upload Gcode, return in page one when refresh
When I load the gcode into the print page, and it is placed in the list after the first page because I have a lot of gcode loaded, the page switch in the first page two or three times while the gcode upload and renders. Is possible fix this?
  • File gets added where it belongs in sorted order. That function does not now why it was added or if something was added. There is just an event that files might have changed and it gets reloaded from server. This even happens if you upload it in another window. And changing on all windows the page is unexpected and normally unwanted.
    Best solution for the problem I see is sorting by uploaded date, then it is always at top. Guess that is the most useful order anyway.
  • edited March 2020
    ok
