Filament Runout not pushing message to Repetier-Informer
I am using Repetier Server Pro 0.93.1 on a Raspberry Pi 3B+ and my printer uses an SKRv1.4 controller with Marlin 2.0.5.3 firmware.
The log below contains the line:
> 16:27:41.690: echo:Insert filament and send M108
I have added this to /usr/local/Repetier-Server/firmware/repetier.xml as:
<response type="outOfFilament">^echo:Insert filament and send M108</response>
And various variations including:
<response type="outOfFilament">Insert filament</response>
And rebooted the server each time, however whenever the firmware detects a jam, the message is not pushed to Repetier-Informer (all other messages work in Repetier-Informer, and all message types are turned on in Repetier-Server).
Is there something else I am misssing?
See the following print log extract when the firmware detects a filament runout:
< 16:26:12.482: N15 M73 P0 R76 Q0 S76
> 16:26:13.982: ok N15 P63 B31
> 16:26:13.982:  T:200.36 /200.00 B:60.05 /60.00 @:25 B@:22
> 16:26:13.983:  T:200.18 /200.00 B:60.05 /60.00 @:62 B@:0
< 16:26:13.983: N16 G90                       ; Use absolute coordinates
< 16:26:13.983: N17 M82                       ; Set E codes absolute (default)
< 16:26:13.983: N18 M107                      ; RepRap Fan off
> 16:26:13.984: Slow command added:G28                       ; Home all axis
< 16:26:13.984: N19 G28                       ; Home all axis
< 16:26:13.984: N20 G1 Z0.16
< 16:26:13.984: N21 G92 Z0 E0                 ; Reset Z and Extruder
< 16:26:13.984: ;@execute pi_temp
< 16:26:13.987: ;@execute enclosure
< 16:26:13.989: N22 M140 S60
> 16:26:14.028: ok N16 P63 B31
> 16:26:14.029: ok N17 P63 B26
> 16:26:14.029: ok N18 P63 B27
< 16:26:14.029: N23 M105
> 16:26:14.029: Slow command added:M190 S60
< 16:26:14.029: N24 M190 S60
> 16:26:14.571:  T:200.18 /200.00 B:60.00 /60.00 @:29 B@:3
> 16:26:15.572:  T:200.00 /200.00 B:59.90 /60.00 @:67 B@:40
> 16:26:16.029: echo:busy: processing
> 16:26:16.572:  T:200.18 /200.00 B:59.90 /60.00 @:32 B@:10
> 16:26:17.572:  T:200.18 /200.00 B:59.84 /60.00 @:54 B@:24
> 16:26:18.029: echo:busy: processing
> 16:26:18.571:  T:200.36 /200.00 B:59.84 /60.00 @:4 B@:11
> 16:26:19.571:  T:200.18 /200.00 B:59.79 /60.00 @:50 B@:31
> 16:26:20.030: echo:busy: processing
> 16:26:20.574:  T:200.54 /200.00 B:59.74 /60.00 @:0 B@:37
> 16:26:21.574:  T:200.18 /200.00 B:59.69 /60.00 @:43 B@:50
> 16:26:22.030: echo:busy: processing
> 16:26:22.575:  T:200.36 /200.00 B:59.69 /60.00 @:23 B@:54
> 16:26:23.574:  T:200.36 /200.00 B:59.69 /60.00 @:26 B@:45
> 16:26:24.030: echo:busy: processing
> 16:26:24.573:  T:200.36 /200.00 B:59.69 /60.00 @:22 B@:48
> 16:26:25.573:  T:200.18 /200.00 B:59.74 /60.00 @:61 B@:33
> 16:26:25.922: X:0.00 Y:0.00 Z:0.32 E:0.00 Count X:0 Y:0 Z:128
> 16:26:25.922: ok N19 P63 B26
> 16:26:25.922: ok N20 P62 B27
> 16:26:25.922: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:128
> 16:26:25.922: ok N21 P62 B28
> 16:26:25.922: ok N22 P62 B29
< 16:26:25.922: M117 ETA 17:34:45 day 26
< 16:26:25.923: N25 M104 S200
< 16:26:25.923: N26 M105
> 16:26:25.923: Slow command added:M109 S200
< 16:26:25.923: N27 M109 S200
> 16:26:25.927: ok T:200.36 /200.00 B:59.69 /60.00 @:0 B@:63
< 16:26:25.927: N28 M82 ;absolute extrusion mode
> 16:26:25.931:  T:200.36 /200.00 B:59.69 /60.00 @:0 B@:63 W:?
> 16:26:26.574:  T:200.18 /200.00 B:59.69 /60.00 @:24 B@:67
> 16:26:26.932:  T:200.18 /200.00 B:59.69 /60.00 @:27 B@:60 W:19
> 16:26:27.574:  T:200.00 /200.00 B:59.74 /60.00 @:33 B@:44
> 16:26:27.926: echo:busy: processing
> 16:26:27.931:  T:200.00 /200.00 B:59.74 /60.00 @:43 B@:68 W:18
> 16:26:28.574:  T:200.00 /200.00 B:59.74 /60.00 @:47 B@:58
> 16:26:28.931:  T:200.00 /200.00 B:59.79 /60.00 @:62 B@:51 W:17
> 16:26:29.574:  T:200.00 /200.00 B:59.79 /60.00 @:32 B@:53
> 16:26:29.931:  T:200.00 /200.00 B:59.79 /60.00 @:30 B@:51 W:16
> 16:26:29.932: echo:busy: processing
> 16:26:30.573:  T:200.00 /200.00 B:59.79 /60.00 @:30 B@:66
> 16:26:30.931:  T:200.00 /200.00 B:59.84 /60.00 @:30 B@:48 W:15
> 16:26:31.573:  T:200.00 /200.00 B:59.84 /60.00 @:20 B@:51
> 16:26:31.932:  T:200.00 /200.00 B:59.90 /60.00 @:28 B@:43 W:14
> 16:26:31.932: echo:busy: processing
> 16:26:32.574:  T:199.87 /200.00 B:59.84 /60.00 @:60 B@:56
> 16:26:32.933:  T:199.87 /200.00 B:59.90 /60.00 @:36 B@:29 W:13
> 16:26:33.575:  T:199.87 /200.00 B:59.90 /60.00 @:39 B@:71
> 16:26:33.932:  T:200.00 /200.00 B:59.90 /60.00 @:11 B@:60 W:12
> 16:26:33.932: echo:busy: processing
> 16:26:34.574:  T:199.87 /200.00 B:59.95 /60.00 @:33 B@:41
> 16:26:34.932:  T:199.87 /200.00 B:59.95 /60.00 @:31 B@:43 W:11
> 16:26:35.574:  T:200.00 /200.00 B:60.00 /60.00 @:15 B@:37
> 16:26:35.932:  T:199.87 /200.00 B:60.00 /60.00 @:46 B@:41 W:10
> 16:26:35.932: echo:busy: processing
> 16:26:36.584:  T:199.87 /200.00 B:60.00 /60.00 @:43 B@:45
> 16:26:36.933:  T:200.00 /200.00 B:59.95 /60.00 @:22 B@:67 W:9
> 16:26:37.583:  T:200.00 /200.00 B:60.05 /60.00 @:27 B@:54
> 16:26:37.932:  T:200.00 /200.00 B:60.05 /60.00 @:30 B@:45 W:8
> 16:26:37.932: echo:busy: processing
> 16:26:38.584:  T:199.87 /200.00 B:60.09 /60.00 @:52 B@:15
> 16:26:38.932:  T:199.87 /200.00 B:60.09 /60.00 @:35 B@:30 W:7
> 16:26:39.584:  T:200.00 /200.00 B:60.05 /60.00 @:37 B@:48
> 16:26:39.932:  T:200.00 /200.00 B:60.09 /60.00 @:31 B@:32 W:6
> 16:26:39.932: echo:busy: processing
> 16:26:40.583:  T:200.00 /200.00 B:60.09 /60.00 @:25 B@:37
> 16:26:40.931:  T:199.87 /200.00 B:60.09 /60.00 @:47 B@:37 W:5
> 16:26:41.582:  T:200.00 /200.00 B:60.09 /60.00 @:25 B@:36
> 16:26:41.931:  T:200.00 /200.00 B:60.14 /60.00 @:14 B@:20 W:4
> 16:26:41.931: echo:busy: processing
> 16:26:42.583:  T:199.87 /200.00 B:60.19 /60.00 @:37 B@:8
> 16:26:42.931:  T:200.00 /200.00 B:60.14 /60.00 @:26 B@:40 W:3
> 16:26:43.582:  T:199.87 /200.00 B:60.14 /60.00 @:53 B@:30
> 16:26:43.945: echo:busy: processing
> 16:26:43.949:  T:200.00 /200.00 B:60.14 /60.00 @:13 B@:42 W:1
> 16:26:44.583:  T:199.87 /200.00 B:60.19 /60.00 @:34 B@:7
> 16:26:44.949:  T:199.87 /200.00 B:60.14 /60.00 @:32 B@:38 W:0
> 16:26:45.582:  T:199.87 /200.00 B:60.19 /60.00 @:32 B@:16
> 16:26:45.928: ok N24 P63 B26
> 16:26:45.928: ok P63 B27
> 16:26:45.928: ok N25 P63 B28
< 16:26:45.928: M117 ETE 01:06:10
< 16:26:45.928: N29 G92 E0
< 16:26:45.928: N30 G92 E0
> 16:26:45.932: ok T:200.00 /200.00 B:60.19 /60.00 @:22 B@:21
< 16:26:45.932: N31 G1 F3000 E-0.75
> 16:26:45.937:  T:200.00 /200.00 B:60.19 /60.00 @:23 B@:21 W:?
> 16:26:46.584:  T:200.00 /200.00 B:60.19 /60.00 @:19 B@:18
> 16:26:46.936:  T:200.00 /200.00 B:60.19 /60.00 @:22 B@:27 W:19
> 16:26:47.583:  T:199.87 /200.00 B:60.14 /60.00 @:39 B@:45
> 16:26:47.936:  T:199.87 /200.00 B:60.19 /60.00 @:33 B@:17 W:18
> 16:26:47.936: echo:busy: processing
> 16:26:48.583:  T:199.87 /200.00 B:60.19 /60.00 @:51 B@:9
> 16:26:48.936:  T:200.00 /200.00 B:60.19 /60.00 @:19 B@:23 W:17
> 16:26:49.583:  T:199.87 /200.00 B:60.19 /60.00 @:55 B@:14
> 16:26:49.935:  T:199.87 /200.00 B:60.19 /60.00 @:36 B@:12 W:16
> 16:26:49.935: echo:busy: processing
> 16:26:50.583:  T:199.87 /200.00 B:60.19 /60.00 @:45 B@:11
> 16:26:50.936:  T:200.00 /200.00 B:60.19 /60.00 @:27 B@:3 W:15
> 16:26:51.583:  T:199.87 /200.00 B:60.09 /60.00 @:41 B@:45
> 16:26:51.936:  T:199.87 /200.00 B:60.14 /60.00 @:34 B@:13 W:14
> 16:26:51.936: echo:busy: processing
> 16:26:52.595:  T:200.00 /200.00 B:60.14 /60.00 @:28 B@:24
> 16:26:52.936:  T:199.87 /200.00 B:60.14 /60.00 @:39 B@:4 W:13
> 16:26:53.595:  T:199.87 /200.00 B:60.14 /60.00 @:47 B@:4
> 16:26:53.936:  T:199.87 /200.00 B:60.14 /60.00 @:39 B@:1 W:12
> 16:26:53.936: echo:busy: processing
> 16:26:54.595:  T:199.87 /200.00 B:60.09 /60.00 @:50 B@:25
> 16:26:54.936:  T:200.00 /200.00 B:60.14 /60.00 @:25 B@:0 W:11
> 16:26:55.595:  T:200.18 /200.00 B:60.09 /60.00 @:0 B@:11
> 16:26:55.936:  T:200.00 /200.00 B:60.09 /60.00 @:41 B@:9 W:10
> 16:26:55.937: echo:busy: processing
> 16:26:56.595:  T:200.00 /200.00 B:60.05 /60.00 @:32 B@:16
> 16:26:56.936:  T:199.87 /200.00 B:60.05 /60.00 @:42 B@:12 W:9
> 16:26:57.595:  T:200.00 /200.00 B:60.05 /60.00 @:34 B@:17
> 16:26:57.936:  T:200.00 /200.00 B:60.05 /60.00 @:31 B@:12 W:8
> 16:26:57.936: echo:busy: processing
> 16:26:58.595:  T:199.87 /200.00 B:60.05 /60.00 @:50 B@:0
> 16:26:58.936:  T:200.00 /200.00 B:60.00 /60.00 @:24 B@:23 W:7
> 16:26:59.596:  T:200.18 /200.00 B:60.05 /60.00 @:16 B@:0
> 16:26:59.939:  T:200.00 /200.00 B:60.00 /60.00 @:34 B@:18 W:5
> 16:26:59.961: echo:busy: processing
> 16:27:00.596:  T:200.00 /200.00 B:60.00 /60.00 @:52 B@:14
> 16:27:00.938:  T:199.87 /200.00 B:60.00 /60.00 @:43 B@:14 W:4
> 16:27:01.595:  T:200.00 /200.00 B:59.95 /60.00 @:18 B@:22
> 16:27:01.938:  T:200.00 /200.00 B:59.95 /60.00 @:29 B@:26 W:3
> 16:27:01.960: echo:busy: processing
> 16:27:02.597:  T:200.00 /200.00 B:59.95 /60.00 @:28 B@:9
> 16:27:02.939:  T:200.00 /200.00 B:59.90 /60.00 @:30 B@:33 W:2
> 16:27:03.595:  T:200.18 /200.00 B:59.95 /60.00 @:19 B@:21
> 16:27:03.938:  T:199.87 /200.00 B:59.95 /60.00 @:65 B@:20 W:1
> 16:27:03.960: echo:busy: processing
> 16:27:04.595:  T:200.00 /200.00 B:59.90 /60.00 @:27 B@:19
> 16:27:04.939:  T:200.00 /200.00 B:59.95 /60.00 @:13 B@:0 W:0
> 16:27:05.595:  T:200.00 /200.00 B:59.90 /60.00 @:22 B@:37
> 16:27:05.931: ok N27 P63 B26
> 16:27:05.932: ok N28 P63 B27
> 16:27:05.932: ok P63 B28
> 16:27:05.932: X:0.00 Y:0.00 Z:0.00 E:0.00 Count X:0 Y:0 Z:64
> 16:27:05.932: ok N29 P63 B29
> 16:27:05.932: ok N30 P63 B30
> 16:27:05.932: ok N31 P62 B31
< 16:27:05.932: M117 Layer 0/595
< 16:27:05.932: N32 M107
< 16:27:05.933: N33 M204 S1000
< 16:27:05.933: N34 M205 X14.1 Y14.1
> 16:27:05.934: ok P62 B31
> 16:27:05.934: ok N32 P62 B31
> 16:27:05.934: ok N33 P62 B31
> 16:27:05.934: ok N34 P62 B31
< 16:27:05.934: N35 G0 F9000 X109.938 Y135.096 Z0.2
< 16:27:05.934: N36 G1 F3000 E0
< 16:27:05.934: N37 G1 X111.513 Y133.949 E0.07128
> 16:27:05.935: ok N35 P61 B31
< 16:27:05.936: N38 M73 P0 R66 Q0 S66
< 16:27:05.936: @excludeTimeOn
> 16:27:05.936: ok N36 P60 B30
< 16:27:05.936: @snapshot 0
> 16:27:05.937: ok N37 P59 B31
> 16:27:05.937: ok N38 P59 B31
< 16:27:05.937: N39 G1 F3000
< 16:27:05.937: @excludeTimeOff
< 16:27:05.937: N40 G1 X112.255 Y133.458 E0.10384
< 16:27:05.938: N41 G1 X113.305 Y132.912 E0.14714
> 16:27:05.938: ok N39 P59 B31
> 16:27:05.939: ok N40 P58 B31
< 16:27:05.939: N42 G1 X115.079 Y132.12 E0.21821
> 16:27:05.940: ok N41 P57 B31
> 16:27:05.940: ok N42 P56 B31
< 16:27:05.940: N43 G1 X115.907 Y131.794 E0.25077
< 16:27:05.941: N44 G1 X117.044 Y131.479 E0.29394
> 16:27:05.942: ok N43 P55 B31
< 16:27:05.942: N45 G1 X118.947 Y131.072 E0.36513
> 16:27:05.942: ok N44 P54 B31
< 16:27:05.942: N46 G1 X119.825 Y130.925 E0.3977
> 16:27:05.944: ok N45 P53 B31
> 16:27:05.944: ok N46 P52 B31
< 16:27:05.944: N47 G1 X121.008 Y130.853 E0.44106
< 16:27:05.944: N48 G1 X122.95 Y130.851 E0.51212
> 16:27:05.946: ok N47 P51 B31
< 16:27:05.946: N49 G1 X123.839 Y130.89 E0.54467
> 16:27:05.946: ok N48 P50 B31
< 16:27:05.946: N50 G1 X125.006 Y131.065 E0.58785
> 16:27:05.948: ok N49 P49 B31
> 16:27:05.948: ok N50 P48 B31
< 16:27:05.948: N51 G1 X126.909 Y131.467 E0.65901
< 16:27:05.948: N52 G1 X127.771 Y131.69 E0.69158
> 16:27:05.949: ok N51 P47 B31
< 16:27:05.949: N53 G1 X128.88 Y132.105 E0.7349
> 16:27:05.951: ok N52 P46 B31
> 16:27:05.951: ok N53 P45 B31
< 16:27:05.951: N54 G1 X130.657 Y132.894 E0.80604
< 16:27:05.951: N55 G1 X131.454 Y133.291 E0.83861
> 16:27:05.953: ok N54 P44 B31
< 16:27:05.953: N56 G1 X132.45 Y133.926 E0.88183
> 16:27:05.954: ok N55 P43 B31
> 16:27:05.954: ok N56 P42 B31
< 16:27:05.955: N57 G1 X134.027 Y135.069 E0.95309
< 16:27:05.955: N58 G1 X134.723 Y135.623 E0.98563
> 16:27:05.956: ok N57 P41 B31
< 16:27:05.956: N59 G1 X135.476 Y136.362 E1.02423
> 16:27:05.958: ok N58 P40 B31
> 16:27:05.958: ok N59 P39 B31
< 16:27:05.958: N60 G1 X136.03 Y135.794 E1.05326
< 16:27:05.958: N61 G1 X136.429 Y135.407 E1.0736
> 16:27:05.959: ok N60 P38 B31
< 16:27:05.959: N62 G1 X136.825 Y135.044 E1.09325
> 16:27:05.961: ok N61 P37 B31
> 16:27:05.961: ok N62 P36 B31
< 16:27:05.961: N63 G1 X137.419 Y134.542 E1.1217
< 16:27:05.961: N64 G1 X138.046 Y134.052 E1.15082
> 16:27:05.963: ok N63 P35 B31
< 16:27:05.963: N65 G1 X138.723 Y133.567 E1.18129
> 16:27:05.964: ok N64 P34 B31
> 16:27:05.964: ok N65 P33 B31
< 16:27:05.964: N66 G1 X139.382 Y133.136 E1.2101
< 16:27:05.965: N67 G1 X139.87 Y132.836 E1.23105
> 16:27:05.966: ok N66 P32 B31
< 16:27:05.966: N68 G1 X140.408 Y132.527 E1.25375
> 16:27:05.968: ok N67 P31 B31
> 16:27:05.968: ok N68 P30 B31
< 16:27:05.968: N69 G1 X141.108 Y132.162 E1.28264
< 16:27:05.969: N70 G1 X141.787 Y131.841 E1.31011
> 16:27:05.973: ok N69 P29 B31
> 16:27:05.973: ok N70 P28 B31
< 16:27:05.973: N71 G1 X142.398 Y131.576 E1.33448
< 16:27:05.974: N72 G1 X143.093 Y131.303 E1.3618
> 16:27:05.975: ok N71 P27 B31
< 16:27:05.975: N73 G1 X143.832 Y131.046 E1.39042
> 16:27:05.977: ok N72 P26 B31
> 16:27:05.977: ok N73 P25 B31
< 16:27:05.977: N74 G1 X144.529 Y130.834 E1.41708
< 16:27:05.977: N75 G1 X145.217 Y130.652 E1.44312
> 16:27:05.980: ok N74 P24 B31
> 16:27:05.980: ok N75 P23 B31
< 16:27:05.980: N76 G1 X145.983 Y130.478 E1.47185
< 16:27:05.980: N77 G1 X146.716 Y130.34 E1.49914
> 16:27:05.983: ok N76 P22 B31
> 16:27:05.983: ok N77 P21 B31
< 16:27:05.983: N78 G1 X147.42 Y130.235 E1.52518
< 16:27:05.983: N79 G1 X148.144 Y130.154 E1.55184
> 16:27:05.986: ok N78 P20 B31
> 16:27:05.986: ok N79 P19 B31
< 16:27:05.986: N80 G1 X149.231 Y130.073 E1.59172
< 16:27:05.986: N81 G1 X150.121 Y130.047 E1.62429
> 16:27:05.988: ok N80 P18 B31
> 16:27:05.989: ok N81 P17 B31
< 16:27:05.989: N82 G1 X150.617 Y130.067 E1.64245
< 16:27:05.989: N83 G1 X151.727 Y130.14 E1.68315
> 16:27:05.991: ok N82 P16 B31
> 16:27:05.991: ok N83 P16 B31
< 16:27:05.991: N84 G1 X152.63 Y130.242 E1.7164
< 16:27:05.992: N85 G1 X153.442 Y130.371 E1.74648
> 16:27:05.993: ok N84 P15 B31
< 16:27:05.993: N86 G1 X154.04 Y130.484 E1.76875
> 16:27:05.995: ok N85 P14 B31
> 16:27:05.995: ok N86 P13 B31
< 16:27:05.995: N87 G1 X154.723 Y130.636 E1.79435
< 16:27:05.995: N88 G1 X155.447 Y130.827 E1.82174
> 16:27:05.997: ok N87 P12 B31
> 16:27:05.997: ok N88 P11 B31
< 16:27:05.997: N89 G1 X156.116 Y131.03 E1.84732
< 16:27:05.998: N90 G1 X156.816 Y131.271 E1.8744
> 16:27:05.999: ok N89 P10 B31
< 16:27:05.999: N91 G1 X157.583 Y131.568 E1.9045
> 16:27:06.001: ok N90 P9 B31
> 16:27:06.001: ok N91 P8 B31
< 16:27:06.001: N92 G1 X158.292 Y131.875 E1.93276
< 16:27:06.001: N93 G1 X158.89 Y132.162 E1.95703
> 16:27:06.002: ok N92 P7 B31
< 16:27:06.002: N94 G1 X159.577 Y132.526 E1.98548
> 16:27:06.004: ok N93 P6 B31
> 16:27:06.004: ok N94 P5 B31
< 16:27:06.004: N95 G1 X160.383 Y132.994 E2.01958
< 16:27:06.004: N96 G1 X160.883 Y133.304 E2.0411
> 16:27:06.007: ok N95 P4 B30
> 16:27:06.007: ok N96 P3 B31
< 16:27:06.007: N97 G1 X161.628 Y133.798 E2.0738
< 16:27:06.007: N98 G1 X162.347 Y134.323 E2.10638
> 16:27:06.010: ok N97 P2 B30
> 16:27:06.010: ok N98 P1 B31
< 16:27:06.010: N99 G1 X162.775 Y134.686 E2.12691
< 16:27:06.010: N100 G1 X163.634 Y135.458 E2.16916
> 16:27:06.013: ok N99 P0 B30
< 16:27:06.013: N101 G1 X164.215 Y136.025 E2.19886
< 16:27:06.542: M117 ETA 17:33:14 day 26
> 16:27:06.596:  T:199.87 /200.00 B:59.90 /60.00 @:37 B@:15
> 16:27:07.279: ok N100 P0 B29
> 16:27:07.326: ok N101 P0 B30
< 16:27:07.326: N102 G1 X164.737 Y136.578 E2.22669
> 16:27:07.347: ok P0 B30
< 16:27:07.347: N103 G1 X165.211 Y137.118 E2.25297
> 16:27:07.373: ok N102 P0 B30
< 16:27:07.373: N104 G1 X165.679 Y137.692 E2.28007
> 16:27:07.595:  T:199.87 /200.00 B:59.84 /60.00 @:52 B@:40
> 16:27:08.595:  T:199.87 /200.00 B:59.90 /60.00 @:32 B@:26
> 16:27:09.612:  T:200.00 /200.00 B:59.90 /60.00 @:20 B@:20
> 16:27:10.607: echo:busy: processing
> 16:27:10.612:  T:200.00 /200.00 B:59.90 /60.00 @:20 B@:9
> 16:27:11.611:  T:199.87 /200.00 B:59.90 /60.00 @:40 B@:23
> 16:27:12.607: echo:busy: processing
> 16:27:12.612:  T:200.00 /200.00 B:59.90 /60.00 @:39 B@:32
> 16:27:13.613:  T:200.00 /200.00 B:59.90 /60.00 @:18 B@:39
> 16:27:14.608: echo:busy: processing
> 16:27:14.613:  T:200.00 /200.00 B:59.90 /60.00 @:28 B@:35
> 16:27:15.265: X:10.00 Y:290.00 Z:20.20 E:1.63 Count X:800 Y:23200 Z:8144
> 16:27:15.269:  T:199.87 /200.00 B:59.90 /60.00 @:57 B@:46 W:?
> 16:27:15.613:  T:200.00 /200.00 B:59.90 /60.00 @:28 B@:40
> 16:27:16.268:  T:199.87 /200.00 B:59.95 /60.00 @:43 B@:25 W:19
< 16:27:16.543: M117 ETE 01:06:08
> 16:27:16.607: echo:busy: processing
> 16:27:16.613:  T:200.00 /200.00 B:59.84 /60.00 @:29 B@:72
> 16:27:17.268:  T:200.00 /200.00 B:59.90 /60.00 @:36 B@:39 W:18
> 16:27:17.613:  T:200.18 /200.00 B:59.95 /60.00 @:0 B@:20
> 16:27:18.268:  T:200.00 /200.00 B:59.95 /60.00 @:49 B@:23 W:17
> 16:27:18.607: echo:busy: processing
> 16:27:18.612:  T:200.00 /200.00 B:60.00 /60.00 @:36 B@:14
> 16:27:19.269:  T:200.00 /200.00 B:59.95 /60.00 @:58 B@:38 W:16
> 16:27:19.612:  T:200.00 /200.00 B:59.95 /60.00 @:39 B@:36
> 16:27:20.269:  T:200.00 /200.00 B:59.95 /60.00 @:56 B@:34 W:15
> 16:27:20.607: echo:busy: processing
> 16:27:20.612:  T:200.00 /200.00 B:59.95 /60.00 @:38 B@:42
> 16:27:21.268:  T:200.18 /200.00 B:59.95 /60.00 @:6 B@:43 W:14
> 16:27:21.613:  T:200.00 /200.00 B:60.00 /60.00 @:48 B@:8
> 16:27:22.269:  T:200.18 /200.00 B:59.95 /60.00 @:17 B@:43 W:13
> 16:27:22.607: echo:busy: processing
> 16:27:22.613:  T:200.18 /200.00 B:60.00 /60.00 @:8 B@:20
> 16:27:23.268:  T:200.18 /200.00 B:60.05 /60.00 @:34 B@:12 W:12
> 16:27:23.613:  T:200.18 /200.00 B:60.05 /60.00 @:30 B@:14
> 16:27:24.269:  T:200.18 /200.00 B:60.00 /60.00 @:31 B@:34 W:11
> 16:27:24.607: echo:busy: processing
> 16:27:24.612:  T:200.18 /200.00 B:60.00 /60.00 @:29 B@:31
> 16:27:25.269:  T:200.36 /200.00 B:60.05 /60.00 @:10 B@:22 W:10
> 16:27:25.613:  T:200.18 /200.00 B:60.09 /60.00 @:50 B@:5
> 16:27:26.269:  T:200.36 /200.00 B:60.05 /60.00 @:9 B@:28 W:9
> 16:27:26.608: echo:busy: processing
> 16:27:26.612:  T:200.36 /200.00 B:60.05 /60.00 @:16 B@:19
> 16:27:27.269:  T:200.36 /200.00 B:60.00 /60.00 @:10 B@:34 W:8
> 16:27:27.612:  T:200.18 /200.00 B:60.00 /60.00 @:42 B@:34
> 16:27:28.269:  T:200.36 /200.00 B:60.05 /60.00 @:20 B@:36 W:7
> 16:27:28.608: echo:busy: processing
> 16:27:28.613:  T:200.00 /200.00 B:60.05 /60.00 @:69 B@:31
> 16:27:29.269:  T:200.00 /200.00 B:60.05 /60.00 @:39 B@:31 W:6
> 16:27:29.613:  T:200.00 /200.00 B:60.05 /60.00 @:52 B@:30
> 16:27:30.269:  T:200.18 /200.00 B:60.05 /60.00 @:18 B@:40 W:5
> 16:27:30.607: echo:busy: processing
> 16:27:30.613:  T:200.18 /200.00 B:60.05 /60.00 @:25 B@:32
> 16:27:31.269:  T:200.18 /200.00 B:60.05 /60.00 @:16 B@:31 W:4
> 16:27:31.613:  T:200.00 /200.00 B:60.14 /60.00 @:51 B@:0
> 16:27:32.269:  T:200.18 /200.00 B:60.05 /60.00 @:16 B@:35 W:3
> 16:27:32.608: echo:busy: processing
> 16:27:32.612:  T:200.00 /200.00 B:60.05 /60.00 @:53 B@:38
> 16:27:33.269:  T:200.00 /200.00 B:60.09 /60.00 @:27 B@:15 W:2
> 16:27:33.613:  T:200.00 /200.00 B:60.09 /60.00 @:29 B@:14
> 16:27:34.269:  T:200.18 /200.00 B:60.09 /60.00 @:0 B@:11 W:1
> 16:27:34.607: echo:busy: processing
> 16:27:34.614:  T:200.00 /200.00 B:60.05 /60.00 @:55 B@:36
> 16:27:35.268:  T:200.00 /200.00 B:60.09 /60.00 @:40 B@:16 W:0
> 16:27:38.614: Warning: Communication timeout - resetting communication buffer.
> 16:27:38.615: Connection status: Buffered:96, Manual Commands: 1, Job Commands: 5000
> 16:27:38.615: Buffer used:96 Enforced free byte:37 lines stored:3
< 16:27:38.615: M117 Layer 1/595
< 16:27:38.615: N105 G1 X166.116 Y138.27 E2.30658
< 16:27:38.616: N106 G1 X166.534 Y138.867 E2.33324
> 16:27:40.474: echo:busy: processing
> 16:27:40.523:  T:200.00 /200.00 B:60.05 /60.00 @:45 B@:31
> 16:27:41.523:  T:200.00 /200.00 B:60.09 /60.00 @:47 B@:14
> 16:27:42.473: echo:busy: paused for user
> 16:27:42.524:  T:200.00 /200.00 B:60.05 /60.00 @:25 B@:31
> 16:27:43.543:  T:199.87 /200.00 B:60.05 /60.00 @:36 B@:25
> 16:27:44.474: echo:busy: paused for user
> 16:27:44.544:  T:199.87 /200.00 B:60.05 /60.00 @:53 B@:22
> 16:27:45.544:  T:199.87 /200.00 B:60.05 /60.00 @:30 B@:22
> 16:27:46.539: echo:busy: paused for user
> 16:27:46.544:  T:199.87 /200.00 B:60.05 /60.00 @:37 B@:19
> 16:27:47.544:  T:199.87 /200.00 B:60.00 /60.00 @:32 B@:32
> 16:27:48.539: echo:busy: paused for user
> 16:27:48.544:  T:199.87 /200.00 B:60.00 /60.00 @:50 B@:26
> 16:27:49.544:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:22
> 16:27:50.539: echo:busy: paused for user
> 16:27:50.544:  T:199.87 /200.00 B:60.00 /60.00 @:45 B@:29
> 16:27:51.544:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:29
> 16:27:52.539: echo:busy: paused for user
> 16:27:52.543:  T:199.87 /200.00 B:59.95 /60.00 @:38 B@:60
> 16:27:53.543:  T:200.00 /200.00 B:60.00 /60.00 @:47 B@:24
> 16:27:54.539: echo:busy: paused for user
> 16:27:54.543:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:24
> 16:27:55.544:  T:200.00 /200.00 B:60.00 /60.00 @:23 B@:24
> 16:27:56.539: echo:busy: paused for user
> 16:27:56.544:  T:200.00 /200.00 B:59.95 /60.00 @:36 B@:46
> 16:27:57.544:  T:200.18 /200.00 B:59.95 /60.00 @:0 B@:39
> 16:27:58.539: echo:busy: paused for user
> 16:27:58.544:  T:200.18 /200.00 B:60.00 /60.00 @:19 B@:18
> 16:27:59.544:  T:200.00 /200.00 B:60.00 /60.00 @:53 B@:22
> 16:28:00.539: echo:busy: paused for user
> 16:28:00.544:  T:200.00 /200.00 B:59.95 /60.00 @:49 B@:22
> 16:28:01.544:  T:200.18 /200.00 B:60.00 /60.00 @:7 B@:21
> 16:28:02.539: echo:busy: paused for user
> 16:28:02.544:  T:200.00 /200.00 B:59.95 /60.00 @:35 B@:30
> 16:28:03.544:  T:200.18 /200.00 B:59.95 /60.00 @:2 B@:39
> 16:28:04.539: echo:busy: paused for user
> 16:28:04.544:  T:200.00 /200.00 B:60.00 /60.00 @:61 B@:9
> 16:28:05.545:  T:200.00 /200.00 B:59.95 /60.00 @:23 B@:37
> 16:28:06.539: echo:busy: paused for user
> 16:28:06.544:  T:199.87 /200.00 B:60.00 /60.00 @:42 B@:18
> 16:28:07.544:  T:200.18 /200.00 B:59.95 /60.00 @:5 B@:51
> 16:28:08.539: echo:busy: paused for user
> 16:28:08.544:  T:200.36 /200.00 B:59.95 /60.00 @:0 B@:33
> 16:28:09.544:  T:200.00 /200.00 B:60.00 /60.00 @:28 B@:12
> 16:28:10.539: echo:busy: paused for user
> 16:28:10.544:  T:199.87 /200.00 B:59.95 /60.00 @:57 B@:40
> 16:28:11.544:  T:199.87 /200.00 B:60.00 /60.00 @:47 B@:23
> 16:28:12.539: echo:busy: paused for user
> 16:28:12.544:  T:200.00 /200.00 B:60.00 /60.00 @:8 B@:33
> 16:28:13.544:  T:199.87 /200.00 B:59.90 /60.00 @:58 B@:65
> 16:28:14.539: echo:busy: paused for user
> 16:28:14.544:  T:199.87 /200.00 B:60.00 /60.00 @:35 B@:28
> 16:28:15.544:  T:199.87 /200.00 B:60.00 /60.00 @:46 B@:29
> 16:28:16.539: echo:busy: paused for user
> 16:28:16.544:  T:200.00 /200.00 B:59.95 /60.00 @:33 B@:50
> 16:28:17.544:  T:200.00 /200.00 B:60.00 /60.00 @:51 B@:30
> 16:28:18.539: echo:busy: paused for user
> 16:28:18.544:  T:199.87 /200.00 B:59.95 /60.00 @:75 B@:62
> 16:28:19.544:  T:200.18 /200.00 B:60.00 /60.00 @:15 B@:13
> 16:28:20.539: echo:busy: paused for user
> 16:28:20.544:  T:200.18 /200.00 B:60.00 /60.00 @:24 B@:22
> 16:28:21.544:  T:200.00 /200.00 B:60.00 /60.00 @:32 B@:32
> 16:28:22.540: echo:busy: paused for user
> 16:28:22.545:  T:200.00 /200.00 B:60.00 /60.00 @:33 B@:32
> 16:28:23.544:  T:199.87 /200.00 B:60.05 /60.00 @:53 B@:13
> 16:28:24.540: echo:busy: paused for user
> 16:28:24.545:  T:199.87 /200.00 B:60.00 /60.00 @:49 B@:33
> 16:28:25.544:  T:200.00 /200.00 B:60.05 /60.00 @:22 B@:22
> 16:28:26.540: echo:busy: paused for user
> 16:28:26.545:  T:199.87 /200.00 B:60.00 /60.00 @:39 B@:33
> 16:28:26.692: echo:Send M108 to heat nozzle
> 16:28:27.544:  T:200.00 /200.00 B:60.00 /60.00 @:0 B@:30
> 16:28:28.540: echo:busy: paused for user
Thanks.
  • Good to know that they replaced the message by a new one.
    So far your replacement looks good. Did you restart server after changing? The files are only read once at the start.
    I also checked the sources and it will send the push message if pause message is enabled since in this case the firmware handles the change internally and just blocks server, also you can unblock using M108. If you already did the restart have a check in /var/lib/Repetier-Server/logs/server.log or server.log.0 - the newer one and see for messages. Push messages get logged and failure also gets logged - you should therefor see a message in any case.
  • @Repetier,
    Yes rebooted server after making changes.  No push message for filament change pause or error in server.log.0:
    2020-04-26 20:14:05: Job created: /var/lib/Repetier-Server/printer/SKRV14/jobs/00000002_Kazoo eSun PLA lw 0.4mm lh 0.2mm if 60% ext1 200.0C bed 60.0C.u
    2020-04-26 20:14:05: finish job creation /var/lib/Repetier-Server/printer/SKRV14/jobs/00000002_Kazoo eSun PLA lw 0.4mm lh 0.2mm if 60% ext1 200.0C bed 60.0C.u
    2020-04-26 20:14:07: Repetier-Informer API response: {"error":0,"data":{"receivers":2}} <-- This is for start print.
    2020-04-26 20:14:07: start printjob Kazoo eSun PLA lw 0.4mm lh 0.2mm if 60% ext1 200.0C bed 60.0C on printer SKRV1.4
    2020-04-26 20:14:07: Added timelapse 20200426T201407_Kazoo eSun PLA lw 0.4mm lh 0.2mm if 60% ext1 200.0C bed 60
    Thanks.
  • @Repetier,
    I see another option, HOST_ACTION_COMMANDS which enables "// action:<command>" from the firmware to the host.  There is also another setting HOST_PROMPT_SUPPORT, does Repetier-Server support this?
  • No message where to expect. Will test with a fake message and see if I get it. Still see no error in implementation on your side only if you have push messages disabled or pause push message disabled it would not appear if detected, but you said all is active.
    HOST_PROMPT_SUPPORT is not supported in server.
  • @Repetier ,
    Not sure why the original XML change wasn't working, however when I enabled HOST_ACTION_COMMANDS in firmware it all worked perfectly as expected.  Don't need the XML change if you enable HOST_ACTION_COMMANDS.
    Thanks.
