00 B:59.95 /60.00 @:66 B@:47
> 18:29:45.659:  T:199.87 /200.00 B:59.90 /60.00 @:57 B@:55
> 18:29:46.383: echo:busy: processing
> 18:29:46.659:  T:200.00 /200.00 B:59.90 /60.00 @:39 B@:57
> 18:29:47.672:  T:200.18 /200.00 B:59.95 /60.00 @:1 B@:46
> 18:29:48.384: echo:busy: processing
> 18:29:48.672:  T:200.00 /200.00 B:59.90 /60.00 @:57 B@:61
> 18:29:49.671:  T:200.18 /200.00 B:60.00 /60.00 @:13 B@:26
> 18:29:50.384: echo:busy: processing
> 18:29:50.672:  T:200.00 /200.00 B:59.95 /60.00 @:36 B@:39
> 18:29:51.672:  T:200.18 /200.00 B:59.95 /60.00 @:23 B@:43
> 18:29:52.385: echo:busy: processing
> 18:29:52.650: X:0.00 Y:0.00 Z:0.32 E:0.00 Count X:0 Y:0 Z:128
> 18:29:52.651: ok N20 P63 B26
> 18:29:52.651: ok N21 P62 B27
> 18:29:52.651: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:128
> 18:29:52.651: ok N22 P62 B28
> 18:29:52.652: ok N23 P62 B29
< 18:29:52.652: M117 ETA 01:11:36 day 23
< 18:29:52.652: N26 M104 S200
< 18:29:52.653: N27 M105
> 18:29:52.653: Slow command added:M109 S200
< 18:29:52.653: N28 M109 S200
> 18:29:52.656: ok T:200.00 /200.00 B:59.90 /60.00 @:39 B@:70
< 18:29:52.656: N29 M82 ;absolute extrusion mode
> 18:29:52.660:  T:200.00 /200.00 B:59.90 /60.00 @:39 B@:70 W:?
> 18:29:52.673:  T:200.00 /200.00 B:59.95 /60.00 @:39 B@:41
> 18:29:53.660:  T:200.00 /200.00 B:59.95 /60.00 @:35 B@:55 W:19
> 18:29:53.672:  T:200.00 /200.00 B:59.95 /60.00 @:35 B@:55
> 18:29:54.660:  T:200.18 /200.00 B:60.00 /60.00 @:10 B@:38 W:18
> 18:29:54.660: echo:busy: processing
> 18:29:54.672:  T:200.18 /200.00 B:60.00 /60.00 @:12 B@:39
> 18:29:55.659:  T:200.18 /200.00 B:59.95 /60.00 @:28 B@:75 W:17
> 18:29:55.671:  T:200.00 /200.00 B:59.95 /60.00 @:66 B@:73
> 18:29:56.661:  T:200.00 /200.00 B:60.00 /60.00 @:69 B@:42 W:16
> 18:29:56.661: echo:busy: processing
> 18:29:56.672:  T:200.00 /200.00 B:60.00 /60.00 @:68 B@:43
> 18:29:57.661:  T:200.36 /200.00 B:60.00 /60.00 @:0 B@:52 W:15
> 18:29:57.672:  T:200.36 /200.00 B:60.00 /60.00 @:0 B@:53
> 18:29:58.660:  T:200.00 /200.00 B:60.00 /60.00 @:66 B@:62 W:14
> 18:29:58.660: echo:busy: processing
> 18:29:58.672:  T:200.00 /200.00 B:60.00 /60.00 @:64 B@:61
> 18:29:59.661:  T:200.00 /200.00 B:60.00 /60.00 @:57 B@:54 W:13
> 18:29:59.673:  T:200.00 /200.00 B:60.00 /60.00 @:56 B@:54
> 18:30:00.661:  T:200.18 /200.00 B:59.95 /60.00 @:34 B@:77 W:12
> 18:30:00.661: echo:busy: processing
> 18:30:00.673:  T:200.18 /200.00 B:59.95 /60.00 @:34 B@:76
> 18:30:01.660:  T:200.18 /200.00 B:60.00 /60.00 @:17 B@:64 W:11
> 18:30:01.673:  T:200.18 /200.00 B:60.00 /60.00 @:18 B@:63
> 18:30:02.660:  T:200.18 /200.00 B:60.00 /60.00 @:21 B@:68 W:10
> 18:30:02.661: echo:busy: processing
> 18:30:02.673:  T:200.18 /200.00 B:60.00 /60.00 @:22 B@:67
> 18:30:03.673:  T:199.87 /200.00 B:60.05 /60.00 @:68 B@:44
> 18:30:03.677:  T:199.87 /200.00 B:60.05 /60.00 @:68 B@:44 W:8
> 18:30:04.660: echo:busy: processing
> 18:30:04.673:  T:200.00 /200.00 B:60.05 /60.00 @:39 B@:43
> 18:30:04.677:  T:200.00 /200.00 B:60.05 /60.00 @:39 B@:43 W:7
> 18:30:05.672:  T:199.87 /200.00 B:60.05 /60.00 @:64 B@:55
> 18:30:05.677:  T:199.87 /200.00 B:60.05 /60.00 @:64 B@:55 W:6
> 18:30:06.659: echo:busy: processing
> 18:30:06.672:  T:200.00 /200.00 B:60.05 /60.00 @:22 B@:47
> 18:30:06.677:  T:200.00 /200.00 B:60.05 /60.00 @:23 B@:47 W:5
> 18:30:07.673:  T:200.00 /200.00 B:60.05 /60.00 @:38 B@:53
> 18:30:07.677:  T:200.00 /200.00 B:60.05 /60.00 @:38 B@:52 W:4
> 18:30:08.660: echo:busy: processing
> 18:30:08.673:  T:200.00 /200.00 B:60.09 /60.00 @:37 B@:33
> 18:30:08.677:  T:200.00 /200.00 B:60.09 /60.00 @:36 B@:33 W:3
> 18:30:09.673:  T:200.00 /200.00 B:60.09 /60.00 @:43 B@:40
> 18:30:09.677:  T:200.00 /200.00 B:60.09 /60.00 @:43 B@:40 W:2
> 18:30:10.660: echo:busy: processing
> 18:30:10.672:  T:200.18 /200.00 B:60.05 /60.00 @:28 B@:66
> 18:30:10.677:  T:200.18 /200.00 B:60.05 /60.00 @:28 B@:65 W:1
> 18:30:11.673:  T:200.18 /200.00 B:60.09 /60.00 @:27 B@:31
> 18:30:11.677:  T:200.18 /200.00 B:60.09 /60.00 @:27 B@:31 W:0
> 18:30:12.655: ok N25 P63 B26
> 18:30:12.655: ok P63 B27
> 18:30:12.656: ok N26 P63 B28
< 18:30:12.656: M117 ETE 06:39:55
< 18:30:12.656: N30 G92 E0
< 18:30:12.656: N31 G92 E0
> 18:30:12.660: ok T:200.00 /200.00 B:60.05 /60.00 @:34 B@:44
< 18:30:12.660: N32 G1 F3000 E-0.75
> 18:30:12.665:  T:200.00 /200.00 B:60.05 /60.00 @:34 B@:44 W:?
> 18:30:12.672:  T:200.00 /200.00 B:60.05 /60.00 @:34 B@:44
> 18:30:13.665:  T:200.36 /200.00 B:60.09 /60.00 @:0 B@:30 W:19
> 18:30:13.672:  T:200.36 /200.00 B:60.09 /60.00 @:0 B@:30
> 18:30:14.664:  T:200.00 /200.00 B:60.05 /60.00 @:45 B@:42 W:18
> 18:30:14.665: echo:busy: processing
> 18:30:14.672:  T:200.00 /200.00 B:60.05 /60.00 @:45 B@:42
> 18:30:15.665:  T:200.36 /200.00 B:60.05 /60.00 @:0 B@:40 W:17
> 18:30:15.673:  T:200.36 /200.00 B:60.05 /60.00 @:0 B@:40
> 18:30:16.665:  T:200.36 /200.00 B:60.05 /60.00 @:18 B@:52 W:16
> 18:30:16.665: echo:busy: processing
> 18:30:16.673:  T:200.36 /200.00 B:60.05 /60.00 @:18 B@:52
> 18:30:17.664:  T:200.18 /200.00 B:60.09 /60.00 @:49 B@:17 W:15
> 18:30:17.672:  T:200.18 /200.00 B:60.09 /60.00 @:49 B@:17
> 18:30:18.664:  T:200.00 /200.00 B:60.05 /60.00 @:50 B@:34 W:14
> 18:30:18.665: echo:busy: processing
> 18:30:18.673:  T:200.00 /200.00 B:60.05 /60.00 @:49 B@:35
> 18:30:19.690:  T:200.18 /200.00 B:60.05 /60.00 @:0 B@:35
> 18:30:19.691:  T:200.18 /200.00 B:60.05 /60.00 @:0 B@:35 W:12
> 18:30:20.663: echo:busy: processing
> 18:30:20.684:  T:200.18 /200.00 B:60.05 /60.00 @:14 B@:24
> 18:30:20.688:  T:200.18 /200.00 B:60.05 /60.00 @:14 B@:25 W:11
> 18:30:21.684:  T:200.18 /200.00 B:60.05 /60.00 @:11 B@:26
> 18:30:21.688:  T:200.18 /200.00 B:60.05 /60.00 @:12 B@:27 W:10
> 18:30:22.665: echo:busy: processing
> 18:30:22.684:  T:199.87 /200.00 B:59.95 /60.00 @:53 B@:64
> 18:30:22.688:  T:199.87 /200.00 B:59.95 /60.00 @:53 B@:64 W:9
> 18:30:23.684:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:40
> 18:30:23.688:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:40 W:8
> 18:30:24.664: echo:busy: processing
> 18:30:24.684:  T:200.00 /200.00 B:60.00 /60.00 @:33 B@:32
> 18:30:24.689:  T:200.00 /200.00 B:60.00 /60.00 @:33 B@:32 W:7
> 18:30:25.684:  T:200.00 /200.00 B:60.00 /60.00 @:42 B@:29
> 18:30:25.688:  T:200.00 /200.00 B:60.00 /60.00 @:42 B@:29 W:6
> 18:30:26.665: echo:busy: processing
> 18:30:26.684:  T:199.87 /200.00 B:60.00 /60.00 @:53 B@:35
> 18:30:26.688:  T:199.87 /200.00 B:60.00 /60.00 @:53 B@:35 W:5
> 18:30:27.685:  T:199.87 /200.00 B:59.95 /60.00 @:37 B@:63
> 18:30:27.689:  T:199.87 /200.00 B:59.95 /60.00 @:37 B@:62 W:4
> 18:30:28.664: echo:busy: processing
> 18:30:28.684:  T:200.00 /200.00 B:59.95 /60.00 @:14 B@:53
> 18:30:28.689:  T:200.00 /200.00 B:59.95 /60.00 @:15 B@:53 W:3
> 18:30:29.683:  T:199.87 /200.00 B:59.95 /60.00 @:47 B@:45
> 18:30:29.688:  T:199.87 /200.00 B:59.95 /60.00 @:46 B@:45 W:2
> 18:30:30.664: echo:busy: processing
> 18:30:30.684:  T:200.00 /200.00 B:59.95 /60.00 @:30 B@:46
> 18:30:30.688:  T:200.00 /200.00 B:59.95 /60.00 @:30 B@:46 W:1
> 18:30:31.685:  T:199.87 /200.00 B:59.95 /60.00 @:44 B@:48
> 18:30:31.689:  T:199.87 /200.00 B:59.95 /60.00 @:43 B@:48 W:0
> 18:30:32.661: ok N28 P63 B26
> 18:30:32.661: ok N29 P63 B27
> 18:30:32.661: ok P63 B28
> 18:30:32.661: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:144
> 18:30:32.661: ok N30 P63 B29
> 18:30:32.662: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:144
> 18:30:32.662: ok N31 P63 B30
> 18:30:32.662: ok N32 P62 B31
< 18:30:32.662: M117 Layer 0/242
< 18:30:32.662: N33 M107
< 18:30:32.663: N34 M204 S1000
< 18:30:32.663: N35 M205 X14.1 Y14.1
> 18:30:32.663: ok P62 B30
> 18:30:32.664: ok N33 P62 B31
> 18:30:32.664: ok N34 P62 B31
> 18:30:32.664: ok N35 P62 B31
< 18:30:32.664: N36 G0 F9000 X100.206 Y50.122 Z0.25
< 18:30:32.665: N37 G1 F3000 E0
< 18:30:32.665: N38 G1 X100.687 Y49.252 E0.04546
> 18:30:32.667: ok N36 P61 B31
> 18:30:32.667: ok N37 P60 B31
> 18:30:32.667: ok N38 P59 B31
< 18:30:32.667: N39 M73 P0 R400 Q0 S400
< 18:30:32.667: @excludeTimeOn
< 18:30:32.667: @snapshot 0
< 18:30:32.667: N40 G1 F3000
< 18:30:32.668: @excludeTimeOff
< 18:30:32.668: N41 G1 X101.273 Y48.319 E0.09585
> 18:30:32.668: ok N39 P59 B31
> 18:30:32.669: ok N40 P59 B31
< 18:30:32.669: N42 G1 X101.844 Y47.513 E0.14102
> 18:30:32.670: ok N41 P58 B31
> 18:30:32.670: ok N42 P57 B31
< 18:30:32.670: N43 G1 X102.538 Y46.641 E0.19199
< 18:30:32.671: N44 G1 X103.198 Y45.902 E0.2373
> 18:30:32.672: ok N43 P56 B31
< 18:30:32.672: N45 G1 X103.971 Y45.127 E0.28736
> 18:30:32.673: ok N44 P55 B31
> 18:30:32.674: ok N45 P54 B31
< 18:30:32.674: N46 G1 X104.709 Y44.465 E0.3327
< 18:30:32.674: N47 G1 X105.591 Y43.761 E0.38431
> 18:30:32.676: ok N46 P53 B31
> 18:30:32.677: ok N47 P52 B31
< 18:30:32.677: N48 G1 X106.4 Y43.187 E0.42968
< 18:30:32.677: N49 G1 X107.33 Y42.602 E0.47992
> 18:30:32.678: ok N48 P51 B31
< 18:30:32.678: N50 G1 X108.196 Y42.122 E0.5252
> 18:30:32.680: ok N49 P50 B31
< 18:30:32.680: N51 G1 X109.198 Y41.638 E0.57609
> 18:30:32.685:  T:200.00 /200.00 B:59.95 /60.00 @:33 B@:48
> 18:30:32.685: ok N50 P49 B30
< 18:30:32.685: N52 G1 X110.113 Y41.258 E0.6214
> 18:30:32.686: ok N51 P48 B31
< 18:30:32.686: N53 G1 X111.172 Y40.887 E0.67272
> 18:30:32.688: ok N52 P47 B31
> 18:30:32.688: ok N53 P46 B31
< 18:30:32.688: N54 G1 X112.124 Y40.613 E0.71803
< 18:30:32.688: N55 G1 X113.234 Y40.362 E0.77007
> 18:30:32.691: ok N54 P45 B31
> 18:30:32.691: ok N55 P44 B31
< 18:30:32.691: N56 G1 X114.278 Y40.188 E0.81847
< 18:30:32.691: N57 G1 X115.416 Y40.065 E0.87082
> 18:30:32.693: ok N56 P43 B31
> 18:30:32.694: ok N57 P42 B31
< 18:30:32.694: N58 G1 X116.404 Y40.016 E0.91606
< 18:30:32.694: N59 G1 X117.505 Y40.023 E0.96641
> 18:30:32.696: ok N58 P41 B31
> 18:30:32.696: ok N59 P40 B31
< 18:30:32.697: N60 G1 X118.492 Y40.084 E1.01164
< 18:30:32.697: N61 G1 X119.584 Y40.213 E1.06193
> 18:30:32.699: ok N60 P39 B31
> 18:30:32.699: ok N61 P38 B31
< 18:30:32.699: N62 G1 X120.563 Y40.384 E1.10738
< 18:30:32.700: N63 G1 X121.659 Y40.64 E1.15885
> 18:30:32.702: ok N62 P37 B31
> 18:30:32.702: ok N63 P36 B31
< 18:30:32.702: N64 G1 X122.609 Y40.92 E1.20414
< 18:30:32.703: N65 G1 X123.643 Y41.288 E1.25433
> 18:30:32.705: ok N64 P35 B31
> 18:30:32.705: ok N65 P34 B31
< 18:30:32.705: N66 G1 X124.555 Y41.671 E1.29957
< 18:30:32.706: N67 G1 X125.56 Y42.162 E1.35072
> 18:30:32.708: ok N66 P33 B31
> 18:30:32.708: ok N67 P32 B31
< 18:30:32.708: N68 G1 X126.424 Y42.646 E1.39602
< 18:30:32.709: N69 G1 X127.351 Y43.234 E1.44622
> 18:30:32.713: ok N68 P31 B31
> 18:30:32.714: ok N69 P30 B31
< 18:30:32.714: N70 G1 X128.158 Y43.812 E1.49161
< 18:30:32.714: N71 G1 X129.039 Y44.524 E1.54342
> 18:30:32.716: ok N70 P29 B31
> 18:30:32.717: ok N71 P28 B31
< 18:30:32.717: N72 G1 X129.772 Y45.188 E1.58865
< 18:30:32.717: N73 G1 X130.529 Y45.952 E1.63784
> 18:30:32.719: ok N72 P27 B31
> 18:30:32.719: ok N73 P26 B31
< 18:30:32.720: N74 G1 X131.187 Y46.693 E1.68316
< 18:30:32.720: N75 G1 X131.887 Y47.578 E1.73476
> 18:30:32.722: ok N74 P26 B31
> 18:30:32.722: ok N75 P25 B31
< 18:30:32.722: N76 G1 X132.457 Y48.39 E1.78013
< 18:30:32.723: N77 G1 X133.041 Y49.33 E1.83074
> 18:30:32.725: ok N76 P24 B31
> 18:30:32.725: ok N77 P23 B31
< 18:30:32.725: N78 G1 X133.517 Y50.201 E1.87613
< 18:30:32.726: N79 G1 X133.995 Y51.207 E1.92707
> 18:30:32.728: ok N78 P22 B31
> 18:30:32.728: ok N79 P21 B31
< 18:30:32.728: N80 G1 X134.369 Y52.123 E1.97232
< 18:30:32.729: N81 G1 X134.732 Y53.176 E2.02326
> 18:30:32.731: ok N80 P20 B31
> 18:30:32.731: ok N81 P19 B31
< 18:30:32.731: N82 G1 X135.001 Y54.129 E2.06854
< 18:30:32.731: N83 G1 X135.238 Y55.19 E2.11826
> 18:30:32.736: ok N82 P18 B31
> 18:30:32.736: ok N83 P17 B31
< 18:30:32.737: N84 G1 X135.401 Y56.168 E2.1636
< 18:30:32.737: N85 G1 X135.523 Y57.286 E2.21504
> 18:30:32.739: ok N84 P16 B31
> 18:30:32.739: ok N85 P15 B31
< 18:30:32.739: N86 G1 X135.574 Y58.275 E2.26033
< 18:30:32.740: N87 G1 X135.566 Y59.424 E2.31287
> 18:30:32.742: ok N86 P14 B31
> 18:30:32.742: ok N87 P13 B31
< 18:30:32.742: N88 G1 X135.498 Y60.475 E2.36104
< 18:30:32.743: N89 G1 X135.361 Y61.599 E2.41282
> 18:30:32.745: ok N88 P12 B31
> 18:30:32.745: ok N89 P11 B31
< 18:30:32.745: N90 G1 X135.184 Y62.577 E2.45828
< 18:30:32.746: N91 G1 X134.926 Y63.652 E2.50884
> 18:30:32.748: ok N90 P10 B31
> 18:30:32.748: ok N91 P9 B31
< 18:30:32.748: N92 G1 X134.642 Y64.601 E2.55414
< 18:30:32.749: N93 G1 X134.265 Y65.646 E2.60494
> 18:30:32.751: ok N92 P8 B31
> 18:30:32.751: ok N93 P7 B31
< 18:30:32.751: N94 G1 X133.877 Y66.556 E2.65018
< 18:30:32.752: N95 G1 X133.381 Y67.558 E2.70132
> 18:30:32.754: ok N94 P6 B31
> 18:30:32.754: ok N95 P5 B31
< 18:30:32.754: N96 G1 X132.892 Y68.42 E2.74664
< 18:30:32.754: N97 G1 X132.297 Y69.345 E2.79694
> 18:30:32.757: ok N96 P4 B31
> 18:30:32.757: ok N97 P3 B31
< 18:30:32.757: N98 G1 X131.715 Y70.148 E2.84229
< 18:30:32.757: N99 G1 X131.011 Y71.012 E2.89326
> 18:30:32.760: ok N98 P2 B31
> 18:30:32.760: ok N99 P1 B31
< 18:30:32.760: N100 G1 X130.342 Y71.745 E2.93865
< 18:30:32.760: N101 G1 X129.879 Y72.222 E2.96905
> 18:30:32.763: ok N100 P0 B31
< 18:30:32.763: N102 G1 X127.156 Y74.968 E3.1459
< 18:30:33.167: M117 ETA 01:10:25 day 23
> 18:30:33.632: ok N101 P1 B29
> 18:30:33.632: ok N102 P0 B30
> 18:30:33.632: ok P0 B31
< 18:30:33.632: N103 G1 X124.547 Y77.74 E3.31999
< 18:30:33.633: N104 G1 X121.852 Y80.772 E3.50551
> 18:30:33.667: ok N103 P0 B30
< 18:30:33.667: N105 G1 X119.494 Y83.567 E3.67275
> 18:30:33.685:  T:200.00 /200.00 B:59.95 /60.00 @:23 B@:48
> 18:30:33.691: ok N104 P0 B30
< 18:30:33.691: N106 G1 X117.041 Y86.642 E3.85264
> 18:30:33.714: ok N105 P0 B30
< 18:30:33.714: N107 G1 X114.613 Y89.868 E4.03729
> 18:30:33.738: ok N106 P0 B30
< 18:30:33.738: N108 G1 X112.428 Y92.937 E4.20958
> 18:30:33.760: ok N107 P0 B30
< 18:30:33.760: N109 G1 X110.239 Y96.198 E4.3892
> 18:30:33.783: ok N108 P0 B30
< 18:30:33.783: N110 G1 X108.185 Y99.448 E4.56503
> 18:30:33.803: ok N109 P0 B30
< 18:30:33.803: N111 G1 X106.187 Y102.804 E4.74365
> 18:30:33.826: ok N110 P0 B30
< 18:30:33.826: N112 G1 X104.341 Y106.103 E4.91653
> 18:30:33.848: ok N111 P0 B30
< 18:30:33.848: N113 G1 X102.552 Y109.51 E5.09252
> 18:30:33.869: ok N112 P0 B30
< 18:30:33.869: N114 G1 X100.862 Y112.951 E5.26784
> 18:30:33.891: ok N113 P0 B30
< 18:30:33.891: N115 G1 X99.226 Y116.53 E5.44781
> 18:30:33.914: ok N114 P0 B30
< 18:30:33.914: N116 G1 X97.714 Y120.088 E5.62461
> 18:30:33.934: ok N115 P0 B30
< 18:30:33.934: N117 G1 X96.274 Y123.751 E5.80461
> 18:30:33.957: ok N116 P0 B30
< 18:30:33.957: N118 G1 X94.985 Y127.312 E5.9778
> 18:30:33.976: ok N117 P0 B30
< 18:30:33.976: N119 G1 X93.769 Y130.974 E6.15427
> 18:30:33.999: ok N118 P0 B30
< 18:30:33.999: N120 G1 X92.628 Y134.758 E6.33501
> 18:30:34.020: ok N119 P0 B30
< 18:30:34.021: N121 G1 X91.62 Y138.461 E6.51053
> 18:30:34.043: ok N120 P0 B30
< 18:30:34.044: N122 G1 X90.717 Y142.16 E6.68466
> 18:30:34.063: ok N121 P0 B30
< 18:30:34.063: N123 G1 X89.882 Y146.037 E6.86603
> 18:30:34.085: ok N122 P0 B30
< 18:30:34.086: N124 G1 X89.199 Y149.683 E7.03567
> 18:30:34.131: ok N123 P1 B31
> 18:30:34.131: ok N124 P0 B31
< 18:30:34.131: N125 G1 X88.569 Y153.659 E7.21977
< 18:30:34.132: N126 G1 X88.076 Y157.405 E7.39256
> 18:30:34.146: ok N125 P0 B30
< 18:30:34.146: N127 G1 X87.677 Y161.239 E7.56885
> 18:30:34.169: ok N126 P0 B30
< 18:30:34.169: N128 G1 X87.382 Y165.077 E7.74489
> 18:30:34.189: ok N127 P0 B30
< 18:30:34.190: N129 G1 X87.188 Y168.966 E7.92297
> 18:30:34.211: ok N128 P0 B30
< 18:30:34.211: N130 G1 X87.102 Y172.817 E8.09913
> 18:30:34.230: ok N129 P0 B30
< 18:30:34.230: N131 G1 X87.118 Y176.646 E8.27424
> 18:30:34.253: ok N130 P0 B30
< 18:30:34.253: N132 G1 X87.239 Y180.511 E8.45108
> 18:30:34.273: ok N131 P0 B30
< 18:30:34.274: N133 G1 X87.464 Y184.358 E8.62732
> 18:30:34.295: ok N132 P0 B30
< 18:30:34.295: N134 G1 X87.809 Y188.342 E8.8102
> 18:30:34.314: ok N133 P0 B30
< 18:30:34.315: N135 G1 X87.919 Y189.317 E8.85507
> 18:30:34.337: ok N134 P0 B30
< 18:30:34.337: N136 G1 X89.114 Y189.618 E8.91143
> 18:30:34.357: ok N135 P0 B30
< 18:30:34.358: N137 G1 X89.885 Y189.846 E8.9482
> 18:30:34.378: ok N136 P0 B30
< 18:30:34.378: N138 G1 X91.226 Y190.306 E9.01303
> 18:30:34.398: ok N137 P0 B30
< 18:30:34.399: N139 G1 X91.786 Y190.08 E9.04065
> 18:30:34.421: ok N138 P0 B30
< 18:30:34.421: N140 G1 X92.637 Y189.822 E9.08132
> 18:30:34.440: ok N139 P0 B30
< 18:30:34.441: N141 G1 X93.264 Y189.685 E9.11067
> 18:30:34.474: ok N140 P0 B30
< 18:30:34.474: N142 G1 X93.56 Y189.63 E9.12444
> 18:30:34.497: ok N141 P0 B30
< 18:30:34.497: N143 G1 X94.442 Y189.507 E9.16516
> 18:30:34.505: ok N142 P0 B30
< 18:30:34.505: N144 G1 X95.33 Y189.463 E9.20582
> 18:30:34.524: ok N143 P0 B30
< 18:30:34.525: N145 G1 X96.219 Y189.5 E9.24651
> 18:30:34.547: ok N144 P0 B30
< 18:30:34.548: N146 G1 X96.858 Y189.576 E9.27594
> 18:30:34.567: ok N145 P0 B30
< 18:30:34.567: N147 G1 X97.121 Y189.616 E9.28811
> 18:30:34.631: ok N146 P1 B30
> 18:30:34.631: ok N147 P1 B31
< 18:30:34.631: N148 G1 X97.993 Y189.789 E9.32877
< 18:30:34.632: N149 G1 X98.847 Y190.04 E9.36947
> 18:30:34.634: ok N148 P0 B31
< 18:30:34.634: N150 G1 X99.974 Y190.506 E9.42525
> 18:30:34.651: ok N149 P0 B30
< 18:30:34.651: N151 G1 X100.226 Y190.629 E9.43807
> 18:30:34.673: ok N150 P0 B30
< 18:30:34.674: N152 G1 X101.008 Y191.055 E9.4788
> 18:30:34.684:  T:200.18 /200.00 B:60.00 /60.00 @:19 B@:35
> 18:30:34.695: ok N151 P0 B30
< 18:30:34.695: N153 G1 X101.683 Y191.502 E9.51582
> 18:30:34.718: ok N152 P0 B30
< 18:30:34.718: N154 G1 X104.078 Y193.233 E9.65096
> 18:30:34.737: ok N153 P0 B30
< 18:30:34.737: N155 G1 X106.395 Y194.787 E9.77855
> 18:30:34.759: ok N154 P0 B30
< 18:30:34.759: N156 G1 X108.73 Y196.237 E9.90425
> 18:30:34.780: ok N155 P0 B30
< 18:30:34.780: N157 G1 X111.152 Y197.628 E10.03198
> 18:30:34.801: ok N156 P0 B30
< 18:30:34.801: N158 G1 X113.585 Y198.914 E10.15784
> 18:30:34.822: ok N157 P0 B30
< 18:30:34.822: N159 G1 X116.099 Y200.134 E10.28563
> 18:30:34.843: ok N158 P0 B30
< 18:30:34.843: N160 G1 X118.612 Y201.246 E10.41131
> 18:30:34.864: ok N159 P0 B30
< 18:30:34.864: N161 G1 X121.219 Y202.295 E10.53982
> 18:30:34.895: ok N160 P0 B30
< 18:30:34.895: N162 G1 X123.796 Y203.224 E10.6651
> 18:30:34.917: ok N161 P0 B30
< 18:30:34.917: N163 G1 X126.421 Y204.072 E10.79126
> 18:30:34.927: ok N162 P0 B30
< 18:30:34.928: N164 G1 X129.103 Y204.836 E10.91879
> 18:30:34.948: ok N163 P0 B30
< 18:30:34.948: N165 G1 X131.829 Y205.511 E11.04723
> 18:30:34.961: ok N164 P0 B30
< 18:30:34.961: N166 G1 X134.485 Y206.07 E11.17135
> 18:30:35.038: ok N165 P0 B30
< 18:30:35.038: N167 G1 X137.253 Y206.553 E11.29985
> 18:30:35.131: ok N166 P0 B30
< 18:30:35.131: N168 G1 X139.98 Y206.933 E11.42577
> 18:30:35.196: ok N167 P0 B30
< 18:30:35.196: N169 G1 X142.73 Y207.218 E11.55221
> 18:30:35.269: ok N168 P0 B30
< 18:30:35.269: N170 G1 X145.517 Y207.409 E11.67997
> 18:30:35.347: ok N169 P0 B30
< 18:30:35.347: N171 G1 X148.261 Y207.502 E11.80553
> 18:30:35.428: ok N170 P0 B30
< 18:30:35.428: N172 G1 X151.036 Y207.498 E11.93244
> 18:30:35.504: ok N171 P0 B30
< 18:30:35.504: N173 G1 X153.833 Y207.399 E12.06043
> 18:30:35.582: ok N172 P0 B30
< 18:30:35.582: N174 G1 X156.561 Y207.205 E12.1855
> 18:30:35.658: ok N173 P0 B30
< 18:30:35.658: N175 G1 X159.331 Y206.911 E12.3129
> 18:30:35.685:  T:200.18 /200.00 B:59.90 /60.00 @:28 B@:73
> 18:30:35.737: ok N174 P0 B30
< 18:30:35.737: N176 G1 X162.104 Y206.519 E12.44097
> 18:30:35.813: ok N175 P0 B30
< 18:30:35.813: N177 G1 X164.804 Y206.042 E12.56636
> 18:30:35.889: ok N176 P0 B30
< 18:30:35.890: N178 G1 X167.517 Y205.463 E12.69323
> 18:30:35.966: ok N177 P0 B30
< 18:30:35.966: N179 G1 X170.198 Y204.793 E12.81961
> 18:30:36.045: ok N178 P0 B30
< 18:30:36.045: N180 G1 X172.878 Y204.025 E12.94711
> 18:30:36.130: ok N179 P0 B30
< 18:30:36.130: N181 G1 X175.497 Y203.172 E13.07307
> 18:30:36.201: ok N180 P0 B30
< 18:30:36.201: N182 G1 X178.123 Y202.216 E13.20088
> 18:30:36.276: ok N181 P0 B30
< 18:30:36.276: N183 G1 X180.66 Y201.191 E13.32601
> 18:30:36.373: ok N182 P0 B30
< 18:30:36.373: N184 G1 X183.223 Y200.05 E13.45432
> 18:30:36.433: ok N183 P0 B30
< 18:30:36.433: N185 G1 X185.707 Y198.839 E13.5807
> 18:30:36.510: ok N184 P0 B30
< 18:30:36.510: N186 G1 X188.157 Y197.537 E13.70758
> 18:30:36.639: ok N185 P0 B30
< 18:30:36.639: N187 G1 X190.397 Y196.248 E13.82577
> 18:30:36.664: ok N186 P0 B30
< 18:30:36.664: N188 G1 X192.76 Y194.781 E13.95297
> 18:30:36.684:  T:200.18 /200.00 B:59.95 /60.00 @:30 B@:54
> 18:30:36.740: ok N187 P0 B30
< 18:30:36.740: N189 G1 X195.216 Y193.129 E14.08834
> 18:30:36.820: ok N188 P0 B30
< 18:30:36.820: N190 G1 X197.443 Y191.517 E14.21406
> 18:30:36.895: ok N189 P0 B30
< 18:30:36.895: N191 G1 X198.186 Y191.028 E14.25474
> 18:30:36.972: ok N190 P0 B30
< 18:30:36.972: N192 G1 X198.596 Y190.798 E14.27624
> 18:30:37.049: ok N191 P0 B30
< 18:30:37.049: N193 G1 X198.829 Y190.674 E14.28831
> 18:30:37.139: ok N192 P0 B30
< 18:30:37.139: N194 G1 X199.632 Y190.291 E14.329
> 18:30:37.204: ok N193 P0 B30
< 18:30:37.205: N195 G1 X200.467 Y189.983 E14.3697
> 18:30:37.294: ok N194 P0 B30
< 18:30:37.294: N196 G1 X201.326 Y189.75 E14.41041
> 18:30:37.358: ok N195 P0 B30
< 18:30:37.358: N197 G1 X201.768 Y189.662 E14.43102
> 18:30:37.436: ok N196 P0 B30
< 18:30:37.436: N198 G1 X202.047 Y189.613 E14.44397
> 18:30:37.515: ok N197 P0 B30
< 18:30:37.515: N199 G1 X202.929 Y189.499 E14.48464
> 18:30:37.546: ok N198 P0 B30
< 18:30:37.546: N200 G1 X203.818 Y189.464 E14.52533
> 18:30:37.583: ok N199 P0 B30
< 18:30:37.583: N201 G1 X204.706 Y189.509 E14.56599
> 18:30:37.638: ok N200 P1 B30
> 18:30:37.639: ok N201 P0 B31
< 18:30:37.639: N202 G1 X205.291 Y189.583 E14.59296
< 18:30:37.639: N203 G1 X205.591 Y189.63 E14.60685
> 18:30:37.649: ok N202 P0 B30
< 18:30:37.649: N204 G1 X206.463 Y189.807 E14.64754
> 18:30:37.667: ok N203 P0 B30
< 18:30:37.667: N205 G1 X207.316 Y190.062 E14.68825
> 18:30:37.685:  T:200.18 /200.00 B:59.95 /60.00 @:27 B@:58
> 18:30:37.685: ok N204 P0 B30
< 18:30:37.685: N206 G1 X207.924 Y190.305 E14.7182
> 18:30:37.687: ok N205 P0 B31
< 18:30:37.687: N207 G1 X208.032 Y190.263 E14.7235
> 18:30:37.705: ok N206 P0 B30
< 18:30:37.705: N208 G1 X209.355 Y189.817 E14.78735
> 18:30:37.723: ok N207 P0 B30
< 18:30:37.723: N209 G1 X210.136 Y189.589 E14.82456
> 18:30:37.741: ok N208 P0 B30
< 18:30:37.741: N210 G1 X211.228 Y189.318 E14.87601
> 18:30:37.755: ok N209 P0 B30
< 18:30:37.755: N211 G1 X211.366 Y188.099 E14.93212
> 18:30:37.762: ok N210 P0 B30
< 18:30:37.762: N212 G1 X211.69 Y184.288 E15.10703
> 18:30:37.780: ok N211 P0 B30
< 18:30:37.780: N213 G1 X211.916 Y180.373 E15.28637
> 18:30:37.797: ok N212 P0 B30
< 18:30:37.798: N214 G1 X212.033 Y176.55 E15.46129
> 18:30:37.823: ok N213 P0 B30
< 18:30:37.823: N215 G1 X212.047 Y172.657 E15.63933
> 18:30:37.829: ok N214 P0 B30
< 18:30:37.830: N216 G1 X211.956 Y168.806 E15.8155
> 18:30:37.847: ok N215 P0 B30
< 18:30:37.847: N217 G1 X211.76 Y164.943 E15.99239
> 18:30:37.864: ok N216 P0 B30
< 18:30:37.864: N218 G1 X211.461 Y161.109 E16.16826
> 18:30:37.923: ok N217 P0 B30
< 18:30:37.923: N219 G1 X211.054 Y157.239 E16.34622
> 18:30:37.978: ok N218 P0 B30
< 18:30:37.979: N220 G1 X210.541 Y153.379 E16.5243
> 18:30:38.033: ok N219 P0 B30
< 18:30:38.033: N221 G1 X209.936 Y149.608 E16.69896
> 18:30:38.089: ok N220 P0 B30
< 18:30:38.090: N222 G1 X209.219 Y145.798 E16.87626
> 18:30:38.160: ok N221 P0 B30
< 18:30:38.160: N223 G1 X208.395 Y141.994 E17.05427
> 18:30:38.200: ok N222 P0 B30
< 18:30:38.200: N224 G1 X207.485 Y138.283 E17.22901
> 18:30:38.255: ok N223 P0 B30
< 18:30:38.256: N225 G1 X206.452 Y134.509 E17.40795
> 18:30:38.311: ok N224 P0 B30
< 18:30:38.311: N226 G1 X205.335 Y130.829 E17.58383
> 18:30:38.366: ok N225 P0 B30
< 18:30:38.366: N227 G1 X204.117 Y127.173 E17.76006
> 18:30:38.422: ok N226 P0 B30
< 18:30:38.422: N228 G1 X202.779 Y123.496 E17.93901
> 18:30:38.477: ok N227 P0 B30
< 18:30:38.477: N229 G1 X201.375 Y119.938 E18.11394
> 18:30:38.533: ok N228 P0 B30
< 18:30:38.534: N230 G1 X199.851 Y116.364 E18.29163
> 18:30:38.588: ok N229 P0 B30
< 18:30:38.588: N231 G1 X198.247 Y112.866 E18.46761
> 18:30:38.643: ok N230 P0 B30
< 18:30:38.643: N232 G1 X196.523 Y109.361 E18.64625
> 18:30:38.685:  T:200.18 /200.00 B:60.00 /60.00 @:42 B@:44
> 18:30:38.698: ok N231 P0 B30
< 18:30:38.698: N233 G1 X194.752 Y105.998 E18.82007
> 18:30:38.754: ok N232 P0 B30
< 18:30:38.754: N234 G1 X192.83 Y102.571 E18.99976
> 18:30:38.809: ok N233 P0 B30
< 18:30:38.809: N235 G1 X190.864 Y99.281 E19.17504
> 18:30:38.865: ok N234 P0 B30
< 18:30:38.865: N236 G1 X188.787 Y96.007 E19.35236
> 18:30:38.920: ok N235 P0 B30
< 18:30:38.920: N237 G1 X186.613 Y92.779 E19.53034
> 18:30:39.684:  T:200.00 /200.00 B:59.95 /60.00 @:64 B@:53
> 18:30:40.684:  T:200.18 /0.00 B:59.95 /0.00 @:0 B@:0
> 18:30:41.684:  T:200.18 /0.00 B:59.90 /0.00 @:0 B@:0
> 18:30:41.920: echo:busy: processing
> 18:30:42.684:  T:200.18 /0.00 B:59.90 /0.00 @:0 B@:0
< 18:30:43.170: M117 ETE 06:39:46
> 18:30:43.684:  T:199.87 /0.00 B:59.84 /0.00 @:0 B@:0
> 18:30:43.920: echo:busy: processing
> 18:30:44.704:  T:199.61 /0.00 B:59.74 /0.00 @:0 B@:0
> 18:30:45.704:  T:199.34 /0.00 B:59.74 /0.00 @:0 B@:0
> 18:30:45.920: echo:busy: processing
> 18:30:46.704:  T:199.08 /0.00 B:59.64 /0.00 @:0 B@:0
> 18:30:47.704:  T:198.82 /0.00 B:59.64 /0.00 @:0 B@:0
> 18:30:47.921: echo:busy: processing
> 18:30:48.704:  T:198.29 /0.00 B:59.53 /0.00 @:0 B@:0
> 18:30:49.705:  T:198.16 /0.00 B:59.53 /0.00 @:0 B@:0
> 18:30:49.921: echo:busy: processing
> 18:30:50.705:  T:197.24 /0.00 B:59.38 /0.00 @:0 B@:0
> 18:30:51.704:  T:196.97 /0.00 B:59.38 /0.00 @:0 B@:0
> 18:30:51.921: echo:busy: processing
> 18:30:52.705:  T:196.32 /0.00 B:59.27 /0.00 @:0 B@:0
> 18:30:53.705:  T:195.79 /0.00 B:59.22 /0.00 @:0 B@:0
> 18:30:53.921: echo:busy: processing
> 18:30:53.938: X:0.00 Y:0.00 Z:3.64 E:0.00 Count X:0 Y:0 Z:1600
> 18:30:53.938: Warning: Missed line detected - correcting buffer usage.
> 18:30:53.938: ok N237 P63 B30
> 18:30:53.938: ok N237 P62 B30
> 18:30:53.939: ok P62 B31
< 18:30:53.939: M117 Layer 1/242
< 18:30:53.939: N238 G1 X184.394 Y89.67 E19.70502
< 18:30:53.939: N239 G1 X182.04 Y86.552 E19.88369
> 18:30:53.941: ok P62 B31
> 18:30:53.941: ok N238 P61 B31
> 18:30:53.941: ok N239 P60 B31
< 18:30:53.941: N240 G1 X179.634 Y83.54 E20.05999
< 18:30:53.942: N241 G1 X177.147 Y80.595 E20.23627
> 18:30:53.943: ok N240 P59 B31
< 18:30:53.943: N242 G1 X174.561 Y77.695 E20.41397
> 18:30:53.944: ok N241 P58 B31
> 18:30:53.944: ok N242 P57 B31
< 18:30:53.945: N243 G1 X171.916 Y74.885 E20.59045
< 18:30:53.945: N244 G1 X169.051 Y72 E20.7764
> 18:30:53.947: ok N243 P56 B31
> 18:30:53.947: ok N244 P55 B31
< 18:30:53.947: N245 G1 X168.774 Y71.709 E20.79477
< 18:30:53.948: N246 G1 X168.146 Y71.023 E20.83731
> 18:30:53.950: ok N245 P54 B31
> 18:30:53.950: ok N246 P53 B31
< 18:30:53.950: N247 G1 X167.439 Y70.157 E20.88843
< 18:30:53.951: N248 G1 X166.857 Y69.356 E20.93371
> 18:30:53.953: ok N247 P52 B31
> 18:30:53.953: ok N248 P51 B31
< 18:30:53.953: N249 G1 X166.253 Y68.418 E20.98473
< 18:30:53.954: N250 G1 X165.764 Y67.555 E21.0301
> 18:30:53.956: ok N249 P50 B31
> 18:30:53.956: ok N250 P49 B31
< 18:30:53.957: N251 G1 X165.27 Y66.557 E21.08102
< 18:30:53.957: N252 G1 X164.882 Y65.647 E21.12627
> 18:30:53.981: ok N251 P48 B30
< 18:30:53.981: N253 G1 X164.505 Y64.602 E21.17707
> 18:30:54.006: ok N252 P47 B30
> 18:30:54.006: ok N253 P46 B31
< 18:30:54.006: N254 G1 X164.221 Y63.653 E21.22237
< 18:30:54.007: N255 G1 X163.964 Y62.58 E21.27283
> 18:30:54.008: ok N254 P45 B31
> 18:30:54.009: ok N255 P44 B31
< 18:30:54.009: N256 G1 X163.787 Y61.603 E21.31824
< 18:30:54.009: N257 G1 X163.647 Y60.459 E21.37095
> 18:30:54.011: ok N256 P43 B31
> 18:30:54.012: ok N257 P42 B31
< 18:30:54.012: N258 G1 X163.581 Y59.409 E21.41906
< 18:30:54.012: N259 G1 X163.575 Y58.278 E21.47079
> 18:30:54.014: ok N258 P41 B31
> 18:30:54.014: ok N259 P40 B31
< 18:30:54.015: N260 G1 X163.626 Y57.289 E21.51608
< 18:30:54.015: N261 G1 X163.746 Y56.184 E21.56691
> 18:30:54.017: ok N260 P39 B31
> 18:30:54.017: ok N261 P38 B31
< 18:30:54.017: N262 G1 X163.908 Y55.204 E21.61233
< 18:30:54.018: N263 G1 X164.149 Y54.124 E21.66294
> 18:30:54.020: ok N262 P37 B31
> 18:30:54.020: ok N263 P36 B31
< 18:30:54.020: N264 G1 X164.418 Y53.173 E21.70814
< 18:30:54.021: N265 G1 X164.783 Y52.116 E21.75928
> 18:30:54.023: ok N264 P35 B31
> 18:30:54.023: ok N265 P34 B31
< 18:30:54.023: N266 G1 X165.159 Y51.198 E21.80465
< 18:30:54.024: N267 G1 X165.626 Y50.214 E21.85446
> 18:30:54.026: ok N266 P33 B31
> 18:30:54.026: ok N267 P32 B31
< 18:30:54.026: N268 G1 X166.101 Y49.342 E21.89987
< 18:30:54.026: N269 G1 X166.693 Y48.389 E21.95118
> 18:30:54.029: ok N268 P31 B31
> 18:30:54.029: ok N269 P30 B31
< 18:30:54.029: N270 G1 X167.261 Y47.58 E21.99638
< 18:30:54.029: N271 G1 X167.951 Y46.706 E22.04731
> 18:30:54.032: ok N270 P29 B31
> 18:30:54.032: ok N271 P28 B31
< 18:30:54.032: N272 G1 X168.608 Y45.964 E22.09263
< 18:30:54.032: N273 G1 X169.368 Y45.195 E22.14208
> 18:30:54.034: ok N272 P27 B31
> 18:30:54.035: ok N273 P26 B31
< 18:30:54.035: N274 G1 X170.102 Y44.529 E22.18741
< 18:30:54.035: N275 G1 X170.983 Y43.817 E22.23921
> 18:30:54.038: ok N274 P25 B31
> 18:30:54.038: ok N275 P24 B31
< 18:30:54.038: N276 G1 X171.79 Y43.238 E22.28463
< 18:30:54.038: N277 G1 X172.722 Y42.645 E22.33515
> 18:30:54.040: ok N276 P23 B31
> 18:30:54.041: ok N277 P22 B31
< 18:30:54.041: N278 G1 X173.584 Y42.162 E22.38034
< 18:30:54.042: N279 G1 X174.588 Y41.672 E22.43143
> 18:30:54.043: ok N278 P21 B31
< 18:30:54.043: N280 G1 X175.502 Y41.288 E22.47677
> 18:30:54.044: ok N279 P20 B31
< 18:30:54.044: N281 G1 X176.55 Y40.915 E22.52764
> 18:30:54.045: ok N280 P19 B31
< 18:30:54.045: N282 G1 X177.501 Y40.636 E22.57297
> 18:30:54.047: ok N281 P18 B31
> 18:30:54.047: ok N282 P17 B31
< 18:30:54.047: N283 G1 X178.573 Y40.386 E22.62331
< 18:30:54.048: N284 G1 X179.551 Y40.214 E22.66872
> 18:30:54.050: ok N283 P16 B31
> 18:30:54.050: ok N284 P15 B31
< 18:30:54.050: N285 G1 X180.702 Y40.08 E22.72172
< 18:30:54.051: N286 G1 X181.753 Y40.02 E22.76986
> 18:30:54.053: ok N285 P14 B31
> 18:30:54.053: ok N286 P13 B31
< 18:30:54.053: N287 G1 X182.877 Y40.02 E22.82126
< 18:30:54.053: N288 G1 X183.866 Y40.076 E22.86656
> 18:30:54.056: ok N287 P12 B31
> 18:30:54.056: ok N288 P11 B31
< 18:30:54.056: N289 G1 X184.971 Y40.201 E22.91742
< 18:30:54.056: N290 G1 X185.95 Y40.368 E22.96284
> 18:30:54.059: ok N289 P10 B31
> 18:30:54.059: ok N290 P9 B31
< 18:30:54.059: N291 G1 X187.032 Y40.616 E23.01361
< 18:30:54.059: N292 G1 X187.984 Y40.891 E23.05892
> 18:30:54.062: ok N291 P8 B31
> 18:30:54.062: ok N292 P7 B31
< 18:30:54.062: N293 G1 X189.033 Y41.259 E23.10976
< 18:30:54.062: N294 G1 X189.946 Y41.638 E23.15497
> 18:30:54.064: ok N293 P6 B31
> 18:30:54.065: ok N294 P5 B31
< 18:30:54.065: N295 G1 X190.945 Y42.12 E23.2057
< 18:30:54.065: N296 G1 X191.812 Y42.6 E23.25102
> 18:30:54.067: ok N295 P4 B31
> 18:30:54.068: ok N296 P3 B31
< 18:30:54.068: N297 G1 X192.744 Y43.186 E23.30137
< 18:30:54.068: N298 G1 X193.552 Y43.759 E23.34667
> 18:30:54.070: ok N297 P2 B31
> 18:30:54.071: ok N298 P1 B31
< 18:30:54.071: N299 G1 X194.425 Y44.455 E23.39773
< 18:30:54.071: N300 G1 X195.164 Y45.116 E23.44307
> 18:30:54.073: ok N299 P0 B31
< 18:30:54.074: N301 G1 X195.938 Y45.89 E23.49313
> 18:30:54.706:  T:195.13 /0.00 B:59.11 /0.00 @:0 B@:0
> 18:30:55.705:  T:194.61 /0.00 B:59.11 /0.00 @:0 B@:0
< 18:30:55.984: ;@execute pi_temp
< 18:30:55.987: ;@execute enclosure
> 18:30:56.073: echo:busy: processing
> 18:30:56.705:  T:194.08 /0.00 B:59.06 /0.00 @:0 B@:0
< 18:30:57.322: @stopLog
Thanks for your help.
  • When you say LCD I assume you mean a firmware controlled display. That does normally not work. Firmware would need to send
    // action:cancel
    to ask server to stop - if not server will continue to print and what you saw was a firmware internal action that had nothing to do with server. I did not see any message from firmware that you pressed stop so it is also not possible to teach server that message.
  • Yes LCD is the firmware controlled display.  Thanks for the quick response.
  • @Repetier ,
    Enabling HOST_ACTION_COMMANDS in firmware which enables "// action:<command>" messages from the firmware to the host works perfectly when selecting PAUSE or CANCEL from the firmware controlled LCD.  Repetier-Server will pause/stop as commanded.
    Thanks.
  • Thanks. Good to know that marlin has also the option to be compiled with host support in mind. These are exactly the commands already implemented and well known.
  • TheJoshW said:
    @Repetier ,
    Thanks.
    when i enable #define HOST_ACTION_COMMANDS then i need nothing more to due ?
    or i need to define my commands ?
  • when i enable #define HOST_ACTION_COMMANDS then i need nothing more to due ?
    no it should just work as Repetier-Server already recognises the action: commands.
