The expected time to finish the print is the same time to notification
The expected time to finish the print is the same time to notification. I print a model upload in a Repetier Host and sliced with a Slicer software (see attached image).
Can you give me some indication to correct it?
Thanks,
  • In my development version start and progress are working. I know progress was defect and looking into it same code was used for start so guess it was same bug that will be fixed in next release.
  • Thanks for answer. I will wait the next release. Best regards.
    Hi Repetier,
    Any news on the update that fixes this bug?
    It's now about a half year that the push updates don't give a real finishing time...
  • We are in the last phase of server update publishing. Then we update host.
    Hi Repetier,
    I appreciate you being busy, but is there any news on the update?
    thanks,
    Ewald....
  • Yes, my fix is already working so will be fixed in 2.2
  • Because of inaccurate firmware updates or slicer settings, the estimated print time might appear to be unchanged. Verify that your slicer produces accurate time estimates and see if real-time progress tracking is supported by the printer's firmware. For improved time prediction and monitoring during the print job, turn on logging or use Repetier-Server.
