Layer Height 0.05
Hey Guys
I use Slic3r PE via Repetier Host. I was printing a small model and set layer height to 0.05 but it slicves to 0.1mm layers. How can i get it down to 0.5?
  • Ensure your slicer profile has the height set. Then check in host if the override is active, where you can set different layer heights. One of them has 0.1 in your case.
    OK thanks i will check that.
