Cannot print anything. receiving only error message reset communication for printer.
I recently installed a fresh copy of repeiter ser ver and everytime i print every thing, initially everything seems fine extruder heat up bed leveling, and then this error message pops up receiving only error message reset communication for printer
https://drive.google.com/file/d/1JPpb01VMT__eZ9TR8Zi3YECa_npbpkTt/view?usp=drivesdk
https://drive.google.com/file/d/1Z6wh2m_Yuk6ilg2hvnWrk-xlkSAM3tyq/view?usp=drivesdk
Uncomment ...
That is no valid gcode. Maybe that is causing the problem. To find out what the problem is you need to enable logging and check the log around the error time and see what is happening there. I guess the wrong line causes an error loop.
