Intercept the type of firmware automatically
Since every
firmware during the boot sends strings on the serial line it would not
be possible to automatically intercept what is, without declaring it in
the configuration of the printer?
echo:Unknown command: "M73 P6 R79 Q6 S79"
MK4duo is an evolution of Marlin 2, and for the eeprom management and more I've to declare in the Server that I've a "Marlin" firmware, there's no other way.
But in that case the server sends a lot of M73 commands that MK4duo doesn't interpret, because it instead manages those in standard "Repetier Host" for the LCD progress bar and other things.
So if you possibile it would be better to insert "MK4duo" as firmware in the selection, and send these commands to the firmware in that case in "Repetier Host" standard, or just remove this M73 command for "MK4duo" firmware.
<response type="unknownCommand" string="true">^[Ee]cho:Unknown command: "([MG]\d+)</response>
in marlin.xml. That should detect the M73 as unknown command after first usage and not send it any more.
I do not really want 100 different firmware files to handle small differences. With all the forks I would get mad maintaining them. But I will include this rule as well in next release so after a first unknown command it should be the last one.
M73 is for Prusa Firmware or copies of that which use M73 for progress.
M530/M531 should be detected and used as well if the cap
Cap:PROGRESS:1
gets send by firmware.
