Informer and filament runout sensor
Hi, can Repetier Informer send a message when filament runout sensor activates M600 procedure, filament change? So far I was able to recognize start and stop printing, even while printing from SD, but Informer ignores completely filament runout signal or manual filament change and takes no notice if I paused the print from the display (it works OK when paused from Repetier).
Is it possible to wake up Informer by sending something from printer firmware?
Sorry for a silly question, I have no real insight into the communication between Repetier and the printer, hopefuly somebody better informed is listening :-)
I use Repetier and Informer on Windows, printer uses newest (7/2016) Marlin 1.1.0 RC BugFix firmware.
Would it be possible to get push messages about M600 from this as well? I can't seem to find anything about it anywhere.
And I can confirm that in console repetier-server can read this whenever my runout sensor is triggered: echo:enqueueing "M600"
echo:enqueueing “M600”
in log part of repetier window? Other push messages are issued normally?
I am using Repetier Server on a Raspbery Pi.
