Invisible object after slicing
Hi everyone!, Trying out the new version V2 of Repetier Host , after slicing the object doesn´t appear on screen , not by layers not by whole, it does show the trace moves though, than way I can see it did sliced.. Anyone with the same issue? when using V1 I had no problem whasoever..
And if use CuraEngine, the sliced as the below. So, I think, that I has accidentally off something. But don't know, where and what, if somebody can prompt, I would like it.
I have similar problem, after slice with slic3r, I see only object, not supports, for supports there are only moves. What can be wrongly set?
