Line Number is not Last Line Number
HiI have a problem
What means this errors:
Error:checksum mismatch, Last Line: 2
Error:Line Number is not Last Line Number+1, Last Line: 2
Error:No Line Number with checksum, Last Line: 2
error: line number is not last line number+1, last line: 12
error: no line number with checksum, last line:12
Waiting for reply
Using: windows 10 pro, Repetier Host 2.0.1 with CuraEngine
For a long time I didn't have any problems with printing even over 10 hours long prints, but for some reason in the last days I can't leave the print unattended. Every now and then this error occurs:
and so on. If I pause/continue the print the error goes away, but returns after a while.
In some cases it even stops the print for no visible reason.
any help would be appreciated.
One known thing is that sending M117 for ETA/Layer through host causes problems with some old firmwares. You then need to disable sending this in host printer config. But that would be an error happening already at the beginning.
Other question is did you change something? New usb cable, firmware update, new position of printer?
Firmware wasn't updated for a long time, same USB cable, same printer settings.
I got a new PLA filament, different colour, from the same manufacturer as before.
I had to change the nozzle, thermistor and nozzle throat because they were worn out and thermistor broke.
BTW: Does the error fix it self? I mean host resends the line in question and the problem should be fixed. That is why we use line numbers and checksums to detect com errors.
Well up until a few days ago, that error has appeared every now and then, but there were no issues. Last print I did,the error started and then the print just stoped...it simply froze and I had to to emergency stop.
15:27:22.071 : N297 G1 F50 X49.644 Y54.649 E4.4132*60
15:27:22.071 : N298 G1 X49.644 Y55.217 E4.4221*95
15:27:22.071 : N299 G1 X49.645 Y55.946 E4.43353*103
15:27:22.071 : N300 G1 X49.647 Y57.09 E4.45146*84
15:27:22.071 : N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.071 : N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.071 : N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.071 : N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.071 : N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.071 : N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.071 : N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.071 : Error:checksum mismatch, Last Line: 300
15:27:22.086 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.086 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.086 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.086 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.086 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.086 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.102 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.102 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.102 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.102 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.102 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.102 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.118 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.118 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.118 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.118 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.118 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.134 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.134 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.134 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.134 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.134 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.134 : Error:Line Number is not Last Line Number+1, Last Line: 300
15:27:22.149 : Resend: N301 G1 X49.648 Y57.589 E4.45928*103
15:27:22.149 : Resend: N302 G1 X49.65 Y59.024 E4.48178*81
15:27:22.149 : Resend: N303 G1 X49.647 Y59.705 E4.49245*110
15:27:22.149 : Resend: N304 G1 X49.644 Y60.209 E4.50035*100
15:27:22.149 : Resend: N305 G1 X49.644 Y60.222 E4.50056*105
15:27:22.149 : Error:Line Number is not Last Line Number+1, Last Line: 305
15:27:22.149 : Resend: N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.149 : Resend: N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.149 : N308 M117 FIN 4m 23s*101
15:27:22.165 : Resend: N306 G1 X49.649 Y60.742 E4.50871*105
15:27:22.165 : Resend: N307 G1 X49.649 Y61.116 E4.51457*103
15:27:22.165 : Resend: N308 M117 FIN 4m 23s*101
