2 in 1 out mixing nozzle having trouble getting set up in repetier server
I am still fairly new to 3d printing and just got my second printer... a Geeetech A20M. It prints in both colors and mixes find when printing from SD card but when I set up in Repetier server, and slice with software using the correct method for doing 2 color prints, I can't get the second extruder to work. In repetier server when I set up it only detects 1 extruder... do I need to add the second extruder? That seems to be the only way I can get control of the second extruder and manually extrude material to clear either extruder. Any assistance in setting this up properly would be appreciated.
For each Tx you need one extruder to be able to select from interface.
Does this help?
Could you post a output to console if ACK is enabled. I'm interested in the temperature format marlin uses.
16:45:32.460: T:19.96 /0.00 B:20.74 /0.00 @:0 B@:0 16:45:33.459: T:21.48 /0.00 B:19.02 /0.00 @:0 B@:0 16:45:34.459: T:19.30 /0.00 B:20.08 /0.00 @:0 B@:0 16:45:35.459: T:23.12 /0.00 B:20.66 /0.00 @:0 B@:0 16:45:36.460: T:23.79 /0.00 B:20.47 /0.00 @:0 B@:0 16:45:37.460: T:22.27 /0.00 B:20.78 /0.00 @:0 B@:0 16:45:38.460: T:20.16 /0.00 B:17.93 /0.00 @:0 B@:0 16:45:39.461: T:22.42 /0.00 B:19.22 /0.00 @:0 B@:0 16:45:40.460: T:21.41 /0.00 B:22.38 /0.00 @:0 B@:0 16:45:41.461: T:18.63 /0.00 B:20.70 /0.00 @:0 B@:0 16:45:42.460: T:19.88 /0.00 B:21.56 /0.00 @:0 B@:0 16:45:43.460: T:21.41 /0.00 B:19.80 /0.00 @:0 B@:0 16:45:44.460: T:20.59 /0.00 B:21.52 /0.00 @:0 B@:0 16:45:45.460: T:20.90 /0.00 B:20.55 /0.00 @:0 B@:0 16:45:46.460: T:20.43 /0.00 B:21.80 /0.00 @:0 B@:0 16:45:47.460: T:21.64 /0.00 B:18.20 /0.00 @:0 B@:0 16:45:48.460: T:23.05 /0.00 B:18.98 /0.00 @:0 B@:0 16:45:49.460: T:20.12 /0.00 B:20.62 /0.00 @:0 B@:0 16:45:50.460: T:19.26 /0.00 B:19.26 /0.00 @:0 B@:0 16:45:51.460: T:21.72 /0.00 B:19.96 /0.00 @:0 B@:0 16:45:52.460: T:18.63 /0.00 B:19.57 /0.00 @:0 B@:0 16:45:53.473: T:21.45 /0.00 B:22.89 /0.00 @:0 B@:0 16:45:54.473: T:20.55 /0.00 B:19.30 /0.00 @:0 B@:0 16:45:55.473: T:21.29 /0.00 B:20.08 /0.00 @:0 B@:0 16:45:56.473: T:21.64 /0.00 B:20.90 /0.00 @:0 B@:0 16:45:57.473: T:23.55 /0.00 B:20.04 /0.00 @:0 B@:0 16:45:58.473: T:20.82 /0.00 B:19.65 /0.00 @:0 B@:0 16:45:59.474: T:22.11 /0.00 B:19.69 /0.00 @:0 B@:0 16:46:00.473: T:20.59 /0.00 B:20.59 /0.00 @:0 B@:0 16:46:01.473: T:20.51 /0.00 B:18.16 /0.00 @:0 B@:0 16:46:02.473: T:23.40 /0.00 B:21.17 /0.00 @:0 B@:0 16:46:03.473: T:21.33 /0.00 B:20.16 /0.00 @:0 B@:0 16:46:04.473: T:23.71 /0.00 B:18.91 /0.00 @:0 B@:0 16:46:05.473: T:21.76 /0.00 B:20.00 /0.00 @:0 B@:0 16:46:06.473: T:19.88 /0.00 B:21.68 /0.00 @:0 B@:0 16:46:07.473: T:21.25 /0.00 B:21.05 /0.00 @:0 B@:0 16:46:08.474: T:21.05 /0.00 B:20.70 /0.00 @:0 B@:0 16:46:09.473: T:22.81 /0.00 B:20.04 /0.00 @:0 B@:0 16:46:10.473: T:21.80 /0.00 B:19.06 /0.00 @:0 B@:0 16:46:11.474: T:22.77 /0.00 B:19.53 /0.00 @:0 B@:0 16:46:12.473: T:21.52 /0.00 B:22.89 /0.00 @:0 B@:0 16:46:13.473: T:19.26 /0.00 B:20.55 /0.00 @:0 B@:0 16:46:14.473: T:22.34 /0.00 B:18.71 /0.00 @:0 B@:0 16:46:15.484: T:18.79 /0.00 B:19.45 /0.00 @:0 B@:0 16:46:16.501: T:18.44 /0.00 B:22.11 /0.00 @:0 B@:0 16:46:17.501: T:21.13 /0.00 B:20.00 /0.00 @:0 B@:0 16:46:18.503: T:20.74 /0.00 B:18.55 /0.00 @:0 B@:0 16:46:19.501: T:20.27 /0.00 B:20.90 /0.00 @:0 B@:0 16:46:20.501: T:23.01 /0.00 B:18.52 /0.00 @:0 B@:0 16:46:21.500: T:19.57 /0.00 B:21.21 /0.00 @:0 B@:0 16:46:22.501: T:20.74 /0.00 B:20.20 /0.00 @:0 B@:0 16:46:23.501: T:19.65 /0.00 B:19.53 /0.00 @:0 B@:0 16:46:24.501: T:23.71 /0.00 B:18.63 /0.00 @:0 B@:0 16:46:25.501: T:22.58 /0.00 B:22.11 /0.00 @:0 B@:0 16:46:26.501: T:21.05 /0.00 B:21.56 /0.00 @:0 B@:0 16:46:27.502: T:18.63 /0.00 B:21.29 /0.00 @:0 B@:0 16:46:28.501: T:19.34 /0.00 B:19.57 /0.00 @:0 B@:0 16:46:29.502: T:21.60 /0.00 B:19.02 /0.00 @:0 B@:0 16:46:30.501: T:20.62 /0.00 B:21.25 /0.00 @:0 B@:0 16:46:31.502: T:23.67 /0.00 B:19.57 /0.00 @:0 B@:0 16:46:32.501: T:21.21 /0.00 B:18.20 /0.00 @:0 B@:0 16:46:33.502: T:22.46 /0.00 B:20.12 /0.00 @:0 B@:0 16:46:34.503: T:21.05 /0.00 B:19.37 /0.00 @:0 B@:0 16:46:35.501: T:21.99 /0.00 B:21.13 /0.00 @:0 B@:0 16:46:36.502: T:21.09 /0.00 B:20.04 /0.00 @:0 B@:0 16:46:37.501: T:21.72 /0.00 B:20.08 /0.00 @:0 B@:0 16:46:38.513: T:21.17 /0.00 B:19.53 /0.00 @:0 B@:0 16:46:39.512: T:22.34 /0.00 B:20.20 /0.00 @:0 B@:0 16:46:40.513: T:21.72 /0.00 B:19.61 /0.00 @:0 B@:0 16:46:41.512: T:23.40 /0.00 B:17.70 /0.00 @:0 B@:0 16:46:42.513: T:21.87 /0.00 B:19.45 /0.00 @:0 B@:0 16:46:43.512: T:20.23 /0.00 B:21.29 /0.00 @:0 B@:0 16:46:44.512: T:20.59 /0.00 B:19.41 /0.00 @:0 B@:0 16:46:45.512: T:20.47 /0.00 B:17.62 /0.00 @:0 B@:0 16:46:46.512: T:20.20 /0.00 B:22.03 /0.00 @:0 B@:0 16:46:47.513: T:19.41 /0.00 B:21.99 /0.00 @:0 B@:0 16:46:48.512: T:19.34 /0.00 B:21.13 /0.00 @:0 B@:0 16:46:49.513: T:20.12 /0.00 B:20.55 /0.00 @:0 B@:0 16:46:50.512: T:21.68 /0.00 B:19.26 /0.00 @:0 B@:0 16:46:51.512: T:22.54 /0.00 B:21.41 /0.00 @:0 B@:0 16:46:52.512: T:21.84 /0.00 B:19.10 /0.00 @:0 B@:0 16:46:53.512: T:19.73 /0.00 B:20.23 /0.00 @:0 B@:0 16:46:54.513: T:22.15 /0.00 B:18.75 /0.00 @:0 B@:0 16:46:55.512: T:21.91 /0.00 B:19.34 /0.00 @:0 B@:0 16:46:56.512: T:20.66 /0.00 B:21.05 /0.00 @:0 B@:0 16:46:57.512: T:20.66 /0.00 B:19.96 /0.00 @:0 B@:0 16:46:58.512: T:19.41 /0.00 B:21.29 /0.00 @:0 B@:0 16:46:59.512: T:20.51 /0.00 B:22.77 /0.00 @:0 B@:0 16:47:00.512: T:19.06 /0.00 B:17.46 /0.00 @:0 B@:0 16:47:01.512: T:20.51 /0.00 B:21.29 /0.00 @:0 B@:0 16:47:02.512: T:19.88 /0.00 B:19.88 /0.00 @:0 B@:0 16:47:03.513: T:20.98 /0.00 B:17.62 /0.00 @:0 B@:0 16:47:04.512: T:19.45 /0.00 B:21.33 /0.00 @:0 B@:0 16:47:05.512: T:20.47 /0.00 B:20.74 /0.00 @:0 B@:0 16:47:06.512: T:23.20 /0.00 B:20.39 /0.00 @:0 B@:0 16:47:07.512: T:21.95 /0.00 B:21.87 /0.00 @:0 B@:0 16:47:08.512: T:20.16 /0.00 B:20.47 /0.00 @:0 B@:0 16:47:09.512: T:21.25 /0.00 B:22.34 /0.00 @:0 B@:0 16:47:10.512: T:23.95 /0.00 B:18.36 /0.00 @:0 B@:0 16:47:11.512: T:20.66 /0.00 B:19.57 /0.00 @:0 B@:0 16:47:12.512: T:21.33 /0.00 B:20.82 /0.00 @:0 B@:0 16:47:13.512: T:20.00 /0.00 B:20.51 /0.00 @:0 B@:0 16:47:14.512: T:21.72 /0.00 B:19.26 /0.00 @:0 B@:0 16:47:15.513: T:21.80 /0.00 B:20.39 /0.00 @:0 B@:0 16:47:16.512: T:19.88 /0.00 B:21.68 /0.00 @:0 B@:0 16:47:17.511: T:20.43 /0.00 B:20.82 /0.00 @:0 B@:0 16:47:18.512: T:18.98 /0.00 B:20.47 /0.00 @:0 B@:0 16:47:19.512: T:20.62 /0.00 B:22.30 /0.00 @:0 B@:0 16:47:20.512: T:17.81 /0.00 B:20.43 /0.00 @:0 B@:0 16:47:21.512: T:22.62 /0.00 B:23.16 /0.00 @:0 B@:0 16:47:22.525: T:19.45 /0.00 B:20.43 /0.00 @:0 B@:0 16:47:23.525: T:21.80 /0.00 B:21.76 /0.00 @:0 B@:0 16:47:24.524: T:21.99 /0.00 B:18.91 /0.00 @:0 B@:0 16:47:25.524: T:21.37 /0.00 B:22.11 /0.00 @:0 B@:0 16:47:26.523: T:19.26 /0.00 B:19.69 /0.00 @:0 B@:0 16:47:27.524: T:20.55 /0.00 B:21.41 /0.00 @:0 B@:0 16:47:28.523: T:21.87 /0.00 B:19.57 /0.00 @:0 B@:0 16:47:29.524: T:22.23 /0.00 B:22.30 /0.00 @:0 B@:0
