Repetier Server, Raspberry pi 3B+, 3.5inch hdmi screen
How do I stop the screen going blank while printing?
  • Do you mean the screensaver? You can disable screensaver then it will not disable screen.
    I'll give that a go, I don't see a screen saver option to be able to turn it off thou, where are the screen saver options?
    The screen on the Raspberry pi goes black after a while. If I touch the screen it comes back on, sounds like a screen saver, or going to sleep.
    Thanks.
    Steve
  • Yes, that is definitively the screensaver. You can configure it in touch screen in Settings->Screensaver.
  • Found it, that was it ;-)
    Thank you
