@execute in gcode not working...
I changed the extcommands.xml to have additional commands for light on and light off (relais connected to the gpio of the pi). The command in the main menu work well, but ";@execute lighton" and ";@execute lightoff" do not work. Here are my definitions:
What's wrong with it? Has anybody any idea?
Thanks in advance!
Alex
<command>
<name>Light On</name>
<execute>/home/pi/scripts/lighton.sh</execute>
<!-- Define if command should show up in local printer interface, default true.-->
<local>true</local>
<!-- Define if command should show up in remote printer interface, default true.-->
<remote>true</remote>
<!-- Define if command should show up only for users with print permission, default true.-->
<print-permission>true</print-permission>
<!-- Define if command should show up only for users with add files permission, default false.-->
<add-permission>true</add-permission>
<!-- Define if command should show up only for users with del files permission, default false.-->
<del-permission>true</del-permission>
<!-- Define if command should show up only for users with configuration permission, default false.-->
<config-permission>true</config-permission>
</command>
<command>
<name>Light Off</name>
<execute>/home/pi/scripts/lightoff.sh</execute>
<local>true</local>
</command>
<execute name="lighton" allowParams="false">/home/pi/scripts/lighton.sh></execute>
<execute name="lightoff" allowParams="false">/home/pi/scripts/lightoff.sh></execute>
Thanks in advance!
Alex
there is an extra > after .sh making the command fail.
should be correct. At least then the syntax is ok. If light in menu work I assume you have already solved the user permission problems (mean it is executed as repetieruser not pi).
Thank you so much!
Alex
