install repetier server on synology with docker station - no configuration usb ports
Hi .. if someone installed Repetier-Server on Synology with docker station can you tell me how to configure USB ports? because I can not do it I do not see the / dev / ttyUSB0 in the configuration of the port or another name that allows me to correctly configure my repetitive server .. thanks
