Timeplapses stuck "Converting"
I have two timelapses now that are stuck being converted. I used the enforce position to capture them.
Both are rather small data sets (one 500 Frames, the other 900)
worked fine for months, even with 91.2. But since I switched to the v14 raspberry PI image they are stuck converting.
I triggered the "recreate video" a couple of times leading to sticky "Background processes running" notifications. But never finished.
there seems to be no processes running on the machine besides the chromium task that takes about 5-10% of CPU and a lower digit mjepeg stream for the webcam. But no conversion I can see whatsoever.
Any ideas? Any settings you need to know? My settings are 25frames 10.000kbit
Hard to say if file has an error or contaitns something that can not finish, so that is I think best solution.
I can give you HTTP/SSH access if you tell me where to send it to! I guess that might be easier?
