Ender 3 Jerk Settings
I'm currently using 4 ender 3's hooked up to Repetier Server. Using the EPROM section for each printer I can define max feed rates and accelerations but can't see jerk settings. I've tried issuing a 'M205 X8, Y8' command followed by 'M105' and when I request a readout it still shows the advanced settings with no jerk defined.
Any solutions how to solve this, as I'd like to reduce my jerk and bump up my acceleration.
Kind Regards,
Sam
Kind Regards,
Sam
M205 X8
this sets X and Y jerk to 8
Have tried M205 X8 aswell and it still doesn't show when I try to recall the EPROM settings via the command line it doesn't show it.
What is the output on M503 for your printer. And can you please mark the part not showing up. I then check and update the map file.
M205 Line isn't updating XY jerk settings, even when I send the M205 X8 command.
tells clearly it has no X parameter, so X is not supposed to work. J seems to be for junction but value is small so not sure what it means here. Marlin is not my firmware. Maybe they disabled changing jerk for x and y.gcode definition on reprap org says
just like you try but M503 says it is no eeprom parameter.
