Import the history
Hi! Can you add import history into the printer. Now i want reinstall repetier-server on my raspberrypi with full wipe. But i want save my data. I can see taht i can save an printer settings and history it is good but i can not Import the history after full wipe. And you can add one button for full save an printers and full settings and full history it will be good.
  • We will soon publish a tool that can do a real backup of server state. Then you can restore it easily. Currently you would have to copy history.sql from database folder to get old history back. In general to copy all data and settings just copy /var/lib/Repetier-Server folder 1:1 to new installation with disabled server.
  • When should the tool come?1
  • Best guess is end of june at the moment.
