Change mjpg-streamer settings in the raspi image- add user/password
I'm using the repetier-server raspi image and I have the webcam externally available.
Problem is I can't find way to alter the mjpg-streamer startup params as I'd like to enable to option to ask for username/password.
Is there a file where that is stored and can be edited?
Previously I had my own custom raspi image and I could easily make this change.
http://admin:password@10.0.0.7/mjpeg/snap.cgi?chn=1
server will detect this and run authentication in that case.
I think that is not exactly it, that would be in case the webcam had some authentication method built-in.
Here I don't have any authentication method in the webcam, so I want o add it at the mjpg-streamer level.
The output_http plugin provides that option: https://github.com/jacksonliam/mjpg-streamer/blob/master/mjpg-streamer-experimental/plugins/output_http/README.md
mjpg_streamer [input plugin options] -o 'output_http.so [options]'
You need to edit the start script of mjpg_streamer. Check /usr/local/RepetierSetup/bin there is teh start script for streamer and you can add your params there.
Just looked into it and have it working now.
PS: The code in github is quite old right? Not worth sending a pull request for it as I'm exposing this params in the UI.
