Printer freezes/hangs a few seconds during printing
using armbian on an orange pi win. I see a strange behavirour: after starting the print, randomly (as it seems) the printer stops up until 5 - 15 seconds, then goes on.
However the print quality is bad 'cause of this.
I'm using an geeetech rostock delta g2s pro, marlin firmeware. It runs fine with Repetier Host.
So what can be the reason. It freezes... then moves again.
Thanks!
Joerg
Thanks!
Joerg
btw. I bought the pro version – so I‘m a paying customer...
thanks!
//#define ADVANCED_OK
As I have paid for the software, I would like to use it ;-) Any idea?
With this frequency of errors you are exceeding the input buffer size. When that happens every x lines you get an error just like this. Octoprint only sends one command at a time (same as when you enable ping pong mode in repetier-server). But this is slower so better to reduce buffer size to 60 instead and try if it gets better. As a last resort you can use ping-pong but then you also should find the wait switch for marlin or at every missed "ok" you will get a timeout hang.
