4 Printers, one of them doesnt save config
I have 3 Ender 3 and one Geeetech A10m
One of the Ender 3 doesn't save config. When I add an extruder and save... it simply doesn't store it :-(
  • This can happen if there is an illegal value format e.g. letter of , instead of . for a number. That can cause an exception during save. You can try to see if logs/server.log if there is a hint about that problem. You can also send me the xml file in question so I can see where it was possible to make it malfunction.
  • YES! I was using 1.75 in extruder size instead of 1,75 . Thank you!
  • What browser do you use. Testing with firefox and chrome it is not possible to save with wrong value there.
  • Using Chrome on Windows 10. It now doesn't allow me to save with this configuration, so I don't know what happened when I did it but is my default browser. I have other problem that can be related:
    https://forum.repetier.com/discussion/6479/weird-movement-on-every-layer-change?new=1
  • nope, the other problem is fixed and no related at all.
