FIRMWARE_RESTART in klipper problem
Hi all,
I've a skr v1.3 where is installed klipper and a raspberry with repetier server on board. I connected ok the board with /var/lib/klipper/connect, but I'm having an issue when I send #FIRMWARE_RESTART command.
The mcu shutdown and I've a "Failed automated reset of MCU 'mcu'" message.
If I send a #RESTART command instead, klipper came ready again.
Is the problem related to klipper or related to repetier configuration?
What I could search to solve?
ok many thanks
