Buttons will not recognized after own gcodes
I have made my own gcode commands to control case lights. These commands are added to "Console/Commands". Gcode is for controlling lights is: M42 P9 S255 to set lights to 100%, for exmaple. It is also possible to control lights from "Param/Toggle Lights" menu at the front-end.
Now, if I control lights from "Console/Commands", the "Param/Toggle Lights" button won't work anymore, at least it will not control case lights. If I make reboot the "Param/Toggle Lights" button will work again.
Any hints?
Any hints?
I wonder how you do toggle with the command. S255 always means on. For toggle you need to switch between 0 and 255 each call and that is not possible in a single script. So maybe you just need 2 script on and off.
M42 P9 S153 to set LED's to 60%
M42 P9 S85 to set LED's to 33% and
M42 P9 S38 to set LED's to 15%
Above Gcode commands will work all the time, I can see it also in the console.
In firmware (Repetier-Firmware, version 1.0.1dev) I have configured that case light pin for LED's is heater 2 output. I can also control LED's ON or OFF via "Control/ Toggle Lights" but not after when any of those gcodes mentioned above are carried out...
My setup is:
Arduino Mega 2560 + Ramps 1.4
Repetier FW 1.0.1dev (download and updated in end of June)
Raspberry Pi 3 B+ with 5" TFT display
