the printer can not be controlled
Now this problem on windows 10 x64, had also been on the windows 8 x32. In windows 7 x32 there is no problem. The program runs, and even connect to the computer supposedly going on, but the printer is not operated by the buttons of the program and no entries in the log does not appear.
NET Framework installed the latest version of where to find the mistake?
  • Connection is only successfull if you see some lines about firmware capabilites in the log. Otherwise you are connected to serial but no communication occurs. In that case check baud rate and reset on connect depending on the printer board.
  • Communication does not happen and there is no information about the printer. Speed is correct. Reset when you connect to your program was the default as well as in where the program works correctly. I tried other settings but to no avail.
