No, I also get them from time to time. This happens on some machines while others have no errors at all. The important direction is sending and there we have a good checksum system to fix such errors. Only if you get several errors per second over longer times you should try to find the source. That looks like in normal range so far.
wait is send from firmware to indicate that it is idle waiting for commands.
