Warning: Seems like we missed something a ok - continue sending.
Hello repetier forum, I am fairly new to the 3D printing community and was recently gifted a older Monoprice Maker Select V2, I have been trying to troubleshoot some problems, most recent is the title, 'Warning: Seems like we missed something a ok - continue sending', I'm assuming this is some sort of communication error, I have also been struggling with the error 'SD init failure' which happens either when I try to insert my SD card or halfway through a print and it will bring the print to a halt, I read some forums but nothing seemed to click quite right, any help would be much appreciated, Thank you -B
If you have firmware sources you can help host by enabling line numbers in ok to detect it on the fly or by sending "wait" when being idle. In marlin these can be enabled in the advanced config. Then the problem would normally not occur since it gets detected before getting critical.
