Screen info missing
For the past few weeks on both my Prusa and Creality, on which I have Raspberry Pi 3b's with Pi 7" screens, the display fails to update after starting a print.  Sometimes it just stays as per the very first screen showing original ETE and ETA and layer 0 and never progresses and the progress indicator never updates.  Also, on many but not all occasions many of the screens are missing most of the display objects.  However, the Params option is always visible and if I click that the parameters screen is correct and then I can go back to the print or home screens.
Despite all of this the remote access via a browser never fails and is always correct.  It is just the output on the 7" Pi screen that is all messed up.
Does anyone have any ideas?  It has defeated me.  I have tried different cables and also a 3A USB supply so have no yellow lightning bolt icon.
Thanks.  I bought a license and love Repetier but having to consider going back to Octoprint (Yuk) or Astroprint (rather not).
«1
  • So, 10 minutes into a print, started from the Pi screen and this is what I get.  On the Printing screen, the Home button has disappeared so only way to navigate back is to select Temp or Params and then it reappears and can press it.
  • Whilst the remote screen via browser is still all present and correct
  • These are web apps and completely independent. Touchscreen is connected via localhost so there is no problem in communication etc.
    Did you use our image (which version) for the pi? There is a updated image now (V8) using latest debian stretch/chromium.
    What seems to happen is that there happens an error in browser that stops parts from working as expected. Ihave not notived this problem so far, so it might be a defect in the files loaded that triggers this. So if you could make a new image with V8 and test if it is still there or not.
    BTW: Did it work at the beginning and then started to fail 2 weeks ago?
  • edited April 2018
    HI.  Thanks for the reply.  Yes, it all worked fine initially, using your 0.86.2 image for Raspberry Pi, and then a few weeks ago just started behaving like this.  I wonder whether it may be Marlin firmware related.
  • edited April 2018
    OK, downloaded and reloaded the latest Pi image and doing new tests.  Note to self: save the previous printer profile before renewing image :)
  • Ok, since it worked before without being updated I assume it has an other source. If you changed firmware that could be an issue, but I do not know how it should affect the interface in such a way. But lets see what the new image does.
  • OK, downloaded and reloaded the latest Pi image but absolutely no difference.  First print, progress screen is locked without updating, if I switch to parameter screen and back to print screen all the info is missing as per the images above.  Really disappointing as now acting in this way on both my Prusa and Creality, each using their own Pi and screen.
  • Ok, so back to firmware theory. Did you upgrade firmware before it started not working? If so which firmware and version is it. Don't have both printers for testing but it might give a trace. What might be possible that now parsing some responses makes problems confusing interface when it interprets a invalid value. But that is just a guess, first we need to find the trigger.
    As additional help, if you have no users defined, you can also run the interface in your PCs chrome
    http://ip:3344/modules/front2/www/app.html/
    And open the developer tools->console.
    I guess it will show some errors once it gets its problems and they might give some hints, even if names are shorted.
  • edited April 2018
    I have upgraded firmware to latest versions on both printers.  On the Prusa I am using the latest Prusa 3.1.0 and on the CR10 I am using a fork of the latest Marlin.  For the CR10 I have tried multiple versions of TH3D Studios Unified firmware and also a version by PrintedSolid and the results are the same.  The strange thing is I have a friend who has the CR10 running the exact same firmware on his CR10 (I compiled it for him) and he has no problems using the same Pi3 with Pi 7" screen.
  • edited April 2018
    Just commenced a print with the interface running in Chrome and, for the first time in weeks, it is behaving properly, both in the Chrome interface AND the Pi screen.  When complete I'll run another one without the Chrome interface and see how it behaves.  More confusion :(
  • Yes, I see that. Running a second instance on pc should not change how the pi chrome acts as they are independent. I think the trigger causing the problem just did not happen like with your friends version. Maybe it would be a good idea to activate logging while printing so you check around the time the error happens if log contains unusual content.
  • I've now run 2 prints without the PC interface and all is good.  No idea what is going on but 2 consecutive prints with no loss of Pi screen interface.  Looking at the Print logs though, there are regular Communication timeout warnings.  No idea if this may have been a cause of previous issues but I've done nothing to the PI and now seems to be working correctly again.  Very very strange.
    The communication timeout warnings in the log appear about every 30 seconds.
  • Maybe time to buy some new USB cables.  I think the one I'm using on the CR10 is an old Motorola Mobile cable (as it uses old style mini USB)
  • Compile firmware to send line numbers with "ok". In log you see it has 109 bytes in buffer (server thinks so). But since nothing seems to happen it times out. This happens if "ok" is not detected due to com errors. Line numbers help server detect that one was missed and correct this on the fly.
    I also wonder I see NO firmware responses in log. As you see with timeout server resets ok counter and send new commands but these should trigger an ok if connection is still healthy.
  • Running another big print now and all good via the browser interface in safari (http://ip:3344/modules/front2/www/app.html/) but the Pi screen is missing all the info again.  I'll look into how to compile firmware as you suggest above, but I'm still at a loss to understand why my friend's works OK with exact same firmware but mine does not.  Would/could cable quality affect anything?
  • Communication problems with firmware can come from cable, but with the line number setting it should already get fixed as it does not seem to happen so often.
    Communication to pis chrome is no cable issue as they are connected internally. The fact that one browser stops while the other stays working is more interesting a sit is the same app and both get same data most of the time.
    WHat you could try is login to pi with ssh and run "top" to see memory usage. If you run out of memory due to a memory leak it could affect stability. Whcih page in the app do you watch while that happens? The print progress or something else?
  • edited April 2018
    Always the print progress screen.  When I see that the circular progress indicator is not displaying and the layer number not progressing I switch to the Params or Temp screen and then back to the progress screen.  It is then that all the graphics disappear.  Also, the Temp screen never shows a graph when this happens but all params options are still there.  So text seems to be OK but graphics are all missing.
  • So if I understand you everything continues working except objects using the canvas html object - circle and temperature graph. That sounds like chrome stopped running canvas for some reason. So that part might be crashed or stopped on intention to maybe reduce memory. Did you test the memory usage? While it swings a bit it should not increase much over the time of the print.
    You could also connect a mouse and open developer tools with context menu to see if chrome shows some error messages. Before edit /home/pi/.bashrc near end to remove --nocursor so you see your mouse pointe rafter reboot.
  • Now, even via the remote browser interface (Safari) I get this after clicking on an item to print.  I give up.  Will need to find an alternative solution I think.
  • Also, now via the standard browser interface, I now get a lack of information for the extruder temperature.  I would just like this to work as intended.  I am using a Pi3 with a fresh install of the RS 0.86.2
  • You did not by any chance store the error message in the browser console (developer tools) when this happened. That is the information we need to find what is causing this. As it now also happens on desktop it is clearly not the chrome on pi, it is just getting the same error information. My guess is that it interprets some infos from firmware that is corrupted with com error cauing an NaN (not a number) or other invalid floating value crashing then later the interface when these get not intended wrong data. Most likely it is in temperatures as that is the most frequent reported value. Will have a look into interpreter if we catch it there or not.
  • I'm afraid I don't know how to do that.  However, by pressing a few keys on a keyboard (attached via 2.4MHz dongle) attached I got this
  • edited April 2018
    It is now working only partly on Pi screen and also only partly on remote browser screen.  You can see on image above (Pi screen) the temp graphs and all data (temp, layer, fan speed, etc) is all missing.
    And on the remote browser screen the progress circle has appeared to stop and it has not shown any temp or layer info etc since it started.
  • You get console in chrome my right clicking and selecting last menu item(inspect i guess it is named, have german localization so not sure) and then select console. Then you see the error debug messages. Especially easy if it happens on your PCs browser.
    But In your last picture I see also that extruder has no temperature. So my guess is that there is a letter in it from com error and that causes server to return invalid numbers making canvas crash when drawing it. A reload after 5 minutes should help. In main menu there is "Restart UI" that does this. After 5 minutes wrong values are out of the lists. Would be great becaus ethen I know exactly what to do. In fact I will now start protecting all conversions and ignore response if an invalid value was detected to prevent exactly this for next update.
  • edited April 2018
    OK thanks.  I just started another print from my Chrome browser console and immediately got this (image above, console text copied below)
    12:40:46.656 vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:22 EXCEPTION: Cannot read property 'alias' of undefined
    ErrorHandler.handleError @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:22
    next @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:15
    e.object.i @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:15
    SafeSubscriber.__tryOrUnsub @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:1
    SafeSubscriber.next @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:1
    Subscriber._next @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:1
    Subject.next @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2
    EventEmitter.emit @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:15
    onError @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:16
    onHandleError @ vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33
    ZoneDelegate.handleError @ polyfills.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2
    Zone.runTask @ polyfills.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2
    drainMicroTaskQueue @ polyfills.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2
    ZoneTask.invoke @ polyfills.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2
    12:40:46.657 vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:22 ORIGINAL STACKTRACE:
    12:40:46.657 vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:22 TypeError: Cannot read property 'alias' of undefined
        at PrinterAction.extruderName (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:8)
        at _View_PrintStatusComponent6.detectChangesInternal (PrintStatusComponent.ngfactory.js:906)
        at _View_PrintStatusComponent6.AppView.detectChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
        at _View_PrintStatusComponent3.AppView.detectContentChildrenChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
        at _View_PrintStatusComponent3.detectChangesInternal (PrintStatusComponent.ngfactory.js:756)
        at _View_PrintStatusComponent3.AppView.detectChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
        at _View_PrintStatusComponent0.AppView.detectContentChildrenChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
        at _View_PrintStatusComponent0.detectChangesInternal (PrintStatusComponent.ngfactory.js:199)
        at _View_PrintStatusComponent0.AppView.detectChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
        at _View_PrintStatusComponent_Host0.AppView.detectViewChildrenChanges (vendor.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:33)
    12:40:46.657 polyfills.bundle.js?lang=en&front=1&12cb7e9e80bcb38da705:2 TypeError: Cannot read property 'alias' of undefined
  • Right clicking on the Pi screen is only switching between Printing and Temperature screens.  No context menu.
  • Thanks for all the help.  I've tried different Pi 3's, different SD cards, new images and nothing fixes these issues.  I'm now back with Octoprint which just works.  It's not pretty but it works.  I will try Repetier again when a new version comes out and see if it works for me then.
  • No problem. Hope my guess was right so the fix works for you.
  • Fantastic.  Thank you so much.  I look forward to it.
